aliluke
Posts posted by aliluke
  1. That planking is looking really good vths. I'm also looking back in your log and admiring the deck planking work too. Just being in this phase makes me realise what a fine job you did on that. I never contemplated tapering the deck planks towards the aft - as good as that looks - it is hard enough just to cut them square and to length!! Impressive work by you.
    Cheers
    Alistair
  2. Hi Mick
    The main keel should definitely be painted white with the hull. Below is a link to my model of the AVS (I still haven't figured out to link it through my signature....) You can see the effect. Work out a painting sequence allowing for the addition of the strakes and other bits. Painting requires as much patience and thought as all parts and while you'll have to do touch-ups as you go you want to get the sequence right in the first place. I haven't done the Endeavour and urge you to look at the other logs for it and look at the approaches to the sequence. You've got the hull sorted out - take your time and make the rest really sweet!
    For masking I'd suggest Tamiya masking tape. I know that lots of others here use it. Properly applied it has no bleed.
    Take your time and enjoy.
    http://modelshipworld.com/index.php?/topic/392-armed-virginia-sloop-by-aliluke-model-shipways-148/page-1
    Cheers
    Alistair
  3. Hi Mick
    I didn't understand your question until I realised, from the later photos that this was your third layer of planks. You have probably spotted the issue but you have to much space midships for planks compared to the bow and, particularly, the stern. The area looks like a lens in shape with a wide centre and points at both ends. I don't think this is going to go away whichever direction you head in. The "lens" will get smaller but it will not go away. It means you'll be bringing planks to finish as points. This isn't correct.
    I wouldn't despair however. My advice is:
    - Finish your planking as best you can and with regard to making it symmetrical - port/starboard - at best.
    - Fill and sand the hull below the waterline until it is smooth as a baby's bum.
    - Paint the hull below the waterline (this is no shame and it looks good too!).
    I've never built Endeavour but have tackled a hull as difficult if not worse - The Dutch Whaler by Sergal. My planking of this is totally wrong but I had no idea at the time and no internet and no other leads. However it worked in the end. The trick, I think, is you have to get some upward sweep of the planks fairly early on instead of running the planks parallel. The upward sweep gets rid of the consequence you are now facing. I'd post some pictures here but I don't think they'd be useful.
    My thoughts.
    Cheers
    Alistair
  4. Hi Mick
    You'll get there! The most important aspect of your effort is that your difficult hull now has the correct shape. Please don't take this the wrong way but your lower planking set out is a bit eccentric. The upper works look great though. I'd  suggest a painted - aged white - lower hull to the waterline. This is consistent with how the Endeavour was finished. Just my thoughts...
    Cheers
    Alistair
  5. Hi Steve
    I used blackened jewellery wire for my hooks. It is very soft but holds the tackles to the eyebolts just fine. It goes down to very thin gauges and is very cheap. I've got 2mm blocks for my Fly model - 1:64 - but I agree that even if they look right they are ridiculously small to try to work with. I might have a go, they came as a part of the upgrade kit, but will probably settle for 3mm blocks too. The AVS cannons even at 1:48 are smaller than the Fly cannons and 3mm blocks worked out fine for them. I also bought different cannons for the Fly about a year ago but wish I'd waited for Chuck to come out with his. They look much better...maybe I will indulge...
    Look forward to your updates - it is very nice work that you are doing.
    Cheers
    Alistair
  6. I think you are in really good shape Mick. The upper works are the most important, being the most visible and unlikely to be covered with anything but paint. Depending on how you finish the lower hull - painted or coppered, the lower planking can be a little more loose. Best thing is your hull shape looks great - well founded and that is what really counts.
    Cheers
    Alistair
  7. Hi Danny
    Although I think I've seen it before (MSW1 versus MSW2 - will do this to you) I was just alerted again to your Vulture project. I'm just starting on the kit Amati Fly - a poor cousin- and would like to thank you for the enormous wealth of information that your build provides for these ships. Just incredible - knowledge plus skill. Beautifully made! I'm going to start back at page 1 and just look and learn...
    Cheers,
    Alistair
