Mike told me her demise was not salt water worm and growth infiltration, but dry rot, that she obtained by being laid up in semi fresh water and she survived so long , because of her additions of deck houses , the continual rain in the Pacific North West could not stand freely on her decks and work down to her holds. So her cannery housing actually protected her. And that is not the Dashing Wave…..it’s the Packard.
- 3,560 replies
- clipper
- hull model
Did some more research and found from Michael Mjelde a few more images of Glory and the artwork for his Latest book project. Rob
- 3,560 replies
- clipper
- hull model
The tape crinkles because the tape is forced to bend around the curves of the hull. If you apply less length at the critical points of hull curvature, you can avoid this issue. Rob
- 44 replies
- Cutty Sark
- Sergal
Oh...I've discussed with my wife about doing just that....I will. Rob
- 3,618 replies
- young america
- clipper
I hope you find it helpful. Not everyone can get a hold of a wringer, such as I have...but they are available on the web......just keep looking. It is best they have rubber rollers. I invented this technique, because, generally, I'm a lazy model builder....always looking for the fastest way to do just about anything. NOT chinsey, but faster. At my scale, 1/96...it works great.....allowing for the *hint* of detail, without overstating the detail. Plus, I coppered my hull in half a days shop time. I had other things to do......😁 Good luck. Rob
- 1,208 replies
- great republic
- clipper
I hope to plan a cross country trip some day to visit Mystic. What a thrill. Rob
- 3,618 replies
- young america
- clipper
The metal to metal rollers are not a good fit….. you need the rubber rollers to press the copper tape into the former. The metal from my experience, crushes the copper. But if done gently it might work. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
We’ll giving it a try may pay off. Use stick glue first to see how it looks. A little while glue or Shellac will due. Rob
- 95 replies
- Cutty Sark
- Sergal
I have real gold foil, but it leaves small wrinkles. No good. Gold is actually edible and my wife has some expensive gold powder used in cake decorating. You dilute it in alcohol (Vadka). Then paint it on. Bright shiny gold that when the alcohol evaporates, leaves a bright gold finish. Can be fragile if handled roughly. But still works well. I then got nervous and removed it and painted it with Testers extreme gold. What can I say…..I like to try different and unorthodox ways. Rob
- 95 replies
- Cutty Sark
- Sergal
Just so you know...the rail cap IS the pin rail on CS. Her fancy rail could use the white paper trick....if at all possible. Your model is looking sharp.
- 95 replies
- Cutty Sark
- Sergal
Make the white portion out of paper. Simply find a piece of copper tubing...bend it to the appropriate dimensions, by squishing it down to make the form.....then using a Dremel sanding disk/drum...bevel the edge into a nice sharp edge. Place your small stack of paper on a soft wood surface...then using a small hammer *punch* out all the paper imprints you need. Just glue em on. Your problem is solved. Task may vary, and is dependent on the skill of the fabricator and hammer user.....☺️ Rob
- 95 replies
- Cutty Sark
- Sergal
On a single vessel there may be a dozen different colored lines. All dependent on the life of the line. Newer lines are darker.....and older lines fade and become grey. Still functionable, but discolored. I try to use at least 3 colors of line on my models to represent this phenomenon. Rob
- 431 replies
- Flying Fish
- Model Shipways
Well...I wouldn't say it is not historical. At any point in time a vessels rigging changes for various reasons......all being historical...but not necessarily historical to all points in a vessels history. In most cases...to protect the public and to preserve and provide for adequate maintenance...some items have to be altered from their original condition. A minor detail the general public is totally unaware of. Rob
- 431 replies
- Flying Fish
- Model Shipways
I was just reading your reply over on Ships..... And my next question was....how do you keep water out? Possibly the length of 5ft and the proximity of *Just* under the rail, behind the pin rail, protected the entrance as a hood would, from encroaching water? Told you, this was going to be an issue to solve. A lot doesn't make sense currently. Rob
Ask yourself....it is a fact they tarred or oiled the shrouds and backstays...no issue there...so what makes the ratlines any less susceptible to weather and decay then these other structures? When they rerigged the Constitution several years ago, they used all black line to simulate the actual tarred line of the original rig. Lanyards too, are part of the standing rigging...susceptible to the same elements and decay. Though they are used to sinch up the shrouds...they are NOT part of the running rigging. Tarr-em. Cutty Sark is no longer a working ship....she is set up for tourist, and many such details have been slightly altered for maintenance purposes. Rob
- 431 replies
- Flying Fish
- Model Shipways
One minute I’m making great sense, then the next minute I’m making no sense. I’m not talking about the ventilators you referenced, but the ones atop the plank sheet, between the bulwark stanchions. These guys can become submerged in heavy seas. Here’s some examples from Campbell and Rick’s Flying Fish.
I don't mean to stand boldly in the face of those who are more experienced than myself on such matters, but history shows us that McKay was terribly dedicated to his workers and from that it is not a far stretch to gather that, that dedication extended to those who would use/sail his creations. As clearly as you have pointed out the failure of the most competent replicators, to recognize the *secret* of McKay's genius ..his now famous... Naval Hood. It is not a far stretch to see that these simple winches must have been omitted out of the same neglect. How could they have missed it....was your battle cry. I believe the same can be said about these lever winches. They are extremely plausible. Rob
This would suggest....she had ventilators similar to those found on Flying fish. Tucked within the stanchions of her bulwarks. I've never been a fan of these kind of ventilators. When the bulwark goes under green water, and the decks are awash....the ventilators get submerged and most likely are flooded with water....which, subsequently spills into living spaces. Rob
