Posts posted by JimGer947
Work kind of on hold for the moment....
.I have found that as work progress the cast metal bulwarks Parts 35-1 and 34-1 are the same as 34-2 and 35-2...
i.e doubles..
Emailed Disarmodel a couple of weeks ago and a reminder last week for replacements... Hopefully will get the correct parts or I will scratch build the offending/wrong parts
Work Continues and Problems solved
(1)....Finished planking the hull and according to the instructions it then appears to be required that fibre glass resin (Cataloy??) is used to cover the entire planked hull blend in the resin bow and stern.. Not at all clear in the instructions....Since for some reason Disarmodel have included a shed load of 4 mm strip I used this to double plank the hull... Less mess Problem solved
(2)... Part 101 is the top of the Bridge deck ..The part with the ? is not listed in the instructions and can only assume that it is the base of the bridge structure. It gives a 3 mm edge around the edges.. However the ply supplied with the kit is very poor 1 mm and was badly warped. Tried to de-warp with soaking, bracing at rear etc but nothing worked. Scrapped these parts and used 3mm ply as a replacement.
The same poor quality and warped ply was supplied for the wheel house and forward deck house. The wheel house was fabricated from ply and strip. The deck house from ply.
I would have had to replace the wheelhouse anyway as it scaled out at 4 feet/1.3 metres in height. The internal wheelhouse grating is supplied as a solid printed item and was replaced . This printed grating is supplied for an engine room vent and for the grating over the rudder arm and will replaced in due course
(3) Funnel is supplied as 21mm dowel and the funnel support ring has a 16 mm internal diameter....filing this item to the required diameter would be difficult as the white metal supplied is quite hard and brittle..My solution was to cut the funnel at the required height and rejoin
Progress so far . The white metal deck railing with are also being replaced with brass as again they are fragile, mismatched casting and have a fair bit of flash to remove.. As soon as you look at them they break.
The portholes are also being replaced as they bear no resemblance to the ones shown in the booklet.. kit supplies brass grommets.Have ordered proper flanged and detailed ports
- GrandpaPhil, zappto, Captain Slog and 1 other
- 4
Work continues
Started on the 2 winches as there is quite a few small parts...
Unfortunately, a few were missing or badly cast...
I dropped an email to Disarmodel and these parts were dispatched to m in a couple of days
The instructions on their building is a bit confusing and not helped by the dark colour in the instruction book.....
I followed the scale drawing supplied and the image on Page 86
Medium Superglue used as some of the parts are quite fragile
Have also started on planking the Hull and working out the run of the planking....As the wood is 8 mm wide it,s a bit difficult...
A little touching up is still required
- hexnut, Captain Slog, ccoyle and 1 other
- 4
Work Continues....
A correction to my previous post.. What I thought was MDF for the hull and bridge construction is actually 5 mm laser cut hardboard or Masonite to our US friends.
No real problems at this stage (other of my own making) . A little filing of the Hardboard slots ensures a snug fit for the frames.. Only slight and easily fixed problems were that the slot in frame 6 is @2 mm to long and frames 3 and 10 have been over milled by a 2 mm outboard of the deck locating stubs.
No great problem, a little packing will sort that.
Frame 11 requires TLC. Broke mine (my fault) . I decided that it was going to fit regardless.. Exopy repaired it ok
The Plastic /Resin bow and stern are a good fit
The false deck is aslo 3mm hardboard/masonite... A little tidying up of the locating slots give a good fit
I,ve marked the deck with the locations frames,deck structures and planked areas .
So far ...so good
I have built a few wooden ship kits over the past years ,but this is my first non-sail for a while. Bought it on holiday a few weeks back , stuck it my case . Saves Postage and I tend to travel light..No Airline surcharges.
It was surprisingly heavy ,due in part to the large amount of White metal casting.
the kits comes with 2 Booklets... One a 98 page colour step by step construction detail subscript in Spanish.
They 2nd booklet is a comprehensive list of parts in English Spanish, French ,Italian and German. Also included is a to scale double side plan and an A4 4 page booket on mainly how to construct the steam winch,
I hope you can see from the Thumbnails the MDF used for the hull and part of the bridge construction...There is also a large amount of white metal for rivet detailed sides, winches etc.. which all seem flash free and cleanly cast
There are also three resin?castings for the bow , stern and the engine room casing
The only part I can see me changing is the Funnel as it is wooden dowel.... Will try to source something better
So..all being well..as we say "Heid doon an awa we go"
- hexnut, Tadeusz43, Captain Slog and 3 others
- 6
Hi Folks .
I have'nt posted for a while as work and family interfere with the Ship Yard. With reference to instruction I have purchased the Talhoer Altsu Mendi Tug in the past week.. Curiously the kit is marketed by Disarmodel.
I digress.... It comes with a 20 page booklet listing all the parts in Spanish, French ,Italian, English and German.. Also included are a 98 page book of colour step by step instructions and as an addition 4 x A4 sheets of plans how to constuct the steam winch....Very helpful.
And that should get me through what seems to be a very good kit.
Previous builds...
Billigs Le Curieuse...Billings Krabbencutter....Constructo Enterprise... Artesania Latia Maria Ii and Le GranLejon ...Occre Tramvias Barcelona and Soller....Not ships but 90% wood and a few Tamiya 1/350 ships
Work in Progress...
Caldercraft HMS Snake 85% completed...... Artesania Latina a vintage Charles W Morgan @ 50% complete and fighting all the way.
In my Stash
Dusek Golden Hind.....Constructo Gjoa......Artesaina latina Jolie Brise and Bon Retour.... Corel Scotland......Talhoer/Disarmodel Altsu Mendi and last but not least an very old Model Shipways solid hull Gjoa
I should live so long
- mtaylor and thibaultron
- 2
Hi Folks
Found this forum while looking for info and/reviews on Dusek Models.. Was on holiday in Spain recently and picked up their Golden Hind for 99 Euros @ £75.00 at then Exchange rate.,, Postage not a problem, stuck it in my case.
First impression is that its an excellent well thought out kit..
Only one thing in it has caused me to re-think my building techniques. The hull is single planked with 3.2 mm high quality walnut.. I am currently going through options on how to plank,any tips welcome
Have just bought one on Ebay. Your brilliant build log has given me some excellent ideas on how to complete her.. Have almost finished Artesania's Le Grand Lejon so I kind of know what to expect from the Jolie Brise.
Excellent Model
Altsu Mendi by JimGer 947 - Talhoer/Disarmodel - Scale 1/50
Work kind of on hold at the moment as I am still hoping to hear something back from Disarmodel with replacement parts.
3 emails with no reply and I tried their contact number with no success..
.Looks Like I,ll have to fabricate these parts.
Bet you anything the correct parts will arrive when I finished them and installed
