72Nova
Everything posted by 72Nova
  1. A few more decorations and some touch up and this bulkhead will be finished and on to the Qtr deck mods. Michael D.
  2. Working on the upper bulkhead, I sandwiched .011" styrene between the scale decking used for this, the armless crew member measures out to around 5'-8" for scale reference. Michael D.
  3. Trimmed the height of the bulkhead minus the rail for the belying pins, also a shot of the scalloped extension of the Qtr deck. Thanks for looking. Michael D.
  4. I finally have the main deck gratings in the arrangement I'm pleased with along with the capstan base, I needed to relocate the main mast forward according to plans in McKay's book, which was also needed as the modified bulkhead mockup would've hit the mast anyways and also needed to check clearance of the gun, it's tight but acceptable. Still much more work lays ahead in this area. Michael D.
  5. interesting detail I've never seen before, looks kind of odd, were your gaps between those planks purposely created in that area of the hull for the battens and why? Just love your work Patrick. Michael D.
  6. I use a #80 bit, the smallest available. The dead eyes for the bowsprit top are completed and I simulated the iron futtocks with thread, it looks ok and a mock up of the new overall length for the spritsail topmast. Michael D.
  7. Michael I use 1.75 reading glasses and good lighting. I use mostly 1/2 knots which is more than sufficient at this scale and sometimes just glue. Michael D.
  8. Indeed she is Marc and I'll try my best to produce a worthy representation of her and her rigging will definitely test my skill. I completed the wooldings using 100wt brown ploy thread and 50wt thread to simulate the wooden hoops, they are 1.8mm wide, 12" at scale. Thanks for looking. Michael D.
  9. Thank you, Kirill, it will be quite useful, just amazed at the amount of detail in Paynes engraving. I'm working on the bowsprit shroud dead eye placement using .030"x.030" styrene as a rail to mount them on port side only with eye bolts on starboard side. This will no doubt be a tricky phase when the time comes to rig them, and I think scale wise everything is looking good. Michael D.
  10. I took small break from the beakhead and roughed in the planking at the stern. I added the gammoning cleats, these measure just over 2mm in length and I'll pare them down a bit in height, the mock up gammoning rope is 0.4mm. Up next, I need to add the additional fore stay and shroud cleats and wooldings. Michael D.
  11. The exercise the last couple of days has been fabricating the grating for the beakhead, this took a few tries but I'm satisfied with the result, the slats are made with .015"x.020" styrene, I also angled the bowsprit to the centerline and made the cut outs for the gammoning in the trailboard. Michael D.
  12. Still in the process of dressing out the bowsprit, starting with the knee and top, as much customizing I've done on ships I've never fabricated a top from scratch, while not totally accurate, I think it looks ok. Michael D.
  13. In case anyone was curious about how this mess will be attached, here's a few pics of the assembled one-piece unit, the glue points will be at the base of the simulated keel/stem, along the leading edge of the deck and the rear bulkhead piece where it mates against the inside of the hull, in theory it should work. Thanks for looking. Michael D.
  14. Not yet Marc, still in dry fit stage but clamped pretty good as I fabricate the pieces though. Michael D.
  15. All of the reworking of the beakhead required fabricating a new bowsprit as the supplied one was about 1" too short after the mods, I left a slight crown in it and is positioned on top as would be in real case scenario and extends out at a 30 degree angle, which was the toughest part of the process. I think it's looking pretty close scale wise but still more work needed. Michael D.
  16. I figured it would be best to start making the necessary modifications to the beakhead area starting with continuing the middle deck out past the beakhead bulkhead and extending the keel/stem up into the area in preparation for relocating the bowsprit off center, still much more work needed but looking reasonably worthy thus far for all the effort. Michael D.
  17. Checking the fit of the beakhead bulkhead revealed some work needed to the port side corner, off by approximately 1/8", just a little too much to force it to fit without creating other alignment issues. I'll try placing the corner of the bulwark in boiled water and manipulate into shape, if doesn't work I'll make a horizontal cut underneath the molding below the gun to lean the bulwark outward. Michael D. '
  18. The prototype railing actually turned out ok, so I just finished it off and looks pretty good to my eye, completed the hatch, coamings, deck staining and the cut out for the tie halliard. Michael D.
  19. I'm using the same 24carat gold leaf I used on the Reale De France. Michael D.
  20. Thanks Kirill, that will definitely be of some use. The forecastle bulkhead is slowly taking shape, next I will need to fabricate the railing and the more elaborate main curved deck bulkhead at the Qtr deck. Michael D.
  21. I've changed my initial design of the belfry as it seemed too closed off, so this is what I have come with and once I add the gilded decorations it should like a reasonable representation of what this area could've looked like, I know with the belfry at the forecastle and the added entry port, this more or less represents her around 1660. Everything is still in dry fit stage. Thanks for looking. Michael D.
  22. Thank you Marc. The mockup of the forecastle bulkhead is ongoing, but I'm shooting for something like on the HMS Prince of 1670 where the belfry is somewhat integrated into the bulkhead and not sitting on top of the forecastle deck, there will be single doors either side of the belfry, just giving you an idea where I'm heading with this. Also I cut in the entry port on the larboard side only, still a lot of work lies ahead. Michael D.
  23. With the deck surgery ongoing I took a little time to rework the lower fore mast, introducing taper and fabricating the hounds, also I pulled a mold of the figures on the outside of the bulwarks and attached them to the inside for added detail and a finished look. All of this is still in the rough in stage of course and just amazed how soft and bendy the plastic is for it's age. Michael D.
  24. Ian I'm still trying to wrap my head around this entire project, first rate craftsmanship/ engineering at all phases👍. Michael D.
  25. Hi Ian, I find it more manageable while I make the modifications/ repeated test fits and it will be so much easier to glue to hull in sections as I work towards the poop deck. Michael D
