palmerit
Everything posted by palmerit
  1. Had some gaps with the third strake. It was either reshape the strake or install the strake and have gaps. Since I’ll be using filler, sanding, and painting, I decided to fill the gaps. We’ll see how it looks when I’m done filling, sanding, and painting. (One gap had to remain for the rudder.)
  2. The book has 6 pages (in English, French, and Spanish) on the Endurance, its voyage, and the discovery of its wreckage.
  3. Starting on the Endurance. 28 bags of parts plus an envelope of sails and a thick instruction book.
  4. It might be nice to see a new section under "Shop Notes, Ship Modeling Tips, Techniques and Research" on "Tutorials". These could be organized by particular "How-to" topics. These could be posts with new member-generated How-tos. It could also be links to build logs (parts of build logs) that show particularly detailed How-tos on particular techniques - these could be links posted by the people who wrote them, or from people who found them in a build log and found them useful. It could also be link to YouTube videos and other external sites. It wouldn't be posting questions on "how to" but posting solutions members wrote or found, even if just links to possible solutions. I know there are lots of build logs that show different techniques for different elements of ship modeling, but unless you read through 100 build logs it is really hard to search for them, and doing a google search will often not find them. I posted a question on my own build log on how to seize a block (I didn't even know that was the name of the technique I was asking about) and someone said "do a search" (which I did and did not find something complete) and said that there are some on videos YouTube (without a link). If I find some good things, I'll post them on my build log, but unless someone is building the Sherbourne, or reading 100s of build logs, few will find what I post. I know there is some great materials in the NRG Articles and How-Tos page, which is linked on the Articles Database, but there are certainly some great tutorials on existing build logs, on YouTube videos, and that some members could generate that could supplement what's there. I've found some build logs where people take a wonderful tutorial approach (and some that were suggested to me) but they can be hard to find and will not come up as "tutorials" in a google search (and certainly not from using the search bar). I know there are some of these tutorials posted in other sections, but they're often mixed with dozens of other posts. Just a suggestion.
  5. I find using Google is a better search option than using a search bar on a web site (any web site). In addition to the search term add on the same line site:modelshipworld.com and that will limit to posts on this site.
  6. The topmast and some of the yards are made from 4mm dowels. I unfortunately just started cutting the yards to size and didn't realize that I should have made a couple small ones from the same dowel. When I went to cut the last one, it was longer than the pieces I had left. I thought I had them all planned out, but I had missed accounting for one of them. I asked Chris about ordering another one from Vanguard, but he suggested to order one from the US. Chris told me that the dowels are walnut made by Amati. In the US, I can order them from Age of Sails (https://www.agesofsail.com/ecommerce/am2535-04-amati-walnut-dowel.html). While the dowels are inexpensive ($1.37 each), the shipping is pricey. But at least I'll be able to continue.
  7. The main mast, mast caps, and main topmast are assembled (glue is drying). Thankfully I attended to how the holes that were drilled into the topmast needed to be oriented. Will paint black both mast caps and the masts areas between them.
  8. It looks according to the plans that there might be a narrow disc on top of the main topmast. Is that right? I didn’t see it on the photos in the manual (but I think some of the photos are from a different ship). If so, would those be left natural wood or painted black?
  9. To get everything to stay aligned with gluing, I made a copy of the section of the plans and taped it to a scrap piece of board (the build board from my Dory), inserted the glued mast cap to the mast, and taped everything down in position relative to the plans. We’ll see how this works.
  10. I ran a round file a little bit on the inside of one of the pre-drilled holes in the mast cap (did a little, checked, did a little more) and that was enough to get the slight angle.
  11. Suggestion on how to get the mast caps to the right angle (84.49 degrees on the plans)? Right now, the top of the main mast is right at 4mm, and the mast caps ride snugly. I’m guessing I either need to narrow the mast a bit more or widen the mast cap hole a bit. That’ll make it loose and allow it to take on a slight angle but then it’ll be loose. Do I then just “lather” with glue and hold it in place until it’s set? That’s what I’ll plan to do tomorrow unless someone has a better suggestion.
  12. Starting to plank the Smack. One nice thing about working on multiple models at once is that I don’t need to rush anything. The garboard is glued on after having been shaped. Now the first strake is being shaped after soaking for a bit in hot water.
  13. I think I’ve hit the first point where the instructions leave me a bit befuddled. I’m at the point of shaping the masts and spars, which I think I know how to do. I’m not entirely sure the best way to tie the blocks onto the masts and spars. I see where to tie them on the plans. I’m not sure how - what kind of knot to use etc. If someone can point me to a good tutorial it’s be appreciated.
  14. I added the deck, faired the hull, and started to add the keel. I’m not entirely sure how much to fair the part near the stern. I’ll need to check the fit of the planks. I had to sand down some of the bulkheads quite a bit in a few places because they extended too far beyond the deck.
  15. I did finally finish the anchors. The black straps are made from thin strips of thick black paper that you cut from a small supplied sheet. I started by glueing the strips to the bottom of the cross piece a letting them dry (I intended overnight but it was actually for a few days). Then I glued one strip to one side, let that dry for a few minutes, then glued the next strip to to one side and let that dry, and so on. Then I went back to the first strip and glued to the next side and let that dry, and so on. I kept the strips far too long, in part because I wasn’t sure if I should wrap once or twice. I ended up wrapping just once around. I cut the excess when I got all the way around.
