Posts posted by hervie
David, Most likely tape, although i have a nice roll of thin copper I found in a scrap business around here. I did use it on a larger scale model using contact cement for every plate, very time consuming. Tape will be faster.
reklein, thanks for the suggestion. I did not see a reference to sealer in Chuck’s instructions but it is something to consider.- EJ_L, FriedClams and Ryland Craze
- 3
EJ_L, thanks for the comment and encouragement. I like to think of myself as a finisher, although sometimes with this model I have some doubts, not because of the monotony of particular tasks, but because I don't think I'm doing a very good job. My goal is to finish the stern, internal planking, coppering and deck. After that I'll reevaluate whether it's worth continuing, or just starting again from scratch.
Gary, thanks for the heads up and advice, and for keeping an eye on my build. I sort of figured up there could be no difference in plank elevation before coppering, and your advice confirms that. Thanks also for letting me know there's sufficient copper in the kit to experiment. -
End of Planking
Phew! I’m done.
My patience and enthusiasm was severely tested with this planking job. I’m not sure I passed.
Approaching the end of the job it became obvious I would have to fit a few odd shaped planks.
Thank goodness for coppering to camouflage all this.
The stern was particularly troublesome.Macro photos are very unforgiving, yet the reality was even worse!
The width of the planks at the bow became smaller and smaller. Looks like my tapering skills are not up to par yet.
And the stern! Well, no comment ...
Eventually, with lots of sanding and some filler it became this.
I wonder if the copper plates adhesive will bond to wood filler …
Back on the saddle. View from the front.
and the back.
The moral of this story is that with enough elbow grease even ugly ducklings can turn into swans … or almost.
- FriedClams, Ryland Craze, captgino and 7 others
- 10
EJ_L, Thomas, thanks. And thanks for the likes.
I just received the kit for the paper model Alstertor. Nice but way too complicated for a first paper model! The instructions being mostly in German doesn't help, nor does the very small size of many parts. So it goes to the back burner , and I'll be looking for a simpler one.
Till then it's back to the Syren with renewed enthusiasm!
Addendum. Actually on closer inspection, the instructions are quite clear and the project now seems doable. So it goes back to the front burner along with the Syren.
The key will be to practice complicated assemblies on separate paper first.
- Ryland Craze and EJ_L
- 2
Planking Progress … sort of
It is definitely slow going. Here are some pictures.
First the gardboard.
Then more top and bottom planks. While there was no tapering of the planks, and more empty space between them, I could work on 4 planks at a time.
Eventually it got slower. Just two planks at a time.
To do two planks takes one hour (excluding drying time). Each plank requires 10 steps
step 1: taper the plank for the bow section.
step 2: position the plank on the hull and insert the pins (see below)
step 3: mark the section of the plank for bending at the stern
step 4: remove the pins and the plank.
step 5: bend the plank at the stern
step 7: dry fit the bended part at the stern, Trim the plank.
step 8: remove the plank and pins one more time..
step 9: put glue on the hull for the entire length of the plank.
step 10: glue the plank and reinsert the pins to hold it in place while drying
fun fun fun
Positioning each pins starts by marking the spot on the hull with an awl. Best way is to rest the awl on the dry fitted new plank and mark the spot a small distance from it in a way that most of the pin will cover the plank.Then drill with a #58 bit and insert the pin.
Here is marking where to bend the plank at the stern making sure the final position of the plank will remain the same.Bending with the method described in the previous postOnce the entire stern counter was covered, all planks were trimmed using a Dremel saw bit.As more planks are inserted the torsion stress on the planks at the bow becomes more serious. After pinning and dry fitting the planks they are moistened with a spray bottle and left to dry.And that’s it for planking. My next post will show the final result.So much for the Syren. But now it has some company in the form of a card model which I am about to start.Thanks to Mirabell61's mention of card models in his log I discovered a whole new world of modeling i did not know existed! Paper (or card) modeling. So I’ve done some research last week and came upon this site in Germany.
Apparently countries in Eastern Europe have evolved paper modeling to a level unmatched in the west.I’ve always wanted to build a mid century cargo ship. So I couldn’t resist and ordered one of the last conventional or classical freight ships before the emergence of container ships, the Sloman Alstertor.
http://h-m-v.de/sloman_alstertor.0.html?&L=1
This kit has 1600 parts! It will slow down the Syren, I know, but I need some faster action every so often
If it works, there is a whole world of card models to discover.
- reklein, Ryland Craze, EJ_L and 6 others
- 9
Beautiful work, Nils. As always.
