Bill Gormley
Members-
Everything posted by Bill Gormley
That's brilliant ... which is probably why I didn't think of simply soaking the planks then clamping them in place and letting them dry there. Thank you for the nudge there to engage my noggin. On the plus side, I did get the planks attached on one side yesterday without too much pain ... just needed to go slowly.
I've been following your progress, just not commenting much. That is absolutely beautiful work and a fine goal for me to work toward with my own build.
- 950 replies
- syren
- model shipways
Four months since my last update ... boy, am I moving slowly. I've managed to get the initial planking above the wales done as well as the counter and transom. Progress photos and a few questions below. In the photo below, I'm thinking the counter will need to be sanded back further at the bottom left to accommodate the next three planks, but we'll see. For the Syren experts out there, did you you pre-form the planks to follow the shape of the stern - or just glue and clamp the planks? It seems like a severe shape to try to force wood to hold with just glue alone. Another question - when I add the garboard plank is it designed to sit flush where it meets the stern post? There isn't a rabbet the plank can fit into so want to check I didn't mess by not chiseling in further. Man, the camera is merciless. That gap above the first gun port looks bad but isn't so terrible under normal lighting and from a normal viewing distance. What is the best way to address that? I was thinking about taping around that gap, then pressing some diluted wood filler into place, and sanding it smooth. The edging around that first gun port is wonky ... but it was my first attempt so I'll let it slide. I was just relieved to get a fairly good fit at the bow. I dreaded adding the counter and transom but they weren't that difficult. Getting them on the model really does a lot to create the impression of a ship rather than an ugly skeleton. Looking at the planks along the rear quarter, that isn't all pencil edging to simulate caulking. The wood was really rough in some cases ... I'll live with it for my first model. And one last question ... does it matter when I stain the model? Safe to wait until all planking is done?
It's been months since my last update, but I'm still chugging along with my build (and enjoying it immensely). I've been watching other Syren builds in the meantime in the hopes of avoiding pitfalls. Unfortunately, I'm a zero when it comes to woodworking, so every little thing becomes a side research project. Going back to my previous update, I needed to correct the frames on one side where I had drastically over faired them. I finished that task and went on to frame the ports and sweeps and sand both sides to an equal degree. Per the instructions, I then added the stern and supporting pieces below the counter to aid in planking. Progress pictures below with a number of questions ... 1 - Should I address this or will it not really show up under a coat of paint? If it should be fixed first ... wood shim or better to use filler? 2 - Are the sills supposed to be sanded to the same thickness as the frame? What I'm showing here is my sills are a little bit wider. 3 - It's hard to see in the photo, but this is a shallow divot where I wasn't careful with my sanding stick. Should I fill and restore this divot (and others like it)? Not sure whether it will cause trouble later on when it comes time to plank the deck. And two more questions... 4 - What do you use to get nice straight cuts? I have been using a razor saw which cuts the wood easily enough ... but is there some basic technique or trick to get a straight cut? 5 - I'm about ready to paint the gun ports red and I was planning to use either Tamiya or Life Color paint from my plastic modeling stash. Do I need to prepare or seal the wood first? Thanks for reading this far ... all input and feedback welcome! Bill
I'm back with the latest edition of the world's slowest build log. At this point I have faired the sills and lintels and cut (but not attached) the 'green' framing for the port side. As I was doing this I realized I created a problem for myself. As you can see in the photo below, I sanded some of the frames far too much. Not sure how I did this without noticing or breaking the frame, but I noticed it in time not to create the problem on the starboard side. Do I need to find a way to fill in the convex area circled in red to strengthen and restore the tumblehome shape? If so, what would be the best way to do that - saw dust plus wood glue? Wood filler? Another question is whether I have sanded the insides of the sills sufficiently for the decking later. In the photo below (red circle on the left) do I need to keep sanding the sills until they are flush with the frames? Finally, this may be a dumb question, but ... the gun ports should be perfect squares that follow the elevation of the sills, right? Meaning by the time you reach the bow and stern they will be square but at some slight angle to (not parallel with) the waterline. Am I going to have an issue at the stern? I know the instructions say to cut out one of frames, but I didn't think it was two ... and my gunports appear to cross frames in two cases.
