Mtoriordan
  • Gender
    Not Telling
  • Location
    New York
473 profile views
  1. Thank you for the advice Russ. I experimented with a clear coat, as well as getting some painting practice in. Stains, varnish and paints, oh my. An aspect of this hobby I had not thought about much and boy do I have a lot to learn! I totally enjoyed building from this kit. It was perfect as a second build. Similar enough to the schiff build and i was able to apply skills learned. It also stretched some of my newly acquired skills with a few new techniques. Another enjoyable Midwest build experience. I wish to express my gratitude to everyone for all the likes, advice, kindness and the very warm welcome. Midwest, Chesapeake Bay flat tie should be arriving next week.
  2. Jparsely, thank you for the advice. I know nothing about stains and varnishes. I also could never have put this together in two days and have it resemble a boat. I think I will be going with Russ' suggestion of a clear coat..perhaps a painted waterline. I googled clear coat and now know what it s I hav attached the inwales. There are a few more parts to attach before the instructions advise painting or applying varnish. Another lesson learned, plan an end game while previewing instructions. The inwales and risers don't leave a lot of room to work in
  3. I had measured the recommended height for the seat risers and attaching them was easier than I thought they were going to be. Preplanning the clamping was key. The next day after taking a good look, the risers seemed too high. Placed a seat across the rail and imagined a person seated there...definitely too high. Compared the placement of the risers on the plan to mine and they looked to be high by about 1/4 inch. I did not have any trouble gently prying the risers off. After installing them at the height similar to the plan, I was much happier with the appearance. I then began shaping the seats and had a really good time with that. After a lot of cutting and sanding, am very pleased with the seats. Found the process very gratifying. In between risers drying and methodically working on the seats, I also accomplished some major sanding on the hull and transom. Have some spots that need some cleaning up, but am making some great progress. Have gotten the grip attached. The very top of it bent at a slight weird angle, will have to get a photo of it up. Have not decided if it is something that will annoy me enough to remove and attach a new one. Thank you all for the likes. The seats have yet to be glued. I believe I am getting to a point that I will have to make painting decisions. Not quite sure where I am going to go with that yet.
  4. Russ, 'tapered' the exact word I had wanted to use but my brain would not provide. Are planks tapered to adjust for the curves? My tapered planks hung low in the center, running pretty deeply into the center plank. Mario and Brian, much appreciate your checking in and the kind words. Mario, I will be looking at the Flattie build you did. Thinking I would like to try that in the future. I had used push pins to attach hull to strong back. This is my repair job, pretty sure a seat will cover this area. I pushed a toothpick into the hole, trimmed the excess ofF and then sanded smooth.
  5. The second planks went on beautifully after putting a bevel in the upper edge of the bottom planks. The final planks were not cut straight as the other planks were. They had what I would describe as a wave cut, the center being much wider than either end. I had attached them and decided a day later to remove them and reposition. The planks were just visually unappealing as they were. Switching sides and flipping the ends around improved the look. The photos showing where the third planks looked just off were great, but have gone missing. As of now, she is planked and off the strong back. Have a little damage to tend to from the pushpins.
  6. Thank you Russ for the kind words and encouragement. Thankfully , wood is also very forgiving! I am very much enjoying the process.
  7. Port garboard attached, after much fitting and sanding. The work has been paying off, both planks lined up nicely and the height also matches. Whew. Moving along to the second planks.
  8. Thank you Russ and Buck, appreciate you guys keeping an eye on me. Also, thank you everyone for the likes.
  9. Gluing supplied blocks onto strong back, no problem, everything lined up nicely. A clamp, sould have run out and purchased a proper clamp. I went with the pushpins as I had them on hand. The small block I pinned into split in half. Had another smal block of equal size, which also split. Finally got hull pinned to a block and did end up with one more pinhole than I wanted. I will be using a toothpick to plug those holes and they should fill in nicely. I then placed the gar board to check for fit. I had a LOT of sanding ahead of me. The transom hung over the bottom ny a hair, the first frame was short of the edge and frames 2 and 3 hung over. I took my time sanding, fitting, more sanding, fitting and glued the plank on. Another lesson learned, pre plan the clamping! Slowly but surely, progress continues.
  10. Thank you Buck, will give it a try. Attached the strip on the transom, stern post I believe. I am trying to learn the appropriate terminology. The next steps have small blocks glued to a build board, the hull then pinned to blocks to create a slight curve. Looks like the planks are applied while still attached to build board. I really like to pick the model up and look at it from different angles while I fit various parts. I plan on spending a little time sorting out something else...probably attaching to a block of wood.
  11. Am very much looking forward to the planking, thanks for the heads up adjustments are normal. Will be hoping it will only be a few
  12. Hi Buck, Thank you! Do wish I had seen your post before I glued it on my own. Would have saved me a bit of time and a little frustration. Yes, did have it leaning side to side. Scrounged up a few small boxes and that set it up nicely.
  13. Thank you Mario, am having a good time with it. Spent a good amount of time shaping the stem today and quite happy with the way it turned out. Won't have much time for a few days to make much more progress, unfortunately.
  14. Augie, so sorry, autocorrect changed your name on me. Do appreciate your checking in.
