Posts posted by Martes
I think it's purely rendering issue. For some reason the program tries to blend the edges of the objects with background color. If it is very bright, some details can go missing, and ropes appear thinner. Probably may be fixed with antialiasing settings, but much easier to give some background like that paper style you posted earlier, or hard black against white. Don't dwell on it.
The ropes are thin and likely look something like that from a distance, but in this post:
they looked more or less all right. I suppose you have to have some kind of world background for the ropes to show normally, since the very last pictures displays the ropes that are shown against the sails and those that are not differently:
In fact, it depends on three factors.
First is the weather. The water is less and less transparent as the wind rises.
Second is the presence of a sea bottom mesh and it's color. They do not appear on all maps, but here nice and not very deep sand is present.And third is somewhat connected to camera angle and wind direction.
I tried once to make maps for this game, it's technically possible, just very inconvenient, because the terrain mesh should be separated from underwater mesh exactly at z=0, and if a single vertex from the land mesh or a single vertex of sea bottom mesh crosses this line, the scenario crashes on load. It is also somehow possible to place buildings, cities and forts (the game contains appropriate models) on the maps, but I did not go that far.
Another relatively practical solution that I have seen on several maps included in the game is that the land mesh is regular, while the underwater mesh is simply a plane with painted features (and corresponding map zones as described below).
The "path" object denotes the land collision edge that has to be separately created (and are particularly difficult to generate), "anchor" allows ships to drop anchor, and "shoal" can have limited depth set in scenario editor and thus strand ships that are deeper than this value.
The sea, however, is done quite ingeniously, especially for so early engine (1999 or 2000, IIRC) - it is, in fact, a combination of two flat semi-transparent surfaces that have different textures running in different directions, creating a very convincing illusion of moving water.
In general, I would love to introduce some accurate geographical scenery into the project, but, again, probably it's better (and easier) could be done in Unity. If only I had the time.
And a dynamic scenery at that. You can recreate various situations, you can even set them to fight and see what happens, it is a tactical simulation, after all. That's why I love it so much. They are alive inside there.
If only I could control the camera lens angle here, the screenshots would be even more beautiful, but it would be easier to reimplement the whole game in Unity than find that bloody parameter in compiled C++ code of the original.
On 2/1/2023 at 3:31 AM, 3DShipWright said:
which would mean only one boat unless stacked like Russian nesting dolls...
That would depend on level of readiness, but yes, they did exactly that.
Plus one boat on the stern davits across the taffrail.
Some links for reference.
https://www.rmg.co.uk/collections/objects/rmgc-object-84945
Or two boats could be carried on the quarter davits if prepared for launch:
https://www.rmg.co.uk/collections/objects/rmgc-object-84911
And I still think she rides too high in the water. The waterline should be probably around X mark (which is also very anachronistic, as those were introduced somewhere around the beginning of 20th century).
But the renders are breathtaking!
The long spar-decked 74 also differs from the "frigate" by retaining the same head as the ship of the line, while on the "frigate" it is slightly shorter and does not have curved rails.
Which one of the two is more powerful - it's a debatable question, but the frigate, having about 150 less crew is certainly more habitable
Thanks, I am really glad you like them.
Hopefully I will convert the flush-decked version today or tomorrow and show her sailing as well.
The Royal Navy had quite a lot of ships based on the Courageux, so making the Colossus as a base was a little bit of a cunning plan on my part (although I was completely unaware of the scale of the copying work that was going on in the Admiralty when I chose which 74-gun ship to make), I just have to maintain a list of precise transformations in case I have to correct something and reimport the change on all the derivative models.
- 3DShipWright, Waldemar and mtaylor
- 3
As I already said, the completed hull of the Colossus presents a lot of interesting possibilities.
Among other things, the hull can be stretched by inserting a parallel section in the middle, and the Colossus turns into the Blake class:
Despite being almost 8 feet longer (180' instead of 172' 3"), it may be a little tricky to spot the difference - note the Blake has more space before and after the battery and an additional upper deck port. This model can represent practically any "long" 74, still smaller than 80-gunners and slimmer than the Temeraire-class ships.
Another option, very slightly less historical, is to stretch the hull without the roundhouse, since I have it anyway, but this time the resulting ship would not be considered a frigate, but a full-fledged two-decker with armed spar deck, less only the upper tier of the cabins. The Royal Navy, if I recall correctly, had only one major ship of the line in this configuration, the Plantagenet, which was of a different design but very close in size (plus the St. Lawrence on the Great Lakes, but that's completely different story), so the model will have to do at least for now.
The paint scheme is relatively unusual for Royal Navy and is closer to Danish or Russian ships, but it's not to say it was not used at all (at least it appears on a number of engravings) and it suits the design perfectly well.
- mtaylor, flying_dutchman2, Waldemar and 1 other
- 4
Interesting, that on two versions of the image, the sail is of different size. On the graphical, first image, it's bottom is near where the lower, main staysail should end on the foremast, and it's upper end is closer to the main topmast, and on the painting from artuk it is more or less identical to the maintopmast staysail from the plans.
Interesting, how effective it would be - both under the circumstances and in general.
1 hour ago, 3DShipWright said:
bow deck (name?)
Beakhead, IIRC. And the wall behind it is the beakhead bulkhead.
1 hour ago, 3DShipWright said:I'm keeping the cant frames from the 45-90 degree radials, but I will thicken and nudge them back on one another to form a more authentic shape and close in some gap space.
As each of them is actually a pair (see Intrepid again), you can divide each of them to two and spread them so they cover as much area as possible. Also their thickness is slightly less near the keel and can be slightly wider towards the wale.
The French did not use this method, they had straight vertical pairs up to the hawse pieces at the time, so you can rely on the British sources at this place.
One thing of note - the Constitution has her straight vertical pairs until the first gunport (as opposed the Intrepid that had them starting from the forward end of the second gunport of the lower deck), and you can, I think, safely follow that example and make at least two of the cant pairs actually straight.
The rest of the hull until the last gunport should therefore be evenly distributed with pair-gap, pair-gap. Very small gaps.
But yes, it already begins to look much better
The original file was at Bonhams, I think, under the title "A frigate under tow down the Avon Gorge". But I can't find it now, not on the fly at least.
A very similar image, though, is on ArtUK site:
https://artuk.org/discover/artworks/the-avon-gorge-at-sunset-188005
And is attributed to Nicholas Pocock.
However, when I look closely, it may be possible that the sail is not like a jib, but has a vertical cut forward and is additionally fixed to the foremast somewhere under the top.
So it begs the question - whether this was a standard sail supplied to ships for such situations, to emulate fore-and-aft rig (and how effective it could have been?) or this is a local captain's initiative and improvisation?
- BenD, mtaylor and thibaultron
- 3
USF Confederacy in 3D | Blender
in CAD and 3D Modelling/Drafting Plans with Software
Posted · Edited by Martes
So for this method to work you need to fulfill two requirements: that your initial run of the vertices and edges should coincide with the planking plan and distances and to be sure that the Solidify would give a correct offset.
However be careful. It may be very well possible that since Blender 2.79 that I use the Solidify operator has been improved with it's results on complex surfaces, but my results with it, when I attempted to reproduce the surface of the frames and then extend it to planking was very unsatisfactory, especially around the bow and I had to revert back to manual editing (see my first post about the latest iteration of the Colossus).
I find it very useful to keep a "water" object, to be able to verify the smoothness of the waterlines so that more or less all intersections of the hull with it would not produce sudden angled surfaces.
Also, take a look at what happens around your keel. There should be no dent there. This is exactly the position the planking edge should touch the keel.
