Everything posted by Erik W
Glenn. This looks superb! I like the display base too. Erik
- 840 replies
- winchelsea
- Syren Ship Model Company
This was a fun week. I finished the stern details. These included building the second seat, which I'm happy to say is close to identical to the first. I made the horse for the boom sheet out of 22 gauge annealed wire, with washers made from .062" diameter styrene rod with the center .028" drilled out for the wire. I cut and formed the transom knees, and glued those on. I then shaped and added the cleats. These I had bought from Chuck a long time ago. I see he currently offers cleats in 5mm, 7mm, and 9mm. I have 9mm and 6mm on hand. So for the cleats on the transom knees, I shortened the 6mm to 5mm, and used the 9mm and 6mm cleats in the other areas of the stern. I see in these enlarged photos a couple of spots that need touching up, but I'm otherwise happy with the way these details turned out. Erik
I did a variety of things over the last week. I built the jib outhaul block (shown in the painfully enlarged photo below . . . warts and all, haha). Mike (stuntflyer) has an excellent tutorial for that on his Cheerful build, so I followed that. I then made a card stock mock up of the starboard side seat. I used the card stock templates as a pattern to cut out the parts. As others have said this is a bit finicky. I have a feeling the second one will be more of a challenge as I try to get it to match the first. I spent some time this week reading ahead in Chuck's monograph chapters to get a list of the last little bits I need to finish the build. I ordered some Albion Alloys brass tube. I also messaged Chuck, Mike, and Glenn (glbarlow) with questions about the thread type/size/color they used with Chuck's scale rope for seizing and serving. Today I went on a region wide road trip to fly fishing shops and fabric stores. Most of my dark brown rope is Chuck's old style rope, other than the .012" new Ultra for rat lines (so I don't need thread for seizing or serving the brown Ultra rope). My tan rope is a mix of his old rope and the new Ultra rope. These tan colors are close enough in shade to mix on the model, but I wanted thread for seizing that matched each shade. The photos below are color corrected to be as close to accurate as I could possibly get the images. The Gutermann thread is for most serving and seizing. The smaller diameter UNI-Thread fly tying thread is for tiny serving and seizing. Here's what I came up with based on what I could find locally. Using with Syren old brown rope - Gutermann 50wt CA02776 Polyester thread Color 593 - UNI-Thread 72D 8/0W Dark Brown Using with Syren old tan rope - Gutermann 50wt CA02776 Polyester thread Color 512 - UNI-Thread 72D 8/0W Tan Using with Syren new Ultra tan rope - Gutermann 50wt CA02776 Polyester thread Color 509 - also UNI-Thread 72D 8/0W Tan Also, as Chuck had answered, the thread he uses for seizing and serving his new Ultra rope is as follows (I researched what actual size/diameter it is in wt and tex). Ultra Brown rope - Gutermann Mara 150 50wt/20Tex Color 682 or for smaller uses Mara 220 77wt/13Tex Ultra Tan rope - Gutermann Mara 150 50wt/20Tex Color 263 or for smaller uses Mara 220 77wt/13Tex This is hard to find in the US, so Chuck recommended this place: https://www.williamgee.co.uk/product-tag/mara/ Erik
As always, thanks for the likes. I do appreciate you all following along. After all the metal work of making the chain plates, backstay plates, eye bolts, and deadeye strops, I decided I'd work on a relatively straight forward sub assembly. I went ahead and installed the rudder, and gudgeons and pintels (I had shaped the rudder itself a couple of months ago). I used Chuck's mini kit for those. You have a choice in the mini kit of .010" thick paperboard material or .028" thick plywood. I opted for the thicker plywood and sanded it down to .018" thick. By my eye that's a good compromise. I used .020" diameter styrene rod for the bolts. Yes, yes, I know it's probably sacrilege among purists to use plastic on a wooden ship build. Haha. But since the bolt heads are covered in paint I chose the easier to cut and work with styrene rather than metal wire. Everything was painted with black paint and then once mounted I taped the simulated metal straps off and applied rust brown weathering powder. I haven't glued the rudder on yet. I'll do that at a later date after I drill the final hole to mount the tiller (I did drill a small pilot/locator hole though). That said, the rudder sits correctly straight and true with the pintels snugged down into the gudgeons. On a related note, I received the last few packages of blocks I'll need for the build, and a serving machine, from Chuck this week. If I'm inventorying correctly, I think that may be the last stuff I need to complete the build. Erik
