KurtH
Members-
Everything posted by KurtH
You may already be aware of this, but just in case - the rope sizes given in the BJ instruction manual are circumference, while the ones on most packages and spools of rope are diameter. I did not catch that, and as a result the rigging of the 24 pounders on my model are way out of scale. I ended up doing the math and writing the correct size into the instructions for all the lines.
No, I have not abandoned the build. I am just a very slow worker. I finished laying the first layer of planks: I will post a similar set of shots when I have sanded down the protruding edges and humps, and filled in the dips and hollows. As I am not experienced at this, the funky fettlin' near the keel is not that surprising. It will not win any prizes for authenticity, but it should suffice as a base for the second planking, and it will not be seen.
Installation of the decking sheets looks great. The sheets I had did not reach all the way to the stern, so I hid the seam between the two lengths under the Captain's inner cabin bulkhead. Concerning the assembly of the guns - you may already be aware of this, but just in case, the trunnions are not exactly midway between the top side and under side of the barrel, so the gun will sit lower or higher in the carriage depending on which way is up. I did not realize this until I had half of them done. Consequently, they align beautifully on the starboard side of my model, but not so well on the port side. My apologies if this info is superfluous.
The glued up sheets consists of strips of basswood glued together edge to edge with black glue which simulates caulking. The strips which make up these sheets can be 1/16" wide, 3/32" wide, and, I believe, 1/8" wide. At 1/96 scale, these would simulate planking which is 6", 9", or 12" wide respectively. The deck plan sheet provided in the kit specifies planking which is 1/16" wide. The decking sheets provided in the kit (assuming your kit is like mine) are scribed rather than glued up. I like the simulated caulking, so I ordered the glued up sheets from BJ. I ordered the sheet which was made up of strips 1/16" wide because that was what the deck plan specified. The plan is wrong. The Constitution has 9" wide planks which is 3/32" at 1/96 scale. I thought I would give you a heads up on that. The photos to which I referred in my post can be found on page 39 of the instruction manual. The planking there is clearly 3/32" wide. By the way, glued up decking should only be used if you leave the deck bright. If you plan to paint it or stain it dark the planking detail will simply disappear. Plank the deck yourself or use scribed decking sheets if you plan to do that.
I also used glued up planking. Following the instructions, I used 1/16" wide planking which turned out to be wrong. On the real ship the planks are 9" wide tapering to 6" at the stern. Tapering is not an option with the glued up planking, so If I had it to do over, I would use 3/32" rather than the 1/16". The photos of Arnot's model in the instruction book does show this size. My kit did not include planking for the spar deck, so I ordered the planking needed from BJ. They sent me 3/32" wide strips which made no sense because they provided 1/16" wide scribed planking sheets for the gun deck in the kit. Since I realized the problem too late to change the gun deck, I ended up using 1/16" size for both decks to be consistent, and used the provided 3/32" strips for the outer hull planking.
I was hoping to complete the first planking before I had to put this project aside in order to do my yearly video projects, but it looks like I am just to slow to make that happen. So here is the current state of play: Stealers to be added aft after the planking is complete. I expect to resume in mid July. Meanwhile I will follow all the great Sphinx builds which abound on this site.
Sorry to hear of your difficulty. I have also made errors similar to yours when I fitted the outer bulwark patterns. I was so taken with your planking that I clicked like before really looking at the text. I am sure you will find a way to work around the problem. I will be interested to see your solution. I have followed your build with interest and admiration.
- 422 replies
- Vanguard Models
- Sphinx
The next step is to install the ply upper hull side patterns: 1. Upper hull side patterns 2. Upper hull side patterns after having been soaked in hot water for 90 minutes and clamped to the hull. Upper hull side patterns installed: Next comes the first hull planking. I did hull planking down to the waterline in my BJ Connie build, but this will be my first foray into planking below the waterline. There are many methods and philosophies as to how this should be done, but I am inclined to go with what is described in the manual. I would like to proceed as if this were the final planking to get the practice of exacting tapering and bending so that when I actually do the second layer, I will have learned some lessons and will be in a position to do my best. I anticipate using filler to fill in dips and hollows but not the small gaps between strakes, as the final layer will hide these.
Thank you Geoff. I greatly appreciate the compliment! I have just looked at your build. Wow!!!
- 112 replies
- Bluejacket Shipcrafters
- Constitution
I have only just now checked on my build log and found some new and most rewarding comments! Thank you Dom Fischli for your kind words. I have found that debonder does a good job of diluting the CA although I have not tried it in quite the same situation that you describe. Thank you Blue Ensign for your compliments. I have spent a great deal of time looking at your builds and have the greatest admiration for your work as do many other modelers. Your comments mean a great deal to me! Incidentally, I plan to add lodging knees to the quarter deck scantlings to my Sphinx build in much the same way that you did. I can only aspire to do as well.
