Hank
SPECIAL CONTRIBUTOR
Everything posted by Hank
  1. KG, Very nice striping, indeed! As a retired designer/draftsman (CAD/Board), your method of striping is quite alive in spite of all the alternative ways available today. For those who might be interested, using a straightedge (or other drafting instrument such as French curves, etc.) as a guide - in order to keep the instrument OFF the material being painted, simply turn the straightedge over and apply masking tape along the back side of the tool. This will allow sufficient space to keep the tool off your material and as KG mentioned, not leave a paint smear. I have a whole set of drafting tools in my case which have tape applied to the underside. This works very well for doing drafting with tech. pens and scribes (and pencils!!). Hope this helps!
  2. Todd (Sorry I got your name wrong on my first reply!), Well, not being into the WoW stuff, I had no idea that they were producing kits - perhaps if this entry kit is popular, they will consider posting this fact on the various ship modeling forums, etc. I'll check out the link you provided. Thanks for the reply re. the weaponry - can I assume that their deck fittings are crude as well, or have they provided decent detail on those? I do my own 3D design and printing - I use Design Spark Mechanical (free version) for the 3D design and currently print with an AnyCubic Photon Mono X 6K LCD printer. The available drawings on NARA of PURITAN (NARA has more that are still not available online) do provide ample information to make detailed parts for a model but some items are a bit doubtful as to accuracy (guesstimating from photos). BTW, your bow emblem looks fine - a very nice design for adding the "sparkle" to the model. Hank
  3. Keith (I hope that's the correct owner of this thread) - I just saw your build tonight and looked over what you've accomplished. Quite impressive, to say the least!! I'm currently designing (3D Design/Print) the parts for a 1/200 scale USS PURITAN (BM-1) and after looking over your photos I see that there are quite a few common parts, such as small cal. deck guns and various fittings. I know there's a 1/350th scale 3D printed kit available (Iron Shipwrights), but I wanted this to compliment my 1/200 scale USS NEW JERSEY (BB-62) model (bookends of a sort - 1st "battleship" and last (IOWA Class) battleship). I'm doing mine waterline as my 3D program isn't real keen on hull design (or maybe it's me!!). I've also noted some possible discrepancies in the kit and don't want those to be incorporated into my project. Anyhow, I normally post on The Ship Model Forum but look into NRG from time to time, so I'll keep my eye on your continuing project. I'll ask a question - what references are you using for your weapons/fittings? I've found a few drawings online from NARA but some are very hard to read (faded due to age). TIA! Hank Strub
  4. Gregory, The difference between the Mk. 28 and Mk. 32 has to do with the front/angled face of the mount body. Here is a cut sheet of the Mk. 32 (I should have provided this in my orig. post) - Comparing the side elevation on this view with the earlier one of the Mk. 28 mount, you'll see that the Mk. 28 mount has an angled front face of 45 If you compare this to the Mk. 28 you will see that on the side elevation, the angled front face on the Mk. 28 is 45 deg. and somewhat higher from the bottom of the mount floor than the similar face on the Mk. 32. But, it's important in building models (esp. EXPENSIVE ones) to get these small details correct. At least IMHO that's a no-brainer!
  5. Well, not to throw a wrench in the works, but from the info (photos) provided on the dual 5"/38 gun mounts, I'm wondering if these are the correct version. The 5"/38 dual mounts that were installed in all the newer U.S. battleships (NORTH CAROLINA, SOUTH DAKOTA, IOWA class ships) were Mk. 28 mounts, not what appears to be the Mk. 32 - but I could be wrong. Suffice it to say, here is a cut sheet of the Mk. 28, Mod. 2 5"/38 dual gun mount that would be correct for this class of ship - The Mk. 32 dual 5"/38-gun mounts were primarily used in cruisers/destroyers. I ran into this problem as well, in building my model of BB-62 which is a kit-bashed 1/200 scale Trumpeter USS MISSOURI kit - those 5" mounts were incorrect and I replaced them with 3rd party parts at the time. Here is a photo of the 3D design/printed 5"/38 dual gun mounts that I've made for my model due to paint issues I've had with those earlier 3D printed (commercial) parts that I originally used when I built this model - This is the 3D rendering of the mount body only - barrels are separate. Perhaps Kevin can confirm whether or not these gun mounts are in fact, the correct models, etc. Hope this helps!
