shipcarpenter
Everything posted by shipcarpenter
  1. hello marktime.Yes, hatch hinges are attached to a bent nail in the central timber. They can be opened both wings. Under the hatch cover is placed the lamp that illuminates the underdeck.
  2. Hello, thanks Marktime for looking, I am only carpenter . I made some paper models as a young boy but now I am making my first wooden ship and I really enjoy it. Following pictures show my little progress in last days.
  3. Hallo, some progress has done and I have already a little time for update. I am working on quarterdeck and Captain's kabin.
  4. Hello teacher, I am watching your hands... Nice to see your build log again. I am building the same ship and this is the really inspiration for me. What system you have used for lighting?
  5. Hello thanks Tim and santa maria's builder! mkmossop - I did not polished those parts, I only blackened them with some chemical lotion I bought in our gun shop. Small scratches disappear. I think it is not ideal blackwash, but I am satisfied with result - meanwhile. Same way I used to cannons. And then a little varnish... Tim - you did very fine work on your ship. Work on model goes slowly, but you know - it is relax.
  6. Hi, very nice, everything harmonized together. My next build will be Endeavour so I´m now learning from you. Thanks shipcarpenter
  7. Thanks Nigel, Tim and Matti for comments! Work goes on. I finished all 6 cannons a the rudder. Starting with deck furniture and fittings. I´m workin on hatches, binnacle and windlass.
  8. Hello Tom, very nice and very handy clamps. I´m also working with them but this adjustment I did not know. Thanks. I am looking forward to your progress. shipcarpenter
  9. Hi, thanks David for your kind words. Now shipcarpenter becomes a blacksmith and silversmith. I have to produce 1pin for rudder hinges. There were only 3 pieces in the kit, but I need 4 for my improved rudder. I made it from brass tube and wire. Soldering with gas solder using liquid solder for brass. I enyoyed it - maybe I mistook my craft. Last foto shows the infernal tool compared with lighter.
  10. Hi , Thank you Ian, I saw your Unicorn and I like it very much. I made some progress on cannons and with rudder.
  11. Hello, Thanks! I have some more pictures. Work is going on. I painted the deck with oak danish oil. Nails stand out. Working on upper deck beams. I also made holes for cannons.
  12. Hull was stained with water-based stain. I didn´t like the metal stocks for cannnos from kit so I made my own. Material sapeli 2x6mm and brass 0,25mm. Treenailing of main deck. I made holes 0,4mm and filled them with dark putty, then sanding. Inner bulwark timbers.
  13. Test of masts after strengthening false keel. Deck planking,material - ramin 1x4mm, edges blackened with pencil hardness 7B .
  14. Hi, thanks for the welcome . Next pictures show how I modified underdeck. I have installed 2 lamps there.
  15. Sanding, filling with putty, sanding and sanding again, second layer of planking,sanding, filling with darker putty, sanding. Material sapeli 0,5x4mm. Veneer on keel mahagony 0,5mm.
  16. Hi all! I am new on this forum same as by historic ship models. I have learned many things from MSW 1 so I would like to share my first build with you. After lot of time spended on explore what I really want I started with Santa Maria in September 2012. This is a beginning of the story in pictures. Ships are arriving from Spain. Packaging. Content of the box. First steps.