I finished the deadeyes and deadeye strops this week. And set a new personal record for the most discarded/rejected parts. Haha. I can laugh now, but at the time, it was the height of frustration. I think to get the 8 usable deadeye strops shaped correctly and mounted, I wound up with an additional 15 or so I scrapped. Admittedly most of that was trying to get the first couple formed. Once I had a system down for shaping them, things went more smoothly. I wound up chipping the paint off some of the chain plates, so had to touch that up. And I wound up rubbing off the finish of the annealed wire I used for making the strops from handling too much, so had to blacken those again . . . which made a bit of a mess on the deadeyes from blackening smudges coming off of my fingers. So, I had to re-sand some of the deadeyes to remove that. All in all not the most fun part of the build. So, I'm happy that buttons up Chapter 9 of Chuck's monograph, and I look forward to getting away from handling metal and back to working with wood for the next parts of the build! Erik
After pulling some hair out, and the remainder going gray, haha, I have finished the backstay plates and chain plates . . . on the port side anyway. I revisited blackening them, using advice here and on the internet. My test brass strips looked OK, but I couldn't avoid bare brass spots being rubbed off after lightly wiping them down with a dry cloth. I'm pretty sure I didn't clean the brass well enough beforehand. After being left frustrated by that, I just went ahead and followed what Chuck had done on his, and painted them black and used a rust brown weathering powder to give them that iron look. I'm happy with the results. A trick I learned years ago as a model railroader with brass, is to bake the brass after painting. Just put the parts under a hot halogen or incandescence light bulb, about an inch away from the bulb, for about five minutes. This hardens the paint on the metal surface and makes it much more scuff resistant. The nails themselves I ordered from ModelExpo (being my first ship build I didn't have any extras from prior builds to use). They are the smallest ones they offer. They're slightly rounded on the bottom of the heads, so don't appear the sit flush when pushed in. So I used a larger diameter drill bit than the holes in the brass were drilled with, and counter sunk all the holes in the backstay and chain plates. I also ran a sharp angled file on the underside of the heads of each nail. This helped get the nails to snug down flat when pushed in. After getting the parts mounted and nailed in place, I went ahead and touched up the paint and weathering powder. Of all the processes involved on this build, metal working is probably the one I have the least experience in. The backstay plates and chain plates have taken a lot longer than I thought they would. That said, I've learned a lot, even with the error part of Trial and Error being frustrating at times! Erik
I had tested some blackening fluid on the brass I'm using and didn't really like the results. It rubbed off easily, and in general just seemed messy. Once I finish shaping all the brass chain plates I'll paint a strip of scrap brass black and play around with the weathering powders I have to see what finish I can come up with that I think looks good. Erik
With longer days, and warmer weather, progress has slowed down as my focus has shifted a bit to being outdoors more as spring arrives. I do still work on Cheerful daily though. I'm working on the chain plates. As with the backstay plates, I cut strips out of a 6" x 12" brass sheet. I then cut the 8 chain plates longer than needed. Next I shaped the tops of all 8. Being my first ship build, I had to do some research when I got to Chuck's instructions, "Assuming this isn't your first ship model, the angles for each chain plate were found in the usual way." Glenn (glbarlow) had some good photos in his Cheerful build log that show how to rig a temporary mast to get the desired chain plate angles. I made a jig to get the rake of the mast correct, when compared to the plans. Then I secured the mast in place with temporary fore and aft stays. The simulated shrouds are tied off at the correct height and spacing on the mast. Knowing the chain plates are not exactly the same length this process was key to do before I cut them to length and drilled the lower 2 holes on each chain plate. I have the port side chain plates finished more or less (they do still need a little tweaking). Each one is marked on the back for which position it belongs in. Erik
