rwiederrich
  1. While I was at it I held the Staghound figurehead up for eval. It’s a little small cuz it’s behind the cutwater….. under the soon to be hood
  2. Did some corrections to the cutwater and the keel. Here is a close up of the stem.
  3. I gathered that as well. I'm in the ball park then. Just asking. Plotting out the main rail cap and the 16" monkey rail. Inside will be the waterways and planksheer. I'll place the cap rail first, then the exterior planksheer. The Navel hood will go on first before that install. But before all that....I still need to finalize the stern. Rob
  4. Yep...it is 3ft...or 2.5 scale ft. Does that number include the *false* keel as well? Rob
  5. After the keel I worked more on sanding and finalizing the stem and cutwater. Rob
  6. Thanks for all the input Rich...and from everyone else who has contributed to the lively exchange as of late. I'll spend some time today finalizing the shape of the bow and stern...probably more filling and sanding. I'll, then primer the hull to expose further inconsistencies, that will most likely require filling and sanding. Once all that is done, and I'm satisfied......I'll affix the stem/cutwater and keel to include the stern post. I move fast...but not too fast. I want this as correct as I can manage. Monkey rail will come after I lay the sub floors for the decking. Rob
  7. Don’t let the discolored wood trip you up. It looks weird, but the hull is getting smoother by the day. Worked on the stern reduction and the stem/cutwater. She still needs her monkey rail,(later). I still have to reduce the prow by 1/2”…….cutting it in so it buts smoothly against the bowsprit. Still oodles to do, but getting there. A bit more filling and sanding……then the addition of the stern post, keel and stem/cutwater.
  8. Maybe you ought to just draw it out for me Rich. I'm not seeing what you are describing. Just a side not: I will be cutting back the stern a good amount....making it more elliptical. Rob
  9. So..is the stern post measured with an external or internal rake? And if so, is the fantail measurement of 7ft, measured from the internal or external rake of the stem. Forgive my crude drawing...but as you can see....the post is identified as vertical or with an internal and external rake. The red lines represent the internal limits the fantail is measured from. Rob
  10. Being considered, by some, McKay's only true *Extreme* design. Staghound, was indeed a sleek model. Compared to the more robust design of his last clipper....Glory of the Seas. During this finalizing time of her hull creation....I'm relying heavily upon the images of her Cornelius half model...to bring her into compliance, as best as I can. Noting one slight issue I have found...between the McLean description and the Cornelius half model. It is the 7ft overhang of her aft poop. The model depicts this measurement slightly longer than the description.....requiring some creative decision making. She was 5ft taller forward then aft, as well...so this needs to accounted for in the sheer of her rail. Currently, I am cutting in her stem and cutwater....this can be tricky. Following the Cornelius model as best I can and still incorporating the McKay *hood*. Rob
  11. It was typical to make the 1/4” to 1ft half model , then loft from it the scale frames. The designer designed the model…. Then made the full scale frames on the lofting floor. Rob
  12. I’ve installed the base for the stern. Lots of carving and woodwork due here. I also dry fit the forward keel to get some measurements. Rob
  13. The bow will be cut back slightly. I over extended it to assure the proper insertion of the stem and cut water. Rob
