Everything posted by Ondras71
Roter Löwe 1597 by Ondras71
Ondras71 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Thank you very much Backer!! I'm starting with the diamonds on the front wall, I want to find out what they will look like .. Preparing for the green .. -
Thanks for the like.. Two days spraying colored strips..💣💥 Unmasked, a few places to repair, but satisfaction.. Now I have the most demanding belt with blue and green cubes waiting for me.. O. -
Airbrush painting
Ondras71 replied to Keithbrad80's topic in Painting, finishing and weathering products and techniques
Greetings. I'm just starting an airbrush for a wooden model, I've studied model fibers, especially for plastic models, there's a lot of information. The finding is that it suits everyone and everyone recommends something different, it is important to buy and try and try until you get used to it. After a few experiments with acrylic paints, I am satisfied with the result, the brush never again .. Good luck!! Ondras -
I have already finished the white one, a lot of layers were needed for the dark wood. But the result is beyond my expectations..💥 Another question, on the German plan from the book "Risse von Schiffen des 16./17. Jahrhunderts " and on my Czech adaptation, is a different shape of geometric shapes. But the Czech one has a simpler square one, so I'll probably use it..😇 -
Thank you very much and I really appreciate your words friends.. Knee of the head hips reinforced against twisting.. Made a spray box 1 meter wide from a paper box and discarded kitchen hoods .. After training outside the boat, I start spraying ..💣 -
Thank you very much Boxbuilds and Louie!! I continue to produce parts that will be painted.. And I'm already training dry with an airbrush.. -
Thank you very much Boxbuilds!! Thanks to new information on the construction of Dutch ships, the Knee of the head was repaired.. and Beams shaped.. -
Thanks for the like.. Due to the need for dyeing and the need to create all the parts that will be dyed, I started making Knee of the head. I studied the construction of Knee of the head, it is nicely covered in the Czech thread by Doris Obručová for its construction Sovereign of the Seas .. https://www.modelforum.cz/viewtopic.php?f=177&t=43575&p=882705&hilit=klounová+paluba#p882705 A study of Dutch ships, I found that the grate of the deck drawn from the folded slats is from a later time, historically more faithful is the grate of longitudinal planks, as in the plan of the Pinas Vitsen by Ab Hoving. Production of Knee of the head.. Delivered paints and accessories to the airbrush.. -
Surrounded and waxed. The pins finally hold the wax-glued parts firmly.. I'm starting to make railings .. Waxed gratings of the main deck .. -
Thank you very much Backer, it's a compliment from you..🧐 Machined vertical beams glued to the supporting part .. The front pillars, where the head will be carved, gave the most work.. I also have beams ready for the first carving test.. As a basis for the head, I used a drawing from Derfflinger's plan, RL is unusable.. Test whether pattex adhesive sticks to the waxed surface - OK! Simple beams glued. Pins and wax are waiting.. -
Thank you very much Louie da fly and FriedClams. I try to be hard on myself ..🧐 I started making vertical beams that protect the side when launching boats. Base milled, but precise grooves created by the files .. Installation of klinkbout on the sides.. -
Thank you for supporting Mustafa. Thanks for the like!! Front deck pins.. Preparation of the aft deck.. -
Thank you very much Steven and Bossman!! I appreciate the favor of you all. Front gratings and front mast holder.. Deck boards will follow .. -
Thank you very much Chuck, Patrick and Tom!! Continuation of gratings. Absolutely accurate system.. Preparation of deck beams for forecastle.. -
The whole hull waxed outside.. I'm making new gratings for the front deck. I tried a new style of production with a 1 mm cutter on one side, it works and it's more accurate than a saw.. Comparison with old gratings.. -
Thank you very much archjofo and Sea Hoss.. Front body wall .. Medical needle 0.7 mm made pins 0.5 mm .. Stairs worked glued temporarily with glue..