- 112 replies
- Constitution
Thanks Rich! I appreciate the info. I also have a couple of books on the subject - one by Donald Dressel, and one by Kieth Julier. An alternative to measuring and dividing is described by Chris Watton and James Hatch in the instruction book. It is good to have a variety of techniques available to consider. I will take my time and think carefully before I proceed. As there are two layers of planking, I can try one way on the first one, and, if that does not produce a good result, I can try another way on the second.
This is my idea of the fairing of the hull. It is my first attempt, so I will not know for sure how well I did until planking commences. Based on what I could determine using card stock strips, I should be OK, but we'll see. The advantage that I see of a plank on bulkhead arrangement as apposed to a solid hull kit is that accuracy of the hull shape is assured as long as the shape of the bulkheads is not altered. To begin with, I sanded the components making up the bulwarks flush with the bulkhead ears. To avoid taking off too much material below the deck level, I left a thin line of char on the aft edge of the forward bulkheads and on the forward edge of the aft bulkheads. This may reduce the bearing surface somewhat when the planks are glued in place, but I think it should still be sufficient given how strong the bonds have proven to be using PVA on MDF and pear. I used my own technique for getting the angles right on each part of each bulkhead, which I am reluctant to describe until I am sure that it worked. It is time consuming, and I am sure that experienced modelers could do just as well much faster. I just did not trust myself to get it right doing it quickly. The process did not take three weeks however. There were other delaying factors which I need not go into. At any rate, here are shots of what I have done:
Hi Gary. I varnished that deck with the recommended Vallejo Matt Acrylic Varnish to protect it. The fact that little of it will be seen was an advantage for me, as I am inexperienced when it comes to finishing, and I wanted to see what the result would be. I do not see why WOP would not do as well if not better, but what do I know? Fortunately there are many modelers who are expert finishers who would be glad to give you good advice.
Gary - I have seen several other builds in which the boats were done first (I forget which). In most other boat builds, the frames serve as the ribs of the boat, and you break out a center piece. In the Sphinx boats the whole piece except the bottom comes out and ribs are added subsequently. I am guessing that you glue the planks to the stem and stern post and to each other edge to edge, avoiding gluing them to the frames. Am I right? Your boats look really good! I can only aspire to do as well.
The next step is to remove the gates which strengthened the bulkhead ears because they are no longer needed, and because they will obstruct installation of the upper hull side patterns. Here is a before and an after pic: Time to construct and fit the jigs which will keep the bulwarks properly aligned as work on the upper hull planking details progresses. This composite photo shows the component pieces of the forecastle jig unit, and how the assembled structure looks when slotted into position. As you can see, the parts are all engraved with letters which guide you when assembling the unit. This parts fit together easily and precisely. but, as I was dry fitting the beams into the side pieces (#30) to check the fit, the port unit gave way at the "U" notch. It seems that these pieces are vulnerable at that point, so caution is needed there. I glued the joint back together with PVA, and reinforced it with one of the extra keys provided in the kit. The jig beams at the waist have notches which fit over tabs in the longitudinal gun port frames. The numbers engraved on the beams match the bulkhead numbers. The J stands for jig. Again, the fit is precise. The jig beams at the quarter deck are secured to the bulkhead ears with the afore mentioned ply keys. A number of extras are thoughtfully provided in the kit. I glued these into the beams to keep them from getting lost when the jigs are not in use. I was, of course, very careful not to let any glue get to the tongue which engages the bulkhead ears. The glue was allowed to set and dry with these tongues partially inserted into the ear slots to ensure exact alignment. It works. I checked. The numbers engraved on the beams match the numbers on the bulkheads the ears to which these beams attach. Here is the current state of play: No deck planking detail is visible in the photo but, as I have previously demonstrated, it is there. Like the Nazca Lines of Peru, these details look a lot better when viewed from above. Now to begin fairing the hull. I have no experience at this, so I intend to proceed slowly and carefully. It may be some time before I post again.
The stern cabin bulkhead pattern and the stern cabin seat pattern are removed from their sheet, varnished, then glued into place: 1. The forecastle bulwark bulkhead patterns removed from their sheet. 2. Parts #16 are glued into notches in the bow curve pattern. 3. Parts #37 are glued into place. 4. Part #17 glued into place. Thinking ahead, I tried fitting the dowel which will be the bowsprit stub into the slot before adding all those little delicate parts. The dowel was a bit too big, so I widened the slot slightly to accommodate it. I dry fit the bowsprit step and fettled a bit until the dowel fit nicely. I figured that doing this now would be easier then doing it when the time came.
