Wishmaster
Everything posted by Wishmaster
  1. Thank you There are many mistakes and lot of space for improvement but I'm very very satisfied and proud
  2. Great and beautiful model and top skills. I wish that option "like" is somehow unlimited so I can like many times most of pics of this beautiful model Real enjoy
  3. Hi Anja. Well I'm getting :DDDDD I put already front little sail only bigger sail is left to set. I need day or maybe two for that. Also I need to make stand for her. But problem is (actually I thank God for that ) that I have a lot of work. I'm full of work and can't organize myself to finish her. I also already started Chaloupe and I did make keel and also wooden mold on which it will be built which was quite big job. But chaloupe is also on hold Thanks!
  4. Thank you very much my friends. Here is continuation: Bracera is on temporary stand Beginning of construction:
  5. Impressive scale and impressive model Excellent craftsmanship Michael
  6. Continuation: Well i work a little and here is result how Bracera look now (black color and flax oil are aplied)
  7. I'm not sure that I understand you very well Toni. Are you saying about possibility of stains from ink after wet finish apply? If that so deck is already finished yesterday And also from beginning I'm aware of that possibility but I think that glue and ink are now solid mix and won't make problems with linen oil. We will see in next few days Cheers everyone and thanks my friends for interest, kind words and encouragement.
  8. Well i tried just a little sanding and here is result.
  9. Well I seen this method many times. But also Kevin you might have a right. Best option is to little sand this planks to see result ? I'm beginner so everything is possible. I can not ignore warnings from my older and experienced colleagues. Thanks
  10. Thanks Anja. Well I will take off (sand) about half mm of deck as planned to get nice surface. So it should be enough to take off this mess also ?
  11. Well somebody is on vacation and somebody works Continuation Works on deck. Its mix of ink and glue. It's very dirty but also fast and effective
  12. Thanks Alex. Yes I have a little extra time. And I'm waiting news from your build log?
  13. Tnx Anja. Right words Continuation Deck hatches and openings for anchor rope:
  14. Hello my friends, 1:15 could be also a right scale I found somewhere on internet that Tehnodidakta's bracera is 1:20.
  15. Continuation: Making planks for deck: Holes for water from deck: One hole is higher which will be seen better when I glue plank which is in line with deck. Well it isn't first mistake and won't be last I'm sure
  16. Thanks Anja and Bob. Well Anja about preparations for deck Well where l live you can't find some wood sheet thick about 0,5 mm or 1mm to glue them to frames and have nice surface for deck. So I made wood parts to fill big holes between frames and then I use a wood putty. So next is sanding and I think I will have fine surface for deck planks.
  17. Thank you friends for comments! continuation: Marked for cutting - improvised cargo bey Fine sanding of hull before paint will wait still because some more things must have be done before Little saw works well First cuted planks for improvised cargo bey Preparations for deck planking Next is sanding
  18. Stunning work! Museum quality. Thanks Edward for sharing this knowledge, tips and skills.