  16. I previously posted that Lego was releasing its own version of the Endurance: I told my wife about it and she actually put it on my Christmas list. That was a nice surprise under the tree. It's been a while since I've had to help my boys build their Legos, though my job was usually finding parts for them. My boys also bought me a Model Shipways Syren. Another nice surprise. I think now I have about five years of models to build. My wife told me this morning that she tried ordering it from Lego on the day it was released but it quickly sold out online. It was sold out at one of the Lego stores in Nashville but she saw that there were some at the other Lego store. They wouldn't hold it for her. She said she went to that Lego store on Cyber Monday (and she never goes to the mall) after we returned from visiting family over Thanksgiving. There was a line out the door and they were only letting someone in after someone left. She saw two Endurance models remaining on the table near the front door. While waiting in line, one couple in the store was eyeing one up, another almost grabbed one, and the people behind her said they were planning to grab one if they could get inside. She was able to get one of the last two before they sold out. Over the Black Friday week the Endurance came with a free gift of the Shackleton Lifeboat at a larger scale. I hope it's okay to do a build log on a Lego set. I'm guessing I'm not going to run into problems with misaligned parts, poor instructions, and broken masts. And there should be far less sanding. And it'll probably take me 2% of the time it takes to do a simple wooden ship model. It's a nice thing to build while watching some football or movies with the family in the living room. It's Christmas Day, so it's two football games today on Netflix and maybe a movie tonight.
  17. I haven't yet begun the rigging on my Sherbourne, in part because I've been trying to read build logs for tips and recommendations. I'm planning to post some of those here (for my reference, for others to check out). I'll update this post as I find more. Here's one on the NRG Rigging Project build that illustrates shrouds, ratlines, deadeyes:
  18. I'm thankful that the first kit I bought was the Vanguard Sherbourne (a decision I made after reading a lot of posts here). The instructions are very clear, the pieces fit together really well, the parts are clearly labeled, the materials are high quality. It's kind of unfair that a complete novice can make a model that looks so good. (I have Syren on my list for a more advanced build someday after I clear the stash I've accumulated.) I've also been building the Model Shipways Shipwright series of boats (Dory, Pram, Smack). The instructions are detailed, but not always entirely clear. You'll see in some logs (not just mine) things like "I had to puzzle over ..." or "I had to read ahead ..." to figure out what to do. It's sometimes like solving a puzzle to figure out what the next step is. Once you figure things out it makes sense. Part of the challenge is that the instructions often describe the way to do something but the parts don't make it obvious which of a few ways to do something, the photos are fuzzy and not often from the best angle, let alone multiple angles. The plans in the instructions are inexplicably not to scale sometimes, and you often need to use the plans to build a part. Not all the pieces are clearly labeled. And what's in the instructions sometimes doesn't match the materials supplied. And much of the wood is basswood. It's not the case that pieces fit together, but that you need to align them right and glue them in place, sometimes hoping that you get them just right because a future step is going to rely on getting their placement just right, and neither the instructions nor the build make that obvious. My sense is that's not unique to these models but is fairly common to the design of lots of "old school" wooden ship models. I know this can read an indictment, and it's not intended to be, but as a heads up to the novice to expect more of a challenge than the "best for novice" designation or recommendation might seem to indicate. I've posted basically the same other places before. I'm posting here again for when future novices might stumble upon this thread looking for a "best" model recommendation. I'd recommend a novice either getting the Vanguard Sherbourne or one of the Vanguard fishing vessels rated as Novice. Then either continue with Vanguard Models or try one of the novice models from Model Shipways, Midwest, or Bluejacket if you want to exercise some other wooden model ship muscles. The Vanguard Models are more expensive. The Vanguard Models will take more time to build that the Shipwright Series models, so it's probably a wash in terms of the "dollars per hour" part of the equation, let alone the quality of the final product. The biggest challenge of the Vanguard Sherbourne (and the same would be true for the Vanguard fishing boats) is going to be the hull planking (haven't got to rigging on it yet, and I'm sure that's also going to be a challenge). The planking on the Model Shipwright series is definitely simpler. But unfortunately, the way the Model Shipwright series does its planking (laser cut parts of different shapes) is completely different from the way the Vanguard model does its planking (wooden strips). I did learn a lot doing the NRG half hull, but that's also a completely different way from either of those (scratch built pieces from a basswood sheet).
  19. Oops. I was rounding the boom and the gaff in my drill and was a little too aggressive. These start square, being from a laser cut thick sheet. There’s a couple of precut holes, which in a nice gesture, but it also makes the wood really weak around the hole. Model Expo has a parts request page to order a replacement part (https://modelexpo-online.com/parts). In addition to ordering a new sheet with the boom and gaff, I also asked for another PE sheet because there weren’t enough long pieces for the pintles.
  20. As someone who's brand new to this kind of modeling (just started over the summer) - and as someone who has used the forum to answer the question of what the "best" kit is (for a beginner) and who asked a "best second kit" question - when someone is a novice, or even has one or two kits under their belt, it is hard to even know what "with respect to what" factors to ask about or to specify. I wouldn't have known, for example, how different models can be in terms of the quality of their materials and the way they fit together and how different they can be in the clarity of the instructions until I worked on a couple of kits. If someone's a beginner, or has done one or two kits, they probably don't really know what the criteria are. Even reading build logs, you often don't understand what the differences are until you get your hands on a model. (It is odd to hear that some manufacturers still send instructions by CD/DVD. I haven't had a computer with a CD/DVD drive in a decade.)