Coincidentally I run into some historical references to the Grosse which might be of interest:
April,1897
"The world was growing more chaotic and speeding up. Rudyard Kipling could be spotted in his six-horsepower motorcar thundering around at fifteen miles an hour. The race among the great shipping companies to see whose liners could cross the Atlantic in the shortest time intensified and grew more and more costly as the size and speed of each ship increased and as the rivalry between British and German lines became freighted with an ever-heavier cargo of national pride. In April 1897 at the Vulcan shipyard in Stettin, Germany, thousands of workers raced to prepare the largest, grandest, fastest oceanliner yet for its launch on May 4, when it would join the stable of ships owned by North German Lloyd Line. Everything about this new liner breathed Germany’s aspiration to become a world power, especially its name, Kaiser Wilhelm der Grosse, and its decor, which featured life-size portraits of its namesake and of Bismarck and Field Marshal Helmuth von Moltke. The launch was to be overseen by Kaiser Wilhelm II himself.""Thunderstruck, by Erik Larson, Broadway Books, 2006"I am reading your entire log from page one to get an idea of what's involved in building this type of ship from scratch. It is definitely a project beyond my capabilities ... but maybe one day ,- Piet, captainbob, Martin W and 5 others
- 8
EJ-L, thanks for the word of caution. I will be tapering, and the manual has a description on how to to that for this ship. Sal’s log (_SalD_) applies Chucks' method to the letter, jet, even then, could not prevent some plank “creep” from happening.
Since the hull will be coppered below the water line, I’m not too concerned about this. I am more interested in producing a smooth surface for coppering, so it’s OK if I end up with a few odd shaped planks here and there. (This must sound as sacrilege to some builders, I know). -
Bending and Gluing Planks
The first plank below the wales begins to get into the extreme curve of the stern. Here I practiced a method for bending planks using two specialized tools I bought years ago. These are shown in a photo below.
To practice, on a spare plank I produced several close notches using the first plank bending tool. One side of the tool jaw is flat, the other has a dull blade. Using this tool by itself would be sufficient to produce gentle curves.
The key for good results with this tool is to do close, evenly spaced and fairly deep notches.
In preparation before using the second tool, a hot iron, some drops of water were placed on the notched part.
Then the iron is used to produce the sharp curve..
The result. Obviously I need more practice.
Now for the real thing..First, the filler blocks under the stern were reshaped to produce a smoother curve.
Previously a few planks were pre-formed in the plank bender jig used before. That takes care of the plank's bow section.
A plank was temporarily attached to the hull, and the spot where the plank needs to be bent at the stern was marked.
Then the plank was removed to make the stern curve.
Here is the result.
Now the plank can be glued to the hull, first the bow section using CA glue, then the rest using PVA glue.I decided to switch back to PVA glue. The CA glue fumes are to obnoxious for me, whereas PVA produces no toxic fumes.That means I had to get a method of securing the planks to the hull while the PVA glue is drying.
After trying a few methods, I settled on one using push pins.
The biggest problem when using push pins is that they need to be pinned to the bulkheads, and the bulkheads are too hard to penetrate. Pre-drilling solves the problem.
First the spot for the push pin was marked using a sharp tool to facilitate placing the drill bit.
Then the hole was drilled. (the plank is not glued at this point).and the push pin inserted.Here are a few push pins in place. I can see the next time around I’ll need to drill the holes closer to the plank. But it will work.I like this method because it can be used for all planks regardless of where they are.
Having settled on this method of planking will helps for the rest of the planking job. However progress will be slow for a while due to some software projects I’m involved with. Hopefully I’ll be back soon with more progress to report.
- _SalD_, Elijah, FriedClams and 4 others
- 7
Signs of life …
It’s been a while. Progress is slow due to other things occupying my time, but chugging along nevertheless.
At this point I decided that is was time to glue the stern to avoid potential trouble with planking. I would have liked to plank the stern and work on the transom before attaching the assembly, but better not.
As it turned out, despite careful measuring and fitting, the rear side planks did not exactly line up with the sides of the stern. So I had to insert some shimming (?).
Then I could glue the side planks.
Now I could begin doing the wales. I’m still trying to find a good way to hold the planks while drying. The one shown in the picture does not work very well.
I decided at this point to switch from PVA to CA for the remaining of the planking task.
After gluing all seven 1/8 planks and the first layer of wales, I turned my attention to the stern. This is the area I anticipate trouble due to the extreme bending of the planks required. Not quite sure how to progress yet.