  6. Glad to see that others are finding Anycubic as being a good printer for both detailed and large parts. I've been 3D printing now for 4 years beginning with a Phrozen Mini and now into the 2nd year with an Anycubic Mono X 6K printer. What could be bought on Shapeways I now make for myself and use the freeware software Design Spark Mechanical for my 3D CAD designs and Chitubox (free version) for my slicing software. I will advise other modelers to make sure they do maintenance on their printers on a regular basis - this includes greasing and lubricating the sliders and vertical rails on their SLA printer with the proper grease, etc. Some AC models (mine included) have mini grease fittings on the underside of the sliders and finding a tip for a grease gun to fit is rather difficult. But, those fittings need to be greased or you will suddenly come to a screeching halt when the sliders freeze up. Proper grease needs also to be applied to the vertical (Lead Z) threaded shaft. The owner's manual and instructions generally don't mention these little tidbits - but are VERY important in the printing operation. Here is one of my latest large scale (1/48) projects - a 6"/47 D.P. 2-Gun Turret which was designed for the WORCHESTER class CA's in late WWII - I designed/printed all the parts for this display model using Phrozen Rapid Black Resin on my Anycubic printer.
  7. Those ARE the twin 5" Practice Loading Machines. These are shown on both the BB-63 1950 BoGP and the BB-62 1955 BoGP (Booklet of General Plans). As for the question regarding the existence of a flag bag abaft the after stack, the answer is "yes" as there were signal halyards employed from the after stack mast and were tied off on this single, centrally located flag bag. Here is a snip of the plan view from the BB-62 (1955) BoGP of that area - it shows the loading machines & flag bag being discussed - These items were unchanged from the 1940's and we still had the flag bag intact aboard USS NEW JERSEY when I was serving in her in 1968-69. I scanned this copy of the 1955 BoGP when I was at NARA in 2016 and the hand written note indicates changes made for her 1967 refit for Vietnam using this set of general plans. I have a set of the 1967 BoGP for NEW JERSEY, but haven't had it scanned as yet. This copy was in "fair" condition as evidenced by the quality of the scan. Additionally, this overhead shot of IOWA in 1944 should be conclusive although the flag bag can't be seen - Hope this answers your questions.
  8. Thanks for posting - a most interesting discussion. I tend to agree with her that CUMBERLAND, along with other U.S. ships thru our history, has never gotten the recognition they deserve.
  9. After reviewing the current status of books on the market (online), I've further revised my pricing as well as making a correction to one of the titles. Here is the revised List #1: Again, I have many more for sale, but this is a good start. Many of these titles are now hard to find or are out of print. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  10. After receiving some feedback from other members of the forum, I've revised again the pricing on several of the books listed - I have many more for sale, but this is a good start. Many of these titles are now hard to find. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  11. I've revised the pricing on List #1 - see below - I have many more for sale, but this is a good start. Many of these titles are now hard to find. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  12. I am beginning to clear out my shipmodeling bookshelves - I will post lists of books I have as I can get them categorized, etc. If and when these are sold, I will update the list. Here is list #1: I have many more for sale, but this is a good start. Many of these titles are now hard to find. Conditions of sale - Money Order Only - No checks, No Cash, Credit Cards, PayPal, or other forms of payment, etc. Postage (within CONUS) in addition to price of book - books will be mailed from my local U.S.P.S. (Mocksville, NC) either 1st class Media Rate or lowest rate they offer. If interested, please send me an email to hms@triad.rr.com (do NOT reply to this posting on this website as I may not see your reply) and let me know: 1) what books you wish to purchase. 2) Your mailing address and email address. 3) any other instructions prior to me mailing the books out. All sales final - no returns! I've listed the condition of the books and noted which ones have wear or other defects or alterations. Hank Strub
  13. Dennis, Sorry to chime in after the fact, but I know Model Monkey personally, we are both North Carolinians and both U. S. Military vets. I have purchased parts from him and his quality and accuracy are excellent. I'm glad you were able to find his products suitable for your use.