Thanks everyone for the input and tips above. I didn't respond at the time 2-4 weeks ago, but it helped me keep moving. Very much appreciate the help. Since my last post I have made a couple trips to Home Depot for stain. I wasn't happy with how the lower deck turned out using straight Minwax Golden Oak, so I mocked up a small section of planks and tried again using Minwax Pre-Stain Conditioner followed by a 3:1 mix of Minwax Natural and Golden Oak. The stain has a much more uniform appearance and the lighter color looks a lot better (at least to my eyes). I also framed the sills and lintels. Baby steps, I know, but I like how they already start to show the ship's lines. Unfortunately, as you can see in the photo below (red circle) I glued the sills in the wrong way with the narrower edge on top. For those who have gotten further with their builds, will this create a problem down the road? At this point, I have thinned the sills and lintels on one side, which you can see in the photo below. My question here is how folks thin the area the red arrows are pointing to. There just doesn't seem to be any easy way to get in there ... and given amount of material to remove and my lack of a dremel-type tool, I'm wondering whether I'll get through this step before Christmas. Seriously, though ... any input on how to get into this space?
What beautiful work - I could look at the photos of the hull all day. I'm seriously challenged when it comes to tying knots so I'm eager to see what (and how) you do.
- 950 replies
- syren
- model shipways
Minimal update here ... but some progress. I laid the planks for the lower deck and stained them Minwax Golden Oak. I'm not happy with the look compared to the reference photo in the instruction manual (see below). The color isn't in the same zip code and the stain penetrated very unevenly. Any thoughts or suggestions? I did not use the Minwax Pre-Stain Conditioner I mentioned in my previous post, so I may conduct a quick experiment to see if it makes a difference. Is it possible the wood in the instruction manual is a difference species than what is included in the kit? Separately, I have started reading ahead to chapter three and have one concern and a few questions. The concern is that the paper template (which I cut out very neatly) doesn't come close to lining up with some of the bulkheads. Anyone else encounter this problem? I don't think I cut out the template incorrectly and it doesn't seem possible that the bulkheads could fit in their slots and be so far off from the template. And a few questions ... What is the purpose of the paper template? The text tells you to cut it out and tape it to the model. But before telling you to do anything further the instructions tell you to remove the template and instead attach a batten. Is it just to help you picture what you will be doing and order to follow (i.e. yellow, green, red, blue)? Is a batten just a 1/16" x 1/8" inch planking strip? The instructions recommend little brass nails to attach the batten. I recall seeing something similar while doing a kit inventory. Is this where those small nails are intended for use? Thanks for all the help and input so far ... makes a world of difference.
Patrick and Mr. Walrus - Thank you both for the step-by-step guidance. I'll give the interior deck a go tomorrow and post progress pictures when I can. I'm trying to absorb as much as I can from all the build logs on this site, but it's like drinking from a fire hose. I climbed the same learning curve on the plastic modeling side too so I understand it's par for the course, but I feel like I could read forever. I have to keep reminding myself to stop stalling, get in the basement, and make some progress. A question about staining planks before I do that. Would you (or others following along) recommend pre-stain wood conditioner? I'll be using Minwax Golden Oak stain per the instructions and while I was in Lowes I saw Minwax sells a pre-stain conditioner that prepares the wood so the stain penetrates evenly. It is especially recommended for soft woods (which I take it the kit wood is). And a random observation. The question of "waterline" versus "full hull" comes up regularly on the plastic model sites. I'm a "full hull" kind of guy, but I realize there is broad support for both camps. Judging from the number of kits that provide both options, model manufacturers do too. How has the wood ship modeling world avoided this existential question?
Well, it's been over a month since my last update ... I knew this would be slow going but I'm surprising even myself. It's been great fun so far and that's the point, right? I've been pleasantly surprised by how forgiving wood is as a working material. Sanding can get tedious but I like how much control you have if you take your time. Working with brass and photo etched parts and super glue in the plastic model world could get nerve wracking. Anyway, just a couple progress photos below. Major progress points are that I have created a basic building board, faired the bulkheads, and added blocks to strengthen the hull. Sanding the blocks to get the right fit took FOREVER so either I need to get more accurate with my measurements or I need to invest in a Dremel tool (or maybe both). One question as I look to finish out chapter two. The instructions suggest using a pencil to recreate the caulking between the planks of the lower level deck. What is the order of operations here? Cut, add, and stain the planks then run a pencil along gaps where the planks meet? Or is it run a pencil along the edge of each plank, add them to the model, and then stain everything?
Thanks for the clear responses, Patrick! I'm going to have many more to come, I'm sure. Below a few progress photos. Apologies for the poor quality ... I should have changed the lens. Q1 - I'm at the point where I need to bevel the bulkheads. The instructions say to bevel the outer edge almost but not exactly to the dashed line. I'm clear on that. They also say to bevel the inside of the bulkhead and to keep the angle consistent. Can I confirm the red arrow is pointing to the correct area to bevel (with the blue dots highlighting the other three corners)? Also, is it fair to say that when I'm done - viewed from the top down - the bulwark frame should be a parallelogram? Q2 - Is the solid black line I'm pointing a bevel line similar to the dotted line circled with Q1? Q3 - I was going to create a building board. Is there a simple example someone can point me to? The simpler the better in my case. 😝
Hi Jamie - Nice start. I'll be following along as I recently started Syren as well. Good idea to work on the ship's boat a project within a project. I have been scratching my head a bit as I glue and clamp something and then have to wait 24 hours. Very different from the plastic models I'm used to where you can keep going.