Glenn, As always, your work looks superb. I like the idea of airbrushing the cannons. As I approach that stage with my Cheerful build's cannonades/cannons, I think I may do the same. It seems a bit tedious to hand paint them all! Erik
- 840 replies
- winchelsea
Mike, I'm glad to see you're back at it! Your build was always one of my favorites. I have the Hahn book on Ships of the American Revolution, so have always had an interest in Hahn's designs. I too know the feeling of life getting in the way of my build. Back when I took what I thought would be a short break from my Cheerful build, I had no idea it would be 6 1/2 years before I started working on it again. When we're working on something that requires such precision and concentration, it's hard to have the energy a lot of times at the end of a full and busy day. That said, I've always had the saying, action breeds motivation. Sometimes if you can just find a little energy to sit down and start, the motivation follows. Erik
- 943 replies
- hahn
- oliver cromwell
One last photo for the week. I drilled the interior scupper holes. This was a bit nerve wracking. I hadn't anticipated how easy it would be for the 1/32" x 1/32" waterway strip to split while being drilled. I wound up starting with a much smaller drill bit and then using three more progressively larger sizes to only take a slight bit of material off at a time. I made sure to turn the pin vice really slowly. If the waterway split, the split part was still attached at one end. I took a sharpened toothpick, applied a tiny amount of wood glue, and glued the fragmented sliver back down. I had to do that with three of the holes. The splits are invisible. Glad I'm done with that part! Also, I'm not sure of the properties of wood in general, but I'm curious if my boxwood, which I've had for 9 years in an inside climate that has a humidity of around 25% most of the year, splits easier because of that. Erik
Thanks for the comments Glenn and Mike. My build is 100% boxwood. When I bought all the wood, and started the project back at the end of 2015, no one was really using Alaskan Yellow Cedar yet. As far as making the eye bolts, at least since I have a large amount of wire now, it's no big deal to discard the less-than-perfect ones as I get up to speed on how to make them. lol. Mike, I used a small round diamond file with the same technique you mention above. It seemed a pretty intuitive way to get the small notch filed from the hole. Erik
This week I decided to mix things up a bit, taking a break between making the backstay plates and the chain plates. I made the 22 eye bolts for the hull exterior and cap rail top. While I have every manner of small diameter wire - lead, brass, copper, phosphor bronze, steel - down to .002" diameter, I didn't have the type of wire best used by ship modelers for these types of things. So after some research on this forum I ordered both 24 and 22 gauge Hillman Group dark annealed wire. I must say, trying to make 22 identical eye bolts was more of a challenge than I thought it would be! I never did get to a point where they were consistent. That said, I selected groups that were close to identical to one another to fasten in the same area. I figure if the port side eye bolts are slightly different than the starboard, a viewer would never know since you only see one side of the ship at a time. I followed what Mike (Stuntflyer) had done in his Cheerful build log, and filed a little channel around the holes so the eye bolts snug down a bit. I also drilled the scupper holes in the outside of the hull. This was pretty straight forward, other than when I went to photograph the model I could see the bright wood on the inside of the bulwark. I wound up taking a fine brush and painting the interior black, followed by running a pencil around the plank edge of the hole. My next step will be to drill the scupper holes on the interior bulwark/deck area. Does anyone have any advice or wisdom on that? Am I drilling all the way through the interior planking? I know I need to make the holes so they notch into the lip of the waterway at deck level. Erik
Hey Allan, Thanks for the links to the McMaster site. I always appreciate good sources for materials. I did some testing with blackening the brass with Birchwood Casey blackening fluid on a scrap piece of brass. I'll most likely go with black paint and a weathering powder as Chuck did to give it that metal look. The copper/liver of sulfur you mentioned sounds intriguing. Erik