One final note for this post. I am keeping a log of the hours spent on the Syren, excluding logging. I’m using an iPhone app called ‘Event Logger’. It shows that I started building on June 15 and that I spent about 140 hours total — which is the time it took to build the ENTIRE Bluenose model shown below!
Of course these models are not comparable, and actually I don’t mind it if building the Syren takes a long time. I like this ship.
- FriedClams, Elijah, Ryland Craze and 3 others
- 6
That's pretty funny EJ_L.
Actually the fix looks a lot better in real life than in the photo which magnifies the scratches and bumps. So I'm moving on.
- FriedClams, Elijah and EJ_L
- 3
Fixing the bow, first pass
The objective is to use filler to cover the previous mistake, then draw fake planks and repaint.
Here is the rough filler in place.
Using a flexible straight edge and a pointy tool, I ‘drew’ the first plank.
More planks drawn.
End result after painting
Before it was:
This is the first pass. Not sure if it is OK.
What is sure is that I no longer have a good side and a bad side. Now I have two bad sides
It is possible that with the timber heads in place this will be acceptable. We'll see.- EJ_L and FriedClams
- 2
Thank you EJ_L, Thomas, ca,shipwright.
Yes, the rabbet around the gun ports almost became a show stopper for me. I'm still not done with them, I have to paint the edges of the planks and touch up the red.
Ca.shipwright, I agree. That was the first thing I noticed in the photo. I took great care in selecting equal width plank, so maybe this is a photo shadow effect.
I'm about to post the results after using filler to correct the problem.
- FriedClams and EJ_L
- 2
Thanks for trying to make me feel less dumb E_JL. I know I can always count on words of encouragement from you.
Yes, some of the planks are painted. I tried different painting approaches. It is not a workable idea to prepaint all planks at this point, the paint will rub off upon sanding. But it doesn't hurt.Nevertheless before installing the wales and sheer strake (which will be prepainted black), all the other planks will be painted. Just the first coat to produce a clear delineation between the two different colors used (ochre and black)By the way, the fact that I am going to use paint instead stain allows trying approach number two above, as my next post will show. -
Continuing with planking …
At this point I have the port side completed to the 7th strake (not shown), and starting on the starboard side. Compared with the other side I noticed right away there is a difference in how the ports and sweeps align with the 2nd strake. Not a good omen, but I chose to ignore it for the time being — big mistake!.
I stopped using the table saw to cut the plank segments and am now using a plain cutter.
When the 5th strake was reached I used the pen sander to straighten the sides of the gun ports. It worked well.Then I temporarily attached the 6th strake to mark the upper edges of the gun ports.Using the table saw method described earlier (page 3, post 56), I cut the notches for the gun ports and glued the 6th and 7th strake.
Then, finally, I compared both sides of the bow and nearly fainted!
Terrible!
I did the most basic error of not working on both sides at the same time, plank by plank. And then I compounded the error by not checking both sides as I went along.
At this point I have three choices:1) throw the ship on the ground and stomp on it. (Tempting!)
2) try to fix thing with wood filler and paint.
3) deconstruct and start from scratch.
To be continued ...
This is going to be an interesting project ... Best of luck.
Cutting the rabbet around the sweeps
I hesitate in posting these pictures because the result is still not good. But the method is. So here it is:
1) Cut a piece of plank longer than required, and mark the area to be notched for the sweep.
2) using a #11 blade, pierce straight down both ends of the notch. Make sure the blade tip goes though the entire plank.
3) Turn over the plank and repeat the above step using the previous cut location as guide. (That’s why it’s important to pierce the entire plank in step 2)
4) finish cutting the notch edges. It should be easy now.
5) with a chisel or a #11 blade cut the upper edge.
6) clean up with files.
7) mark the ‘real’ plank segment length
8) trim and installStill rough, but I guess with practice it will get better.There definitely will be a good and bad side to this ship. Unfortunately I started on the port side which it is my favorite side for display.
EJ_L, ca.shipwright, thanks for the encouragement. And for the advice. It comes at the right time since I'm beginning to doubt my ability to finish this ship, let alone the hull. . What bothers me is not how long Planking takes, but that I'm doing a lousy job.
We'll see how the job ends after I have a chance to mask the errors with files, wood filler and paint. If I cannot make the rabbet edges straight, I may just tear the whole thing -- with great satisfaction! -- and start all over again.My next post illustrates the method for cutting the rabbet edges I settled on. Looks similar to what you guys do.Thanks again.
US Brig Syren by hervie - Model Shipways - Scale 1:64
The wales
Gluing the wales was routine. Here are some pictures.