Thanks for all the input so far. I have managed to attach the rabbet strip, carve the rabbet, taper the stem knee, test fit the figurehead, and glue and clamp the stem knee to the bulkhead former. It took quite a while to taper the stem knee and get the figurehead to fit but I have thoroughly enjoyed the work thus far. Below are a few progress photos with circles where I have questions. Hopefully they post in order ... Q1 - A lot of build logs show an orange color or substance where I have circled. Any idea what that is? Also, should the bearding line still be visible once I have carved the rabbet? The picture doesn't show it well, but there is a smooth taper from the bearding line down to the rabbet. Q2 - Is this area going to pose a problem? The wood just snapped when I tried to work it. Q3 - Same question, different area. Toward the top of the circle the wood chipped and toward the bottom it came away. Q4 - Should I have sanded off the dark outer edge of the stem knee? Q5 - General question. I'm working in a basement with little in the way of ventilation. Should I be concerned about sawdust build up?
Thank you all for helping me push this thing out to sea. Patrick and WalrusGuy (should I call you that?), I've been eagerly catching up on both your builds. Really nice work, and motivational to see what can emerge from the pile of wood on my table. One question for the group - should I try to find a long, flat plastic container for the wood? I wouldn't characterize the basement where I am working as overly damp, but still I wonder whether the wood will warp over time.
Hi everyone. Long time modeler but first time wooden ship builder here. I have waited patiently to finish two projects - IJN Yamato and USS New Jersey, both in 1/350 scale - before starting this kit. Now they are done it is time to start on Syren. I can't hope to match the beautiful renditions of Syren created by others here, but I do hope to learn from them. By way of background, I have been making plastic models from kits for the past 10-12 years. I started with 1/35 scale armor, dabbled in 1/48 scale aircraft, and then gravitated to 1/350 scale ships. Along the way I acquired a huge assortment of tools and paints, and developed an almost masochistic degree of patience. IJN Yamato and USS New Jersey both took me two years or more to complete - and I suspect Syren will take longer - so patience will be a requirement. I'm sure many of you are thinking, "Oh no, another first time builder who has bitten off more than he can chew." Possibly - we'll see - but there zero chance I will walk away from this build or the hobby in general. True to form, I will work slowly, watch carefully what better builders have done, and ask a lot of questions. At the end of the day, I'm not afraid to screw this up and that relieves any sense of pressure. There WILL be a ship that comes of out all my efforts ... the only question is whether it resembles the real thing. 😝 As true "negatives," I have no experience working with wood, and I wouldn't consider myself handy in a real world sense. I'm not the guy who whips together a treehouse for the kids in a weekend. And scratch building is something I have avoided in the past. Finally, I suspect I will be diverted initially gathering tools and supplies ... things like rubber bands, binder clips, clamps, balsa wood blocks, etc. that I haven't needed in the past. At any rate, here I go. Since I don't have much to share at this point, I added some pictures below of my workspace, my first steps, and my previous projects.
For Beginners -- A Cautionary Tale
Bill Gormley replied to ccoyle's topic in New member Introductions
The timing for me to stumble across this thread is perfect. I'm a newbie to MSW although not to modeling in general. I've been on the plastic side of the hobby for the better part of a decade and just finished a two-plus year build of the Japanese battleship Yamato. After a few months off it's time for me to select my next project. I want it to be a wood ship and I have two options: La Confiance (Constructo Modelismo) or Syren (Model Shipways). The former is an orphan kit I rescued from my father's basement years ago. It's a solid hull French fishing trawler by a company I haven't been able to find much information about and seems to be relatively straightforward (at least by comparison). The latter was a Christmas gift from my wife last year and interests me much more. I realized it would be on the difficult side as an initial build but received some encouragement here that, with the detailed instructions and the help of this site, it was realistic. Am I about to make the same mistake as others before me? Would I do well to cut my teeth on La Confiance? Better to start with a simpler, solid hull kit of a subject that doesn't interest me or a more complex subject that really does interest me? I plenty of modeling experience but I don't have a background working with wood. And just one thought - made previously, but that I would like to echo - is the need for the manufacturers to provide quality materials and solid instructions with so called "beginner" kits. If the wood goes to pieces and the instructions read like a Rorshchach test then it's easy to see why the first build is often fatal. It creates a high barrier to entry into the hobby and I'm surprised more manufacturers haven't addressed it. -
I have the Pontos set for the USS New Jersey so I know exactly what you mean. The instructions look pretty good but you do hear complaints from time to time that they are insufficient. I just finished Tamiya's new Yamato kit using the Pontos wood deck plus Tamiya's AM railings, degaussing cable, and 18" guns. I have never drilled so many holes in my life. Took me a couple years but after finishing and taking a break I'm ready for my first wood project. Yikes.
