Everything posted by JSGerson
You will notice in the image of the rails above there are markings for drilling the stanchion tenon and belay pin holes. First the stanchion holes were drilled and dry fitted with the stanchions. This in turn was dry fitted to the bow. The image below shows just the starboard. The same was done for the port side.
- 974 replies
- rattlesnake
- mamoli
After looking more closely at Harold Hahn’s model (and others) I noticed that contrary to Mr. Hunt’s model, the stanchions’ top tenon does in fact show flush on the surface of the rail. The Practicum would have had the tenon shorter so that it didn't show at the rail surface. Because I thought you shouldn't see the tenons I initial chose to use brass wire pegs. Since I found that is not necessarily the case I will make the tenons for the top and use the brass pegs only for the bottom of the stanchions. The brass pegs will give me a little leeway when installing the railings. Using the 3/32” square stock I made earlier (see Fixed Gang Plank) I fashioned the fourteen ½” long pieces into stanchions. The tenons were made in the same fashion as the gun truck axles, one side was sanded to slope inward, and a brass wire was inserted in the bottom to create the plug. Notice my fancy macro lens in the second photo? The image was shot through a magnifying glass.
- 974 replies
- rattlesnake
- mamoli
Everything is built and ready for installation. I'll be updating the log soon with all the gory details.
- 974 replies
- rattlesnake
- mamoli
The Forecastle Top Rail Stanchions Once again I am going to deviate from the Practicum for the construction and installation of the forecastle rail stanchions. The Practicum instructs the builder to create 1/16” wide tenons 1/32” deep on both ends of fourteen ½”stanchions. However once the stanchions are installed, there will be no indication of this effort. Instead I plan to use brass wire like I did for the quarterdeck rail stanchions but at both ends for the deck and rails. It won’t look any different and should be just as strong and a whole lot easier to do…assuming I don’t screw up.
- 974 replies
- rattlesnake
- mamoli
Although the Practicum would have you rubber cement the tracings directly to the wood stock, I cemented them to card stock. The inside curve was cut off and that edge was used as a guide for the compass to draw the outside curve. It was then rubber cemented to the stock wood. I just found it easier to do it this way. The railings were subsequently cut from the stock wood using the scroll saw, trimmed and sanded. The edges still need to be shaped, belaying pin openings still need to be drilled, and the whole railing will be stained black, but I’m getting a little ahead of myself.
- 974 replies
- rattlesnake
- mamoli
The only problem was that the curved rail tracing did not fit on the5/8” width boxwood. It was too narrow (at least for my model). If you remember when I was constructing the bulkheads for the main deck I ran into a problem where I didn’t have the required stock wood because it wasn’t in my wood package. Jeff Hayes of HobbyMill sent me some 1/16” x 1½” boxwood to resolve that problem. With what I had left over from that, I used for these top rails. NOTE: I informed Jeff Hayes of the need for a wider piece of wood for future customers.
- 974 replies
- rattlesnake
- mamoli
Forecastle Top Rails – Initial Here is another of those tracings that has to be done. Because of the construction differences (I assume) of each builder, the Practicum instructs the model maker to make a tracing of the inner edge of the bow bulwarks. Then you are instructed to transfer this tracing to 1/16” x 5/8” stock boxwood. Once there a parallel line is then drawn outside of the tracing.
