Garward
Everything posted by Garward
  1. The rubber pillow used at production of nails.
  2. The photo shows a needle with the minimum opening which is in the tool Valentin Shabanov.
  3. Here so we sharpen these needles. Coronary drills turn out.
  4. A little more expanded description of process of production of wooden nails on Alexander Dobrenko's (Woodeater) technology in a statement of the Russian modeller Valentin Shabanov http://forum.modelsworld.ru/topic1392start30.html. We buy here such needles of different diameter (internal).
  5. Here so the modeller of andys_2007 http://forum.modelsworld.ru/topic1392start30.html sharpens needles.
  6. As a result of searches something I found. Process of production of wooden nails in Alexander Dobrenko's (Woodeater) statement http://forum.modelsworld.ru/topic1392.html Wooden nails become specially ground needle from a syringe. Sharpening in the form of a crown of the king. After repeated lowering raising in the boring machine of this special drill it is necessary to cut off only a plate from an end face of preparation and to shake out some hundred ready nails!
  7. Hi, Tom! Unfortunately, directly I have no photo of this equipment, but I will look at Russian-speaking model forums. I remember that some photo was published.
  8. Hi, Janos, I completely support your comment concerning Unimat.
  9. No, here it wasn't used coloured putty. The plugs imitating nails, are made of wood by means of a needle for a medical syringe.
  10. Hi, Snowmans, first attempt looks good! And how sander paper on a drum fastens?
  11. Hi, Spiff, the correct decision, experience should be saved up. Needless to say that this model shouldn't be remade. The hull looks good.
  12. Hi, Spiff! I apologize, these are all "miracles" of the electronic translator. I wanted to tell that length of planks of a secondary planking of the hull is too small. It would be suitable for the deck, but not for the hull.
  13. Hi, Jingyang! This HMS "Pandora" in scale 1:48 http://www.shipmodels.com.ua/eng/models/elite/pandora/index.htm model russian master Narim Majgeldinov is constructed. Your 3D model looks perfectly!
