MikeR
Everything posted by MikeR
  1. Last week I made a dozen of these small clamps out of 1/4" brass. I drilled and tapped the brass for a 6-32 X1 1/4 machine screw. I then cut small wooden blocks and drilled them to loosely fit the screw head and glued fine sandpaper to the other side.
  2. Hi Steve I tried to use .005 twisted copper wire for the shrouds on my DN iceboat but they keep breaking. I ended up using .005 stainless wire twisted together and they were much stronger. I had no problems after using them. Mike R
  3. Hello Ed I have been following your builds since the Victory and they are some of the best I have seen on this site. If this question has been answered before I do not remember. What do you use to clean the copper fittings after they have been installed on the ship, before you use liver of sulfur to blacken them? Mike R
  4. Jack They were pre-printed and bought at Michaels an Arts and Craft Store. Now I have to come up with a base to mount it on. Mike
  5. I added the decals to the sail and I ran into a problem , I broke the mast cables. I was using fine copper wire (.005) twisted together and it was breaking at the connection points were it was bent. Now the cables are made of .005 stainless piano wire twisted together and they are much stronger.
  6. I just found this picture from 1972 of my better half and me.
  7. Jack, I should of taken some pictures, but once I started making the sail I forgot. I used vellum drafting paper. I tried to find vellum paper that shows the linen weave but I could not find any. I drew out the sail on graft paper, I then folded the vellum in half so the seam will be the mast side. I use a glue stick to glue a .020 brass wire on the seam and also to attach the battens. I also reinforced the corners with piece of clear plastic. I then used a spray paper adhesive to glue the 2 sides together. For the bottom of the sail I folded a strip of paper and glued a .020 wire on it then attached it to the sail. I then laid the mast over and ran the sail up the slot in the mast. Then the same thing for the boom. All I need now is get a few decals for the sail.
  8. Thank you all for the comments and it was Jacks ice yacht that gave me the idea to build this. I am using a gun stock refinishing oil for the iceboat. This is after three coats. The sail that will be used. The Bluenose in the back ground that I am working on the rigging while the oil dries.
  9. Jack, I am thinking on installing a sail. John, This was the second time I'm making the metal works. The first was full size and now a much reduced size. Mike
  10. Thanks Jack, it was one of my first attempts at silver soldering. Here ar
  11. I'm also making 6 small metal blocks.
  12. For the last week or so I have been working on the metal items for the iceboat.
  13. The runner plank is made up of two pieces of wood glued together with the proper arc. Next I am gluing on the grab rails.
  14. Jack, I sold the iceboat years ago. Back in the 70's and early 80's we had a lot of snow covered ice. The only time I got to use it was at the end of winter when the snow was melted off the ice. Which left only a week or two of good sailing ice before open water. Being young and crazy we would use a plank from shore to the ice over open water for the last sailing day of the year. I used walnut for the base and sides, the deck and the cockpit is dogwood with a bloodwood stripe
  15. The previous picture shows some of the internal framing. I will attempt to build this model just like the boat I built 45 years ago. Boy time flies. Mike R
  16. Too easily convert the dimensions from the plan drawings I developed the following chart.
  17. In the early 1970's I built a DN class Iceboat that I sailed on Lake Arthur in Moraine State Park which is located in western Pennsylvania. I am now building one at a reduced scale of 1 1/4 in. to 1 ft or 1 : 9.6 scale. The plans that I used are from the International DN Ice Yacht Association. I am using walnut, bloodwood, and dogwood for construction of the model.
  18. Outstanding sails I have one question. How is the rope attached to the edge of the sails? Mike R
  19. Check out this site. They have micro drill bits with 3/32 shanks Mike R http://www.contenti.com/products/drills/200-089-005.html