  14. I just listed under the Traders/Dealers/etc. forum boxwood sheets for sale. If interested, check it out! Hank
  15. Trying to pare down things in my shop that I more than likely won't need. The following items are for sale: (5) Sheets of Boxwood - 1/4" thk x 3" wide x 24" long (+/-) - this works out to be 72 sq. in. per sheet (LxW). These sheets have been packed away in the box they were shipped to me in 2009 and have been flat on a shelf for the entire time. Totally dry, etc. Here is a photo of this wood: Price is $30.00/sheet if purchased separately. If sold together (5 sheets) - $25.00/sheet or $125.00 - shipping is additional in either case. I will only accept a money order in U.S. Dollars - no checks, cash, credit cards, etc. This photo shows 8 sheets - I am only selling 5 of these at this time. If interested, please PM me and let me know what you're interested in and we can go from there. Shipping is from Mocksville, NC. Hank
  16. Scottie, Welcome to Model Ship World - we've made email contact so I'll be in touch again soon. This is the right "spot on the dial" for wooden sailing ship models and I'm sure you'll find lots of commentary - all you have to do is ask!! Hank
  17. Realizing that I will probably never get around to actually building this kit, I have the following items for sale as a package only: Trumpeter kit #03701 – 1:200 scale USS ARIZONA (BB-39) Originally intending to build this into the 1940 USS PENNSYLVANIA (BB-38), I have the following 3rd Party Parts and Accessories as listed below: Artwox #03701 – 1:200 scale ARIZONA Wood Decking Set Model Monkey (Shapeways plastic, not resin) – 1:200 scale 1934 PENNSYLVANIA Bridge Modifications Kit Model Monkey (Shapeways plastic, not resin) – 1:200 scale PENNSYLVANIA Boat Cranes Kit – Assembled/painted in separate plastic parts box. Model Monkey (Shapeways plastic, not resin) – 1:200 scale PENNSYLVANIA Funnel (1940 era) Model Monkey (Shapeways plastic, not resin) – 1:200 scale PENNSYLVANIA Main Deck Vents (3) – Painted White Ensign Models #2005 – 1:200 scale PE ARIZONA Deck Plates White Ensign Models #2002 – 1:200 scale PE ARIZONA PE Set Master Model #SM-200-001 – 1:200 scale 14”/45 cal. Main Gun Barrels Eduard #53 099 – 1:200 scale PE Cranes Set Eduard #53 100 – 1:200 scale PE Catapults Set Eduard #53 104 - 1:200 scale PE Life Boats Set Eduard #53 111 – 1:200 scale PE Railings Set Sapguy 3”/50 Mk. 22 Open Gun Mounts ( Shapeways Plastic, not resin) – 3 guns Arwox # AW60003 – 1:200 scale Anchor Chain The Floating Drydock PM-C115 Stud Link Anchor Chain 11.5 LPI (3D Printed – 4 sets) – NO LONGER AVAILABLE Trumpeter #06633 – 1:200 scale WWII USN Figures Set Note: This kit was started and a small amount of modification work has been done to the hull & main deck as I had intended to build this as USS PENNSYLVANIA (BB-38) in 1940. All kit instruction sheets, decals, flag sets, etc. and as far as I can determine, all kit parts are included in the original kit box. I purchased this kit from another modeler and a few parts he had scavenged for use on his ARIZONA project - I have not made an inventory of these items but they mainly involved the kit PE brass sheets - I believe these items will be included in the 3rd party PE sets described above. Package Price - $650.00 PLUS shipping – I have just under $950.00 invested in all of this and today’s prices may, in some cases, be higher than my original cost in 2015 when I purchased all of this. Interested parties should send me a PM and we can discuss in detail shipping and payment, etc. In addition, I have created quite a few 2D CAD drawings related to the PENNSYLVANIA modifications made to her after her 1935 refit - and the differences in her and ARIZONA. If interested, I can include a copy of those drawings and my photos & reference materials that I've collected for this model. Interested parties should PM me or reply for additional details, etc. incl. shipping costs and payment, etc. Thanks, Hank Strub
  18. I have books 1-16 of the Thomas Kidd Series available for sale. All are in excellent condition - read once and put on the shelf! The following list describes their title, type (hard/soft) cover, original price: I will sell the Kidd Series books for 50% of their original price + shipping. Some of the hardcover editions are no longer available, so if you collect nautical books, this might be a good deal. The 3 additional paperbacks are from the 1960's era and are interesting reading if you've never encountered Hornblower or heard of the Mary Deare. Anyone interested please PM me, etc. Hank
