IgorSky
Everything posted by IgorSky
  1. The next step - the making of the waves. And ... it's still happened ... It was a sad moment when I discovered a crack in one of the corners of the bottle. (( Resin really strongly have reduced its volume. I think there are two reasons for this failure - I filled the heated resin and I added too much hardener. ((
  2. Hi Bob, Mike, Michael and Nils! Many thanks for your good words and all LIKEs!!! Mike, of course I still have a long way to the title of master, and I am still only a student now )) Yes, Niels, you'll have the opportunity to see this process in my next posts)) So, I am continuing. On Friday evening, I once again checked all the details, I fixed some of the rigging and I prepared the lower part of the body for the placing in the bottle.
  3. Thank you Patrick! I myself did not quite believe it))
  4. Thank you John! Yesterday I have gathered all together to check.
  5. "Sweetbrier, a 180-foot Iris or C-class tender, was built in Duluth Minnesota by the Marine Iron and Shipbuilding Company. Her keel was laid on 3 November 1943 and she was launched on 30 December 1943" Thank you Patrick! On spring I have contacted with Bernd Jocham and bought this set of drawings of "Sir Winston Churchill"
  6. Hi Patrick! I am not sure that it will be soon, because I have now the three projects in progress that I need to finish - ATLANTIC, RS 1 and LENA. But I collect materials for the building of two ships - Sir Winston Churchill and USCGC SWEETBRIER (WLB-405). Best Regards! Igor.
  7. Hi everyone! Many thanks for your interest to this mini project and all your LIKEs! The third sail:
  8. quote name="Omega1234" post="349856" timestamp="1443021130"] The zodiac was far easier than you'd think. Here's how - Beneath the waterline was a shallow v shaped hull onto which I glued plastic rods to simulate the rigid, but round inflatable sides of the hull. From there, I added the centre console and seat with the radar supports above the outboard motor at the rear. Hope this helps! Thank you Patrick! I think that at least for two of my prospective future projects I will need to make the zodiacs. Best Regards! Igor.
  9. WOW!!! Patrick you have carried the my thoughts about stand! And I still can not understand how you made the Zodiac! Bravo Patrick!!
  10. So, yesterday I was continuing to make a sail. The second sail: Best Regards! Igor.
  11. Thank you Nils and Bob! Nils, I built only several SIB about 15 years ago. Now I have only a couple of photos of my first SIB. The first of my SIBs: The second of my SIBs: But in January 2015 I returned to the making SIBs again with this model - http://modelshipworld.com/index.php/gallery/album/1020-noname-yacht-in-bottle/ Now I have 8 completed models and 4 in progress )) Best Regards! Igor.
  12. Hi Patrick! Yes, the needles from a syringe are a source of the tubes the smallest diameter. Usually I am using the needles with the diameter of 0.3 - 1 mm. Best Regards! Igor.
  13. Hi, Bob! I continue to get enjoy of the photos of your boat! Did you make the figure of lady? Best Regards! Igor
  14. Patrick, I used the needles from the syringe of different diameters. I cut short pieces and glued them on the ends of the boom. And every time I try to use the different ways of attaching the boom to the mast.
  15. Hi Tom, I just wanted to offer to moisten the sail white glue diluted with water. This will give it a shape. It is also possible to make the sail from a thin cloth (percale. Epoxy. I have used the epoxy resin several times. I have dyed it with using the gel from pens.
  16. Hi everyone! So yesterday I have continued. The mast and boom.
  17. Hi Patrick! My congratulations on the beginning of a new project! And of course, I am occupying one of the chairs in the first row. )) Best Regards! Igor.
  18. Thanks Michael! Yes, you're right - it needs a very small amount of material. It's one of the nice sides of the building of SIB. )) Best Regards! Igor.
  19. Amazing work Bob!!! Congratulations on the successful completion!
  20. As you know there are three things at which you can watch endlessly - fire, water and well made model ships! )) BRAVO Patrick!
  21. Hi Tom! How is it going? Are you going to use the sails from kit? Best Regards! Igor.