- 75 replies
- scharnhorst
- dragon
I have this kit in my closet but have been patiently waiting for Pontos Model to produce a PE detail set to start it. It's a daunting kit even with adding PE and a wood deck. But it's a beautiful ship with graceful lines (at least after they added the Atlantic bow). I'll be following along with interest!
- 75 replies
- scharnhorst
- dragon
Help with Model Shipways kit choice
Bill Gormley replied to Bill Gormley's topic in Wood ship model kits
It's been a while since my last post. I have another few weeks on my current project but then I hope to start on Syren. I realize the instructions that come with the kit are excellent - and I will start a build log - but are there any books you would recommend as a companion or first addition to my library. -
Well, Santa came through and Syren was waiting for me under the Christmas tree. It's a very attractive kit although vastly different from what I'm used to with plastic kits. I couldn't resist reading the first few chapters to see how well I could visualize the steps. Seems do-able, especially with the build logs and ready help available on this site. I'm definitely motivated now to finish Yamato so I can move on to this. In the meantime, a couple questions: 1) Most of my tools are oriented toward plastic ship modeling. Has anyone compiled a list of basic "must have" tools? 2) Are there any clubs in central NJ that focus on model ship making? I'm aware of the Ship Model Society of New Jersey but it's too far away (I'm near Princeton). If there's a group nearby, I'd like to get involved. And if there's an experienced builder nearby, I'd be interested to discuss hands-on lessons. -
First off, thank you all for your input. Lots of good information. Chris - After poking around some more, I'm no longer convinced a LSS practicum is the way to go. Sounds like a good kit + good instructions + lots of help from the members here is a better bet. And I'm happy to hear you think Syren would be realistic for a first build (since I lean toward it). Do you think there's any real difference in terms of the difficulty relative to Fair American? Augie - How many wooden ship models did you have under your belt when you tackled Syren? And with regard to the scale difference versus Fair American, does that translate into more difficulty with the details (e.g. rigging)? I have a lot of tools and supplies, but they're all geared toward plastic ship modeling. Certain items such as the airbrush, tweezers, files, etc. will transfer but I suspect I'll have to get the basics for woodworking once the time comes. Jay - I'm drawn to Syren because of her lines, historic role, and the fact that she's a warship. There don't seem to be that many other entry-ish level options that meet all three criteria (although I'm open to suggestions even if it means going with a manufacturer other than Model Shipways). I have to admit, after reading through the build logs here over the last few days, I'm intimidated by almost every kit option. That jogged my memory about an orphan kit I got from my father several years ago (his eyes were bigger than his appetite). It's the French fishing trawler La Confiance from Constructo Modelismo. Has anyone heard of this kit? I've attached some photos of the box, instructions, and parts. Any thoughts on whether it might be a good place to start? -
I know this question has been asked many times before ... but I'd appreciate some help selecting a first ship model. As the topic title suggests, I'd like to limit the options to what is available from Model Shipways. That's a somewhat arbitrary decision on my part to prevent decision overload but it's also based on my reading of the threads on this site, which suggest Model Shipways is a solid vendor. By way of background, I've never built a wood ship model but have been heavy into plastic ship modeling for the past 5-7 years. My current project - the Japanese battleship Yamato - is nearing two years and still going strong, if slowly. I don't mention that to impress anyone but to demonstrate that perseverance won't be an issue regardless of the kit I choose. I'm not afraid of complexity or a long time horizon. I've attached one of the few photos I could find of a past project to give some sense of where I'm at ability-wise. With all of that said, Christmas is around the corner and my wife is open to suggestions. I've been thinking about one of the following packages and would appreciate any input: 1. MS Bluenose ($220) + LSS "prep school" practicum with photos ($120) = $340 2. MS Fair American ($250)) + LSS "freshman" practicum with photos ($120) = $370 3. MS Pride of Baltimore ($220) + LSS "freshman" practicum with photos ($120) = $340 4. MS Syren ($400) 5. MS Rattlesnake ($240) Options two and five are what I'm leaning toward based on price and personal appeal. Option four scores really high from a personal appeal perspective but looks more complicated and is expensive without any accompanying aids. Do any of the above options stand out as an especially good choice? Am I likely to bite off more than a first timer can handle with the Fair American? And what would you budget over and above what I have above for tools?