- 974 replies
- rattlesnake
- mamoli
Although I didn't know it at the time I started installing treenails into the hull, treenails on the actual ships are almost the same color as the planks so have a very low contrast. A lot of the models I've seen go for the higher contrast to look pretty. My treenails are low contrast because intuitively I didn't think real shipwrights would be thinking about about color contrasts when building ships. I just thought it looked more realistic. Also at the scale of 1/64 means that the nails are probable over sized. It is for those reasons I believe some model makers don't treenail especially at the smaller scales. My next project, the USS Constitution which is 1/76 scale, I don't expect to treenail its deck. The hull will be painted so there is no point to nail there either. As a matter of fact, I've yet to see any model of the Conny with treenails. So for now, I'll pass on the Vanda Lay industries treenail maker. Take care, Jon
- 974 replies
- rattlesnake
- mamoli
It took a bit of searching but I found the reference to the dremel method of treenails. He also pointed to a forum which somehow I missed devoted to making treenails. My method which I learned by trial and error is really simple, relatively fast, and easy, but the fingers do get sore if you stay at it too long. I chose garden variety grocery store bamboo skewers as my base stock material because Mr. Hunt used bamboo. He however had some fancier stock material and used a Dremel treenail cutter of some sort. I really don't know. I then split the skewers into four or five splinters. Each one had pointed ends, well because they started as skewers. As I mentioned earlier in the build log I started off with a draw plate I bought from Model Expo but was dissatisfied with it. Then I discovered Jim Bryne's draw plate and what a difference that made. Each skewer splinter would generate 30 - 40 treenails after you cut the nails to length. It took me only about 10 minutes or so to turn one splinter into treenails. To install the treenails, I first used a common pin to located and create a starter impression for the drill in the wood. Then I used a push type hand drill as opposed the twist type to create the holes. You can really drill a lot of holes without you hand getting tired. Then I used a needle nose pliers designed to handle model railroad spikes. It has a groove cut into to securely grab the spike or in my case the treenail. That made insertion real easy. If someday I need to make treenails for a larger scale model, I probably will try the one toothpick equals one treenail method because I'm guessing pulling thicker wood through a draw plate will just be too hard. All that said, I'm glad that for this model I'm done with treenails...I think! Jon
- 974 replies
- rattlesnake
- mamoli
I'll tell you, I'm glad that's over with. Pulling those bamboo strips through the draw plate hurts your fingers after a while. If I used a tool like pliers to grip the bamboo, it destroys the ends because the pieces are so thin. Well the next item appears to be bow railing - this should be fun.
- 974 replies
- rattlesnake
- mamoli
Forecastle Deck Planking – Final One last time (I think) I broke out the draw plate and drew the bamboo strips (formerly bamboo food skewers) through the holes till they got through the #29 orifice. Cutting the fine dowels into short pieces resulted in treenails that fitted the hole the #69 drill made very nicely. The holes were drilled like before on the quarterdeck where the planking crossed the deck beams and the tree nails inserted. Using the Poly-wipe as my adhesive, a tiny drop was applied with a toothpick at each hole. There was no worry if I got sloppy as the whole deck would eventually be coated with it. Once I felt the treenails had been secured after a couple of hours of drying, the excess bamboo was snipped off and sanded down flush. The whole deck was then sanded. The deck was applied with poly-wipe, sanded, and applied again.
- 974 replies
- rattlesnake
- mamoli
You had the same wood problems? I purchased my package in Nov 08 probably before you although you are ahead of me in the build. From the correspondence I had wilh Jeff, the deficiencies I found a few years later were news to him. I basically have one chapter to go to finish the hull so hopefully I won't have any more wood problems. It appears that those problems were not the result of anything Jeff did or did not do. He inherited the list of wood type and sizes from the previous suppliers. Jeff informed me that somehow nobody told him (or the previous suppliers) of the inaccuracies or errors in the list until I did. I sure that any future buyers of supplemental wood for the Rattlesnake will not run into the same problem I had now that Jeff has been informed. You mentioned that you substituted boxwood for the dowels used for the masts and yards. Why? Was it a good choice? If I choose to go that route, would you be willing to give me that substitute wood list?
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
The wedge was installed under the foredeck by placing it on the dowel after it had passed through the foredeck. The dowel was then positioned and inserted into the main deck mast hole and the wedge was then pressed to the deck. Once the Weld Bond glue had taken hold (about three minutes), the dowel was removed. The remaining wedges were set aside for later. The planking continued.
