Everything posted by Jack12477
Small progress update: After gluing and squaring all the bulkheads to the false keel. I started on the lower decks. Totally misread the instructions on the Mukali wood and started using the darker "walnut" veneer instead, after doing the two most aft decks I caught the mistake and switched to the pale yellowish Mukali wood. Which they had printed photos in this kit like they've done in some of their other kits I've built. After installing some cleats to support the outer most edges of the decks so they don't become a "teeter-totter", I installed the lowest decks first. Tried applying some stain directly to the wood but it looked to dark even tho I wiped it off immediately. So for the other decks I put some Wipe-On Poly on a cloth and went over the planks with that first then applied the stain over that, wiping off the stain almost immediately. Finish came out looking a bit weathered to my eye. After this I glued all the lowest decks in place, added the reinforcing blocks for the masts, but left the middle deck just dry fit for now, until I double check all drawing for anything that needs to be added to the lowest decks before I paint myself into a corner - so to speak. Photos follow Dry fitting all decks first Then adding the planking, staining and gluing in place Reinforcing blocks for masts
Okay, back to the build. I finished gluing all the bulkheads in place makin sure they are perpendicular to the false keel. Right now I am dry fitting the decks to see how they fit. I notice that 3 will need some type of blocks at the outer ends to keep them from sagging and rocking since the only support is the false keel in the middle of the deck. Photos will follow later once I finish testing.
You have a pretty good eye. It is 25 1/2 inches as it sits on build board. Build board is 3 ft long Correct! Finished size. It is just over 6 inches wide before planking. No problem! Just didn't want that discussion to get lost over there. It is worth knowing. I did visit this ship in Baltimore a few years ago with the Admiral and our youngest granddaughter who had to explore every inch right down to keel. It is a really beautiful ship regardless of the history of its rebuild/restoration.
For my next ship build I decided to finally drag the Artesania Latina US Constellation kit out of my stash and start building it. It was given to me by a good friend as a birthday present 9 years ago and has languished on the shelf since then; partly because it was intimidating, but mostly because I did not have the work space big enough to set it up and build it and lastly I did not know where I would display it once built - still don't but that will be dealt with later on. Even the box it comes in is huge and intimidating. I first constructed a build board that will hold it. Unfortunately I routed a groove along the centerline of the board to hold the keel but when the keel sits down in the groove the bulkheads don't seat fully, so I set it flush on the board and screen small cleats alongside the keel to keep it upright and straight. Some startup photos are below: So far I have dry fit all the bulkheads, sanded them as needed and am now slowly gluing them in place use small pieces of aluminum angle to keep everything perpendicular to the false keel. At this point everything is just dry fit
Well guys, @Canute, @cog, @Egilman, @Edwardkenway, @popeye the sailor, @mtaylor, @CDW, @Backer, @Landlubber Mike, @lmagna, just wanted to let you know that I am leaving the dark side and going back to church ; or is it the other way round, leaving church for the dark side? But anyway I am dragging the AL USS Constellation kit that I received as a birthday present 9 years ago out of the stash and onto the workbench as my next build. So I will see you all over in the kit build arena as soon as the dust settles from the mass migration. 😉 But I will continue following all the non-ship builds over here. My son gifted me 2 vintage Verlinden diorama ruins for my birthday and Fathers Day so another diorama(s) is(are) in store for some future build here. One of the ruins is 1:15 scale, misprint in sellers ad, instead of 1:35 but we decided to keep it anyway. Both are Verlinden's original plaster castings in original unopened boxes. As Arnold once said ""I'll be back" 😎
