rwiederrich
  1. Next I use my dental tool and separator disk and cut off two end corners. This will create the desired shape of the block.
  2. We’ll here is my tutorial on how I make my 1/8” gin blocks. First I begin with 1/8” copper tube.
  3. Thanks Rick. Tomorrow I’ll show exactly how I make one. It’s quite easy actually. The real trick is knowing how to force the perspective of its function. You see, for a chain to properly fit in and around the sheeve, the body frame of the block must be large enough. However, if the sheeve is too large the chain binds between the sheeve and the frame of the block To prevent this from happening and to keep the block frame within the desired scale of 1/8”, you have to undersize the sheeve. The chain I use is the smallest available at 42LPI and it still needs room to move within the block. A true scale gin block is probably less then 3/32”. in this scale of 1/96. No one can make them that small and not go mad. Bluejacket doesn’t even use iron stropped gin blocks on their Red Jacket clipper model. Just large single blocks without a truck strong back tied to yard bands. So I have a ways to go. I’d like to see your gin blocks. Rob
  4. I definitely have to work over my towel in my desk drawer to keep from losing them, when they eventually slip from my fingers. Thanks for looking in. Rob
  5. Finished up 5 more gin blocks. That makes six. Still need 10 or so more. Painted them and still need to clean them up and finish them off. It only takes about 35 minutes a piece. A little hammering, 3 cuts, one soldering of the eyelet, micro internal grinding, place the sheeve and TaDa…… Rob
  6. Goodness John, I'm just now getting a good look at your restoration log. Very fine work and refurbishment indeed. What a task for sure. As usual,......research, research, research. Very impressive endeavor.. Rob
  7. I began soldering the next one. Final grinding is next. Rob
  8. I’m beginning to build the first of many gin blocks. Here are some pics of construction. They are less then 1/8” wide. Tony boogers. Coper soldered and with metal sheeves. Rob
  9. A bit more research shows that the Staghound was larger than the Flying fish. 17 Ft longer and 29 tons heavier. Duncan McLean says the Fish employed *double topsail yard Tye's and haulyards. Well, the Staghound had 4ft longer main topsail yards then did the Flying Fish. However, Duncan McLean doesn't describe the Staghound having *double* Tye's and haulyards. He simply says, "Tye's and haulyards. I can only assume he wasn't that clear when describing his first McKay clipper. As far as her rigging was concerned. If the Flying Fish had them...and she was smaller in every regard....I can only conclude the Staghound employed them as well. Rob
  10. Rick, I was reviewing your log *again*, Well, first of all, I want to say you have done a superb job for sure...your build is so clean and neat...not to mention well built. You're like myself in that you tend to scratch build many components yourself..🙂...Oh wait....I scratch build everything.......😄 Anyway. have you researched the single topsail Jin block haulyard...yourself, or are you simply following the kit plan? I ask....because the Staghound also had a single topsail yard and, I will be rigging her in similar fashion....but I want to make sure the system you used is the same used for Staghound...or if different, I want to make sure I know this in advance. Rob
  11. Started on the helm steering box. First coat of paint....still needs sanding and another coat....plus the addition of the wheel. Rob
  12. Johnny …….we literally are. Rich typically makes deck and profile drawings of our projects….based off of Duncan McLean’s eyewitness accounts. The hull plans can be mass produced if one were desirous. Rob
  13. Thanks Glen. I try. Now onto the helm tiller box and wheel. Rob
  14. Thanks Pat. I’m hoping to make all the deck furniture before I get the hull bulkheads from Vlad. Next will be the helm tiller box and wheel. Rob
  15. Finally I built the final one that will be mounted after it dries. Rob
  16. Here is the first one I built. Didn’t like it either. Rob
  17. HI Luis. Thanks...Vlad is waiting for the laser cutting to be completed...before he sends me my copy of the hull bulkheads and keel. I'm hopeful, that they will arrive before the end of next month...hopefully sooner. Rob