  19. Phil, I appreciate your comments above re. CAD and tend to basically agree with your observations. While I wouldn't characterize CAD drawings as being "artistic" I would say that some very proficient CAD drafters have been able to produce 3D rendered drawings (and I include your OKY BOAT pix) that certainly could almost pass for photos. I think this is an exception and not the rule overall. You are IMHO, completely correct in that much of it depends on that individual's ability to produce a quality and professional drawing in the end. There is a talent and knack to this, it's not by accident! I'll go back to one of my earlier comments regarding the 1935 drawings at NARA II that I found of BB-38 after her modernization. These wonderful "artistic" plans were more than likely drawn ink on vellum (at least the originals that I handled appeared to be such) and that particular draftsman had an extremely professional ability in his artwork. That's the main reason I wanted scans of those drawings. While computers can produce all sorts of colors, shades, tones, etc. they tend to lack a certain "artistic" aspect of drawing that manual drawings have - nuances, if that's the correct word for it, and I think a lot of this is due to the individual in the "driver's seat". I've seen quite a few recent 3D renderings of War of 1812 era combatants that are commercially available as "artwork" and I'm sorry, they simply don't have the same "feel" that the traditional water color or oil/acrytic paintings have. They tend to be "technical" rather than "artistic" in composition. Along the way of 47 years of drafting/CAD etc. I can honestly say that I've met very FEW engineers who could produce a correctly scaled and accurate engineering drawing that was actually useful. The usual answer was "I'm not being paid to do drafting!" - and their resulting drawings showed that over and over again (down & dirty). But, corporate heads now have virtually eliminated the Draftsman and even Designer level positions to save $$. However, in this hobby of ship modeling I think that anyone who is able to make their own drawings, whether CAD or manual, is certainly a few steps ahead of someone who lacks these abilities. The CAD drawings I've made for my various model projects were created to make parts, not to be "artwork" per-se, while at the same time "finished drawings" that I could share with others upon request, etc. Layout & composition, etc. being rule of thumb! As a side note, while my PENNSYLVANIA model is still basically in the box, I have already drawn up brand new main mast drawings, deck equipment drawings, and a few other miscellaneous details for that model in MicroStation 2D CAD and have shared some with Steve Larsen (Model Monkey) in order for him to produce 3D parts. ARIZONA and PENNSY are NOT identical in several aspects. Hank
  20. Roger, I can relate to your sub tale in that when drawing up HVAC & Mechanical equipment (boilers, chillers, heat exchangers, etc.) in new facilities layouts, we had to include repair/replacement space for pulling out tube bundles, etc. and believe it or not, quite a few corp. managers didn't want to allot this extra floor space because it cost more - they simply had no conception of what's required to maintain & operate this equipment - they were only interested in the bottom line. Hank
  21. Tim, To answer your question, "Yes!" - I reported aboard 03 Sept. 68 a few days before NEW JERSEY left Long Beach, CA for her one and only WestPac cruise 1968-69. We spent 6 months on/off the gun line and then an extra 2 weeks lurking in the Sea of Japan after NK shot down a USAF EC-121. I have been a member of their veterans group since 1990. I got you beat on the Tamiya 1/350 scale models - that kit first hit the market as a Life-Like kit (and in my opinion was a better kit in many ways - I've had/built 2 of them). I've built the Tamiya kits as well, but sold those in progress as I had no further interest in them. I got involved in the 1/200 scale Trumpeter MISSOURI kit in 2006 and spent 6 years converting it to USS NEW JERSEY 67-69 configuration. During that time I created quite a few CAD drawings in MicroStation to supplement the various modifications made to the ship that the kit did not encompass (it is as MO on surrender day, 1945). The Trumpeter kit, by the way, is far from correct as far as the hull is concerned and that was an exercise in reforming a misshaped hull - I did it one way, other modelers have done it in other fashions. However, the end product is this: She is 53" LOA. Much of the superstructure and all masts/RADARs/antenna, etc. are scratchbuilt. I incorporated 3D parts from a couple vendors in addition to supplemental PE & Decking - I had the decking vendor (Pontos) create the wood decking to my drawn specifications which was modified from their MISSOURI deck parts. I also designed 2 PE sheets for parts and found a UK vendor to print them for me. During the 6 years of building this model I had the pleasure of correspondence and communications with the late Richard Landgraff who oversaw some of her 1968 final mods and also her complete 1981-82 refit - he knew the ship inside & out. Back to drafting - here is my full size drafting table just after resurrection in my workshop earlier this year: It is now covered up with FLETCHER Class plans, my CAD drawings, and a light table on the lower right. My shop construction is a complete topic of its own over on Workshop Equipment, etc. forum in case you're interested. Hank
