Everything posted by jose_b
HMS EURYALUS by Matiz - FINISHED - scale 1:56
jose_b replied to matiz's topic in - Build logs for subjects built 1801 - 1850
Splendid work as usual. What rope-making machine do you use? Could you put any photos of the process of making ropes? Thanks in advance. Splendido lavoro come al solito. Che macchina per la produzione di corde usi? Potresti mettere qualche foto del processo di creazione delle corde? Grazie in anticipo. (Google translator) -
ancre Le François 1683 by jose_b - Scale 1:48
jose_b replied to jose_b's topic in - Build logs for subjects built 1501 - 1750
After a long period of inactivity due to job matters, here you are a small update including the main capstan. -
That's right, it's a wood filler. In Spanish is called "tapaporos" (a compound word formed by the verb cover -tapar- and the noun pores -poros-).
Excellent!
Precious and neat work as usual. It's a pleasure to watch your progress. -
Amalio, if you have the opportunity, it would be a great idea to show us the making process of those clamps. Thanks in advance.
A repetitive and accurate work! It's fantastic! -
I've used knives, mainly one (with which I felt more confident), and a rotary tool for "wider" areas. Thanks. -
I appreciate all the suggestions. I'll try to fix some irregularities on the third wale. Hubac, Druxey, thank you very much for your help. -
After a long time, some updates: I've installed the upper wales and then I've cut all upper parts of frames. I've also finished the upper part of the stern. -
It's a really neat work. On the other hand, Congratulations on your recently fatherhood!
- 969 replies
- hahn
- oliver cromwell
Thank you very much everyone for the "likes" and kind comments. Yes, Cabrapente, I hope to continue with this marvelous hobby when I'm retired. By now, I can only devote to it very little time due to my job. -
