Mahuna
Everything posted by Mahuna
  1. I would suggest a double-action for control. Gravity feed, for several reasons: 1) needs less air pressure, 2) generally holds less paint, so less waste, 3) easier clean-up. Internal Mix is easier to learn and use. Compressor needs to output at least 30 psi. A friend purchased a compressor/airbrush combo from Model Expo that was well within your price and was an excellent value. You won't need a higher-level airbrush (Badger, Iwata) to start out. ME has a sale on right now (code MAD13), and is offering a nice compressor/airbrush combo for $115. http://www.modelexpo-online.com/product.asp?ITEMNO=AS176K Here's a link to a site that gives good airbrush lessons: http://howtoairbrush.com/airbrush-lessons/ Frank
  2. Hi Meredith: For cutting the zero tolerance insert: Here's the process I sent to Jim: 1. lower the saw blade, 2.mount the blank insert, 3. turn on the saw, 4. raise the saw blade until it cuts through the insert? His answer: You're right on the insert. When the blade breaks through put a little candle wax on the blade to help it along. It worked fine, and after the blade cut through to the extent I wanted, I removed the insert and cleaned it up a little. I'm playing around with making miniature "push blocks" for cutting very thin planks (1/32" or even less). When I get one that I'm comfortable with I'll post a photo. I'm hoping some of the more experienced modelers will also give us some helpful advice. Frank
  3. Just wanted to make a comment on the service I've received from Jim Byrnes: A few months ago I purchased Jim's table saw - I see why this is the most sought-after saw for modelers. Being new to the use of table saws in general, I've been proceeding slowly. I've been using the standard blade, and wanted to start using a slitting blade, but wasn't sure how to cut a zero-tolerance insert for the blade. I also had a few questions on the process for cutting very thin planks (1/32). I sent Jim an email via the Model Machines website, and received a personal email from Jim within a couple of hours. Jim answered all of my questions and was very supportive. Contrast this to some other sites where it took days for any answer, if one was received at all. Jim's quality machines and workmanship are matched by his commitment to customer service, and he's a pleasure to deal with. Thank you Jim!! Frank
  4. Water based paint will raise the grain of the wood (one reason why Russ is sanding after each of the first couple of coats). The wood can be sealed with a light coat of a mixture of 1 part clear lacquer to 1 part lacquer thinner. That's the primer used by bird carvers before painting birds carved from tupelo or basswood with acrylic washes. No sanding should be needed after painting if the wood is primed with this mixture. It's important that after this priming the wood should not be handled, since the oil from your hand will keep the acrylic from adhering properly. Hope this helps, Frank
  5. Thanks Danny - this definitely goes into my files. Frank
  6. Gaetan is correct, a micro motor system is much easier to control. The Foredom has more torque and is better for removing large amounts of stock. I use both. Another advantage of the Foredom is that you can set it up in a jig and use it for routing and milling. If you're looking for a rotary tool for small work, then the micro motor would be the better choice. Gesswein tools are very high quality (I have the Marathon Handy 700), but are very expensive. Woodcarving sites have other manufacturers to choose from - here's a link to an example: http://www.woodcarverssupply.com/NEW-MICRO-PRO-CHAMPION-SET/productinfo/793800/ Frank
  7. I've been using the Foredom for years in my other hobby (bird carving). I would recommend the SR model, which allows you to change the direction of the spin. There are several handpiece choices available as well, which adds to the utility of the tool.. Frank
  8. Very helpful topic. I recently bought a 16" Excaliber and love it. I've been using Olsen blades on it with no problems, but was not sure what size blade and/or tooth configuration to use for the different materials I'm working with. The link posted by Jeff is what I was looking for. Thanks to all. Frank
  9. Thanks for this info. Very informative. Frank
  10. Hi Ed: I recently borrowed a well-used copy of Volume 1 from a good friend, and I've already ordered my own copy - it's exactly what I need. I started ship modeling about a year ago and have completed a couple of POB kits. My goal is to complete a POF version of the Dunbrody, and your book will help me understand the techniques I need to master and the proper way to use my tools. Frank
  11. Hi Mark: Thanks for showing the Crosscut Table. I have a Byrnes saw, but I'm new to using table saws in general and seeing what others have done is really very helpful. Do you (or others) have any other examples of jigs or homemade accessories for a small table saw? I'm also not sure of how to make the cut in a zero-tolerance insert - do you use the actual saw blade to cut the slit? Thanks! Frank
  12. My favorite is a 0.3 mm pencil - very clear and tight lines. I think I found it in Hobby Lobby. Frank
  13. Jay - you're correct in what you said: "Now that I look a bit closer, it seems the one in front is stationary and the one in the back slides in a curved slot to make the thickness adjustments. Right?" Another really nice feature is that the port for a dust collector works really well - I attached my Fein shop vac to it and there was almost no dust after I used it. The only issue I had is that my old drill press didn't have a fine adjustment for table height, so changing drums was more of a job than it needed to be - this is more of a drill press problem than a Luthier's Friend problem. Frank