  22. Tim wrote: Sorry I missed that, Tim - Well, back in the '60s (in NC) boys took shop, girls took home economics - just the way it was back then. I see your point however and that does make sense. Different times, etc. I did learn cooking from my mother and found years later this came in quite handy. Not to bore everyone to tears 😱, but I'll relate this short tale - Having been transferred to a DE in San Diego in 1968 I quickly learned that this would be temporary as this ship was going to transit to Seattle, WA as a USNR Station Ship and they had no billet for a PN3 (Personnelman). So, while we were transferring people here and there to reduce the crew, the cooks were also transferred leaving the galley without proper staffing. Well, I made the BIG mistake early one morning of putting on an apron and proceeding to fry my own eggs - and found myself doing commissary duty 3 times a day for the next week or so until my 2nd Class could arrange for a temporary CM1 to take over. Initially, I found it quite novel (as long as liver [yuk!!!🥴] was not on the menu and I didn't have to mess with it!! ). 3 weeks later I was stepping on the quarterdeck of USS NEW JERSEY (BB-62) and reporting aboard (well YEAH!!). I think a further comment in the thread regarding typing classes was also somewhat overlooked - in today's CAD/CPU world, this is a necessity, not an elective decision to be made lightly. I was fortunate enough in college in 1965 to take a semester of typing - although my professor said I would never amount to anything as far as admin. abilities were concerned. I'm glad I've forgotten what her name was as she was dead wrong!! That typing class actually got me into the admin field in the Navy and later has provided me extremely useful CAD abilities ever since. I can (and do) type roughly 110 wpm and that's not exaggerating, simply a fact. And sadly, I know CAD guys still employed that are "Hunt & Peckers" when it comes to the typing aspect of CAD work (pun intended!!!). Also (and finally🥱) I have seen some very artistically rendered 3D CAD industrial layouts of various utilities & facilities that could rival the best hand drawn architectural renderings out there - but, in the final analysis it is the individual who has to decide which medium to work in. I see benefits using both board and CAD depending on the need, ability of the artist/draftsman, and what is required. Glad you brought all this up!!! Hank
  23. Rik, In regards to the Spark freeware - I'm pretty sure that this version is a lot less "user friendly" than their Spark Mechanical version that you have to purchase - at least, my experience with CAD & various software programs is that what's free is basic - no bells, whistles, or enhancements. And - this is where I'M having a problem in that I'm used to a professional level CAD program WITH all those extras. And I think that's why my acquaintance who's making great strides in using Spark is doing so because he's never had any prior CAD experience to confuse the issue, so to speak. The kind of designing we are trying to accomplish is basically items for modern warship models (deck equipment, railings & stanchions, RADAR antenna, etc., gun mounts, and FC directors). This is pretty straight-forward using 2D drafting/CAD but can get very involved when you move into 3D and solid modeling, etc. My main problem (as I see it!) is finding the tools to do various manipulations that I'm used to having available in my 2D program - they simply don't exist and having to come up with a work-around gets very frustrating and when I do that, it isn't long before The Admiral gets wind and winds up The Cat!!🥵 My suspicions are that they DO exist, but only in the paid-for version of that software. They get you coming & going. 😭 But, looking back a few years ago - I built a 1/48 scale scratchbuilt model of U. S. Sloop of War PEACOCK (1813) and in the preparation stage and developing drawings, I produced some 15-20 2D CAD drawings in order to make all the parts for the various carronades, masts, yards, spars, as well as all the bulkhead drawings for the hull and much more. In addition, that was when I was working away from home and bought the 18x24 tabletop drafting board and used it quite extensively at night when I needed a quick sketch drawn up in order to continue construction. Whether or not Spark is your "cup of tea" I can't answer, but is perhaps one of several you might investigate along the way. Hope this helps! Hank
