Everything posted by 72Nova
Hi Ian, I'm humbled by your compliments. I used ropes of scale polyester line for the gammoning and spritsail shrouds, and I use Syren line as well. You are correct about the tacks, I still need to add the fairleads under the trailboard. That photo is someone else's work/wood shop unfortunately. Most of my tools are at another location due to space. Michael D.
- 324 replies
- Sovereign of the Seas
- Airfix
Hi Kirill, Here's a few, one can almost consider them bobstays, but they are different. The last major piece has finally been glued in, that being the beakhead bulkhead, at the moment I'm fine tuning the fitment of the catheads and small modifications to the canon/gun ports to compensate for the added thickness of the deck. I will use some artistic license to clean up the corners where they meet up with the bulwarks, then a myriad of paint and gilding touch ups. Thanks for following along. Michael D.
- 324 replies
- Airfix
Thank you, Marc, I've seen them rigged with lanyards on both sides but to me doesn't really make sense since they're not attached to the bowsprit itself. Michael D.
- 324 replies
- Airfix
In my limited research I haven't seen any rigged this particular way, Lee's does not make reference to them nor does Anderson, Don Dressel mentions they didn't appear until after 1700 and that maybe true but the painting by Payne which I believe is around 1657 and way too early, clearly shows them. I did find a build of the Le Rochefort 1787 that has them but rigged entirely different, looks like they start from the tip of the bowsprit with a lanyard and run almost Parrell being made fast by the cathead, perhaps this is what Mr. Dressel meant? Don did not rig them on his SoS. Thank you for the compliment, Kirill. Cheers! Michael D
- 324 replies
- Airfix
The bowsprit shroud exercise is completed, this was much more challenging than I anticipated but I think it looks acceptable. Thank you for stopping by and taking a look. Michael D.
- 324 replies
- Airfix
A small update, I used .35mm line for the gammoning and completed the topsail lifts. Up next are the bowsprit shrouds, I'm actually looking forward to rigging them as it will a first for me. Michael D.
- 324 replies
- Airfix
The bowsprit is finally glued in along with the topsail yard, braces, parrel, clue blocks and the tie. Next, I'll rig the lifts before completing the furled clues of the sail along with the necessary rigging, then I can focus on finishing up the bulkhead and move on to the gammoning and bowsprit shrouds, not perfect, but pretty darn good to my eyes. Thanks for looking. Michael D.
- 324 replies
- Airfix
Kirill, I really like your choice of decorations, especially the portraits, an exciting project to say the least and goes without saying I'll be leaning on you for resources regarding mast and spar dimensions etc when the time comes to start mine. Wish you well on this journey my friend. Michael D.
- 30 replies
- Golden Hind
- Airfix
Thank you my fellow ship modeling friends, I'm starting to feel a little more comfortable working at the smaller scale, which is good as I still have the Airfix ST. Louis, Golden Hind and the Revell Viking ship waiting in the wings along with the 1.96 Cutty Sark that started it all at age 12 on that fateful New Years Eve night of 1971 Michael D.
- 324 replies
- Airfix
The spritsail mast area is progressing with the fabrication of a new spritsail topsail yard, this measures out to approx. 54.00 mm or 30ft at scale, the tie, halliard and parrel are in place, up next, I will be fitting out the yard with the necessary blocks and furled sail before gluing the bowsprit in place. Michael D.
- 324 replies
- Airfix
The shrouds are completed along with the lanyards, the top sail lifts are clove hitched around the cap, well simulated anyways, and the lift blocks. The pendants for the back stay are adjusted to their final lengths. I experimented a little with the ratlines by separating the 100wt threads, illustrated in the lower two compared to the 100wt on top, while technically thinner I don't see a striking difference for the added work, anyways that's it for this update. Next will be the top sail yard tie and halliard assembly, thanks for looking. Michael D.
- 324 replies
- Airfix
Kirill, You've been planning this for some time now, so it's good to see it becoming a reality, I have the same kit, so I'll be watching closely. Michael D.
- 30 replies
- Golden Hind
- Airfix
The shrouds for sprit sail mast are completed, I used .20mm line for those, in the process of mocking up the pendants for the crow feet, using 100wt silk thread for these, once I'm happy with those I'll glue the knots at the masthead and will have just enough room above them to fasten the single block for the royal stay. Thanks for looking as always. Michael D.
- 324 replies
- Airfix
Bill, that is a great tip worth mentioning👍 Michael D.
- 324 replies
- Airfix
The rigging has officially commenced, 1st pair of shrouds are on, I used .20mm shroud laid line and 100wt tread for the serving. Scale wise I think looks pretty good. Michael D.
- 324 replies
- Airfix
With the modifications to the beakhead bulkhead nearing completion, this is the final test fit of the bowsprit, once the eyes for the bowsprit shrouds are fitted and the sprit sail mast rigged, it'll be glued in. Cheers. Michael D.
- 324 replies
- Airfix
Dressing out the bowsprit is completed with the addition of the eye bolts for the horses, I will follow Lee's explanation and use two horses. My initial plan was to install the spritsail topmast yard brace blocks on the bowsprit, but they were used later on so I'll follow Paynes plate and run them directly to the range. Currently fabricating new catheads and adding the timberheads to the forecastle rail, still a lot pre fitting left to do before installing it for good, also completed the rudder chains. Michael D.
- 324 replies
- Airfix
I've completed one of the pendants, I tried to replicate how their rigged on the Royal George....I know a much later date, but I do love the detail and complexity of it, Overall, I'm happy with it, the rings could be a bit smaller, but geez their already 1.5mm so I'll just run with it. Thanks for stopping by. Michael D.
- 324 replies
- Airfix
While the work continues on the beakhead bulkhead the scale chain arrived I had ordered for the rudder. The preliminary mockup is looking good with the pendant still left to do, the chain will be cut and a ring installed at the midway point to accept the hook of the pendant and the other end will be hooked below the gallery, whether or not chain was used, who knows?, but it looks like it belongs. Michael D.
- 324 replies
- Airfix
Thank you for likes, they are very much appreciated. I've wrapped up the work on the poop deck, outfitted the Ensign staff with cleats, the truck and final paint, added cleats to the deck and sides for the main braces and mizzen sheet etc. The focus now will be to finish dressing out the bulkhead beakhead, bowsprit and get that assembly installed. Michael D.
- 324 replies
- Airfix
The decorations on the lantern are completed, I added the remaining knees, completed the decorations above the galleries and currently working the Ensign staff. The final figures atop the taffrail will be added much later on. Michael D.
- 324 replies
- Airfix
Kirill, Your model looks stunning no matter the background, I especially like the last photo. Michael D.
- 228 replies
- spanish galleon
- lee
Thanks Michael, I've done somewhat the same in the past using transparent colors and all look good, I was really tempted to do a black background with the gold leafed tulle. Michael D.
- 324 replies
- Airfix
