Cleat
Everything posted by Cleat
  1. I started a Chris-Craft 1956 Capri build log.  You mentioned you'd be interested in it.
    1. usedtosail
      usedtosail
      Great. I’ll check it out
  2. Thanks, I didn't notice the Edit button.
  3. I started my first build but I noticed when I copied my title the first letter was missing. Can I correct it or does it take an administrator.
  4. I switched to a thinned Tru Oil (50%) to build up the finish. I wet sanded the mahogany with the Tru Oil to create a slurry to help fill gaps. I’m applying many, many, many coats of the Tru Oil to build up the finish. This is as far as I have gotten. Next up is fitting the seats and I'm trying to decide how to approach adding coaming around the cockpit. I need to get some chrome paint for the hardware.
  5. Customization #2 The standard seats are just flat wood. I modified a plank to simulate a tuck and roll look of real seats.
  6. The instructions suggested using parchment paper to glue the deck pieces together, that worked well. I assembled the cockpit panels and mounted the deck. Mistake #5 I sanded the deck too much and removed some of the plank etching. I used a woodburning tool with an Exacto head to reapply the plank etching. Mistake #6 I installed the floor of the cockpit at an angle. I discovered that when I test fitted the seat. Customization #1 I planked the transom because when I broke the stock piece because it didn’t fit properly and I didn’t like the look. I also added a light piece to emulate a detail a real boat has.
  7. I used thinned boiled linseed oil (50%) to darken the wood to help hide my mistakes. The BLO also penetrates the wood. I used scrap pieces to fill in gaps and collected saw dust. I used the BLO create a slurry with the saw dust to also fill the gaps.
  8. Mistake #4 I didn’t follow the instructions. I should have planked the sides with mahogany before the bottom. I thought my experience with the sub planks would make the mahogany planking easier, I was wrong. I thought the planks would follow the contour of the hull but they wanted to change direction. I realized I was thinking in terms of a cylinder, not a compound curve. I chose to install the top plank first to ensure one plank looked right. I kludged together the remaining planks. I’m embarrassed to show this picture.
  9. Mistake #3 I got a bit over zealous when sanding and shaping the bow. I should have snuck up on it and kept the dark edge intact. I reshaped the bow using the piece from the keel cutout. The bow of a real boat has a bulbous nose. I didn’t get it completely right; I was concerned how the mahogany could be applied to the shape.
  10. I cut chunks of the balsa included with the kit to fit the voids. I used a saw, files, and sandpaper to shape the bow. That was a fun step.
  11. I have never bent wood before so I found a video to find out what to do. I soaked the ends of a couple pieces in warm water for about 20 minutes then used an iron to work the bend. I inadvertently creased the bend with the edge of the iron but that turned out to help the bend. I’d clamp the planks until they dried. Then I’d glue and clamp them again. I noticed that I created different arcs on each plank and I ended up with uneven planking (yellow glue is a structural component in my build).
  12. Mistake #2 When I test fitted the transom it broke, I should have filed the slot to locate the transom for a looser fit. Planking the bottom was straight forward but I should have trimmed the planks before planking the sides.
  13. The frame assembly is straight forward but I managed to make a mistake. Mistake #1 I didn’t fully seat one of the bulkheads (I discovered the problem when I stated planking). I had to sand down the top and add material to the bottom.
  14. For my first wooden boat kit I chose the Dumas Chris-Craft 1956 Capri. I wanted a modest kit to learn the basics and the kit offers a good introduction. I really like wooden inboard boats – they have a special sound. As a woodworking hobbyist I’m discovering that I’m not used to working with small parts. Since this is my first build, I am including my mistakes. The Dumas kit is complete, they say there are more than enough planks (I have extra pieces after planking). The drawing is very helpful and the instructions provide enough instruction to complete the kit (I’d like to see more tips). I use the plastic base as a place to store the project as I work on it. I’ll replace the plastic base with a wooden one that emulates a slow wake.
  15. Thanks for the information. I need to order some chrome paint. I've started a document of my notes and organizing pictures to create a build log.
  16. I'm glad I found this thread (I wish I'd found it earlier). I'm building the Dumas '56 Chris-Craft Capri - my fist build. I'm overcoming a number of my mistakes but I am enjoying the challenge. Your build is a guide for me to document my build. I noticed an aluminium clamp that you used to shape a plank (post #24 Feb 3), I wish I had something like that when I attempted planking. What is the fixture called and where did you get it? I'm looking into what to use to chrome the plastic fixtures. I noticed the Spaz Stix spray you used and the result looks good, I'm not familiar with that product. Why did you paint the part black before the chrome?
  17. I've been reading Ship Modeling Simplified and I decided to get a more modest kit to start with. I've also been putting together a tool wish list and like JimJ mentioned, I'll be getting a X-acto knife set and a razor saw set. Plus a couple other tools that seem useful like some small clamps.
  18. Thanks for the welcome. That applies to me too.
  19. I saw an ad for a Dumas 1949 19ft CHRIS-CRAFT Racing Runabout boat kit in a catalog I get as a woodworker and I decided I want to built it. I came here to research my project. I read the New to Shipbuilding thread to get an idea of the hurdles. I looked through a build thread for the runabout and it mentioned a book called Mahogany in Scale; I bought the book to become familiar with the process. As a woodworker I’m also trying to determine the smaller tools that I’ll need. I’ve been looking through a Micro Mark catalog trying to decide what tools might be useful. I’d appreciate any recommendations. I’m in Minnesota, US and I’m looking into my next winter project. I think the boat kit is something I can do (but it will probably take longer than I think).