A little bit of progress this week. I'm new at metal working, so it took some trial and error to figure out how I am going to make the backstay plates and chain plates. One of the main issues to getting the ball rolling was figuring out how I was going to make these without the availability of 1/64" x 3/32" brass strip. It would appear that K & S has discontinued nearly its entire line of brass strip, and I couldn't locate any of the size I needed in my internet search. Many years ago I had bought a package of various sizes of 6" x 12" brass shim stock (used to shim the plates when molding parts in plastic injection molding machines so that they align correctly) just in case I ever needed sheet brass. These sheets came in thickness of .001", .0015", .002", .003", .004", .005", .006", .007", .008", .010", .012", and .015". The .015" thickness is the decimal measurement of 1/64". So I have my material. I used a pair of ancient tin snips I have in my toolbox to cut 3/32" wide strips off the sheet. I then had to flatten the strips since they curled both along the face and the edge. Next I filed the sharp edges flat. Then used flat pliers to eliminate the lengthwise cupping caused in cutting the strips off the sheet. Now that I had my self-made strips ready, I then shaped the backstay plates following Chuck's instructions in his monograph. Since the strips I created were rough and with blemishes, I polished the finished backstay plates with a fine file after shaping was complete, just because I'm a perfectionist, and that's how I roll! Yes, I know they'll be painted black. Haha. Erik
Glenn, you do good work. That looks awesome! Erik
- 840 replies
- winchelsea
Not a ton of progress this week. I did finish fashioning and installing the boarding ladders and channels though. I must say ripping the boards by hand out of sheet stock to make these parts is a bit of a pain in the rear. lol. Also, it was tough getting the pattern cut into the scraper to make the boarding ladder profile. I think my limitation there was my lack of precise small files. I deliberately made the filed notches in the channels that will house the chainplates narrower than they'll be. I just wanted to get the notches placed correctly and the angles in, according to the plans. I'll finish the notches up when I fit and attach the chainplates. And lastly, I'm patting myself on the back. My third photo below manages to capture the elusive and hard to photograph lower step of the Cheerful's boarding ladder (located on the wale and painted black). Haha! Erik
Though I feel like I didn't get much done on the Cheerful over the last week, I do feel a sense of accomplishment. After about 9 hours of work total, I finished both boom crutches. These are easily the most complicated shapes on the build so far. I read and reread Chuck's instructions on how to get the angles correct many times before I started. I formed the first boom crutch and glued it on and painted it before I started the second one. It probably would have made more sense to make the second one before I glued on and painted the first. Doing it the way I did made it harder to get them the same size and symmetrical to one another. I wound up spending some time sanding the first to get it to look like the second, after it was already glued into place. A delicate task, to say the least. At any rate I'm happy with how they turned out, more or less the correct angles and the same as one another. While carving/cutting these out of single pieces of wood, I couldn't help but think of the guy who carved this out of a single piece of Carrara marble 500 years ago: https://upload.wikimedia.org/wikipedia/commons/thumb/6/65/Pieta_de_Michelangelo_-_Vaticano.jpg/1024px-Pieta_de_Michelangelo_-_Vaticano.jpg Erik
Thanks for the kind words! Toni, as far as the photos go, your comment is worth an explanation of how I get my photos. I take the photos on my work space, which is pretty darn small. Especially for the last year or so since I've been working mostly from home (I'm a remotely working accountant for the National Center for Atmospheric Research). I threw in a photo of my work space too. Basically my work day, and hobby, all take place on different sides of my L-shaped desk. It means my commute from work to modeling at the end of my work day takes about one second. Haha. I have a large sheet of light blue construction paper for a photo background that I tape down to my work surface. For lighting, I always take the photos mid day in front of the window, which provides good area lighting, and use a halogen desk