- 974 replies
- rattlesnake
- mamoli
Mast Wedges At this point it was time to construct the main deck mast wedge under the foredeck like was done for the main deck under the quarterdeck. But an unforeseen complication arose; per the instructions of the practicum. In Chapter, 8, section 8.1.3, Page 24, Mr. Hunt describes the creation of the mizzen mast wedge for the parquet floor on the Main deck. The stock material was 1/16" x 1/4" swiss pear which was based on the 3/16" dia of the mast:+ 1/16" + 1/16" (thickness of ring on either side of mast) = ~1/4". The wood package contained 1/16" x 1/4" swiss pear. So far so good. In section 8.2.4, Page 108, the practicum addressed the foremast wedge under the forecastle. It stated: "And like the mizzen mast, there is a small mast wedge made of swiss pear on the main deck...The mast wedge was made the same way I described earlier." The foremast is 1/4" in diameter. To make the wedge I would need a stock piece of 1/16" swiss pear of at least 3/8" square: 1/4" + 1/16" + 1/16" = 3/8". There are a total of 3 wedges of this size, two on the main deck and one the forecastle. The wood package had nothing in swiss pear of this width in any thickness. At this point my only alternative was to create them in boxwood and then stain them as best I could. I immediately contacted Jeff Hayes of HobbyMills and started the email with “You wouldn't of seen this one coming.” Mr. Hayes was again very gracious: “I guess that Bob just used some pear that he had lying around and forgot to add it to his list. If you need a piece of 1/16 sheet stock, just let me know. As an alternative, how about gluing two layers of the 3/64 x 5/8 together to make them?” Looking at my supply of 3/64 x 5/8” swiss pear, I realized that that didn’t have too much left and didn’t know if I would need it later so I reluctantly went with his first option. Letting Jeff know I felt guilty about “nickel and dimeing” him he asked and I agreed immediately to at least pay for the postage. Within a couple of days I received a piece 1/16” swiss pear 1 1/8” x 24”, more than sufficient to create the wedges and anything else I might need. Thanks Jeff. Well if I was going to make one wedge, I might as well make all of the remaining wedges. Here you can see the progression in mast wedge construction.
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
Forecastle Deck Planking – initial With the catheads installed, it was time to start the forecastle deck planking. Just like the quarterdeck, 1/32” x 3/32” holly was used. Starting from the center the first plank was set in place. The practicum would have me lay out all the planks and later on drill out the foremast hole. I elected to create the foremast hole earlier. As soon as I had glued down the second plank, a notch mas make in the center plank to indicate where the foremast was to pass through the deck. By the time I had five planks down, I commenced to complete the hole. I wanted the five planks glued in solid so that when the hole was expanded to fit the dowel that would become the mast, there would be enough strength to resist drilling and filing. The mast has a rake to it and the deck hole butts right up to the support beam below so everything had to line up perfectly.
- 974 replies
- rattlesnake
- mamoli
"I received the ModelShipways Rattlesnake plans as an additional reference (gee, why am I putting in all this extra time and $$ on this.............I might be rigging by now...)" I am contemplating getting a set of the ModelShipway Rattlesnake plans myself. I have not seen what the plans look like. Is there anything in them that it is worth the $50?
I am waiting with anticipation to see how you install these fixed blocks onto your model. As you may know I'm following Mr. Hunt's practicum and his method for installing these is totally different but I didn't really like his results. Of course I'm no expert either in historical ships or model making and I would have followed his method blindly, but so far I like your method. I can't wait to see what you do next.
Yeah, they now have a coat of poly-wipe on them where as before they didn't. Right after I plank the quarterdeck, I get to go the rail process one more time when I put in the hand rails. That should be as much fun fun!!
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
I went a step further than the practicum and added the cleats and rings. It seemed a whole lot easier to do that now before installation on the model than latter when Mr. Hunt did his.
- 974 replies
- rattlesnake
- mamoli
Based on those marks, the areas to be cut out were blackened so as to make it clear where to cut. Using the fine tooth hand saw from my miter box and micro chisels, the appropriate areas were removed and fitted. This took me two attempts with the second being adequate, not perfect. At the tip of the cathead are six holes for rigging the anchors. The kit shows only four. Knowing that I had to drill through 5/32” six times precisely I used my Dremel drill press jig. Now I am blind as a bat and have to work with an eye loupe attached to my tri-focal glasses. Trying to get my head close enough to the drill press work area so that my lenses would focus, was a challenge. I would have sworn I was right on my marks but the results left something to be desired. If I had a true drill press, I don’t think I would have had the same results. The drill drifted because the jig wasn't as rigid enough so that the holes are not exact where they should be. The imperfections are there if you look for them.
- 974 replies
- rattlesnake
- mamoli