lamp with 700 lumen bulb as a spot light aligned with the lens of the camera. The camera I use is a 7 year old Olympus OM-D mirrorless camera with a 14-22mm lens mounted on my now 30 year old Gitzo tripod. I use the self timer so I'm not touching the camera when the shot is taken, this aids in crisp photos. For each shot I take a 3 photo bracket by 1/3 stops using aperture priority with an F stop of F22 (creates the greatest in-focus depth of field). The aspect ratio I prefer is 16:9 which gives a horizontal rectangle photo, rather than a square, so there is not too much dead space at the top and bottom of my photos. For size I select 1280 x 720. This is big enough to see details, but small enough to not use a lot of memory. Once I have all my photos I upload them into the Olympus photo software on my laptop. I delete 2 of the 3 photos taken in the bracket, selecting the one that is the best brightness wise. The only editing I do is making the crispness greater (not sure why the camera doesn't automatically do that itself with in-focus photos), and to get the boxwood to look the actual color/shade it is, I've been color correcting slightly by adding a small bit of blue hue and very slightly removing red hue. This has been an evolutionary process for me. I don't have any kind of formal training, and taking photos of something as large as Cheerful, the largest model I've ever built, has had it's own learning curve. I threw in a photo of my last ship build below, a 1/350 scale tugboat, for a comparison of the "normal" size I'm used to photographing! For me, presentation is a fun part of participating in forums, so I really strive to have good photo presentation for you wonderful folks! Hope this is useful for people. I encourage my fellow modelers here to play around with their photography. You'd be surprised at what you can come up with. Erik
As always, thanks for the likes folks. I finished a few different things over the last week. I spent time shaping the rudder. Using the plans I drew the lines that I would sand down to on the rudder faces and sides. Doing this gave me the visual cue to not over or under sand. Once the rudder was done I cut out the rudder port. I made a paper template from the plans that I used to get the shape correct. Next I made the top of the rudder post. This took way more time than it should have. I accidentally removed too much material from the laser cut piece. So I would up gluing on a chunk of scrap wood to that piece and then shaping the whole thing again. Sometimes it's the one little piece of wood that is the biggest pain! The last thing I did was shape the 6 timber heads. This was a bit nerve wracking as a newbie, but they turned out OK. The photo below shows the tools that wound up working best for me (as well as a rough cut timber head before clean up). For some reason, on any model I build, I'm most comfortable using either a #17 or #18 X-Acto chisel blade with no handle (rather than a #11 blade w/handle). I know it's weird, but it gives me more control by holding the blade directly. The overall height of the timber heads match the plans, but my angled faces are not as tall as the plans. No big deal really since all 6 look the same. The next thing I'll be working on is the boom crutches. Wish me luck! Haha. Erik
I spent the week building the windlass mini-kit. Hats off to Chuck for the engineering of this little thing! It goes together easily, with the biggest challenge being beveling the edges of the windlass faces. These didn't all turn out perfectly symmetrical, so I test fit the sub assemblies on the center strip in a bunch of different combinations. I settled on what looks symmetrical when viewed from the top, and put the best sides facing up. To get the windlass to snug down on the deck I taped a piece of sandpaper to a 1/16" thick wood sheet and then sanded each of the supports with one side on my cutting mat while the other side was being sanded on the 1/16" sheet with sandpaper. Since the deck is angled towards the scuppers from the center line, sanding the windlass support bottoms like this allows them both to sit flat on the angled deck. As far as getting the windlass positioned correctly on the deck in relation to where the bowsprit will go, I put a straight wooden dowel where the bowsprit will be and then marked the center line on the stern cap rail and top of the stem. I positioned a steel yardstick on the center line and adjusted the dowel parallel to that. Everything measured out and looked correct. The proof will be down the road on the build when I'm installing the bowsprit step and bowsprit though! Erik
