capnharv2
Posts posted by capnharv2
  1. Sarah,
    What size lathe are you looking for? Unimat/Sherline/Proxxon (Micromark) or something a little bigger?
    Regarding a drill press, I have the one for the Dremel (minus the Dremel). If you like, I can bring that along to the next meeting (I've been using my U3 milling head as a drill press lately, so I don't need it).
    Thanks,
    Harvey
  2. Sjors,
    Here's my U3:
    I weighs about 20 pounds. Mainly Aluminum alloy parts. I believe the only plastic are the drive pulleys and the handwheels (and they make replacement Al handwheel)
    It's set up for milling some cannon carriages:
    And here's most of the accessories for it:
    I got it about 15 years ago for 50 dollars and an unused Dremel Tool. It came with the standard toolpost, 3 jaw and 4 jaw chucks, and a steady rest. Since then, I've had it refurbished, and added the milling post, milling vise, milling table and a compound angle toolpost.
    That said, I have a lot to learn about using the tools and setting up the machining operations to get what I want. But I'm enjoying myself-and that's the point, isn't it?
    Thanks,
    Harvey
  3. Sjors,
    I'll post some pictures later today. As Tony said, the Unimat 3 is one of the better lathes, but no longer available new. As far as the newest Unimats go, I agree, they aren't worth the trouble or money.
    I debated getting a Sherline. I've heard lots of good things about them, and are larger with more capability. I decided to keep the Unimat and add the milling head because
    a) I was familiar with it
    B) The total cash outlay was less (I already had the lathe)
    c) the overall footprint in my shop is smaller, and I will need to downsize in the near future
    Thanks,
    Harvey
  4. Looks good Jeff.
    Here's an idea. try soldering something like brass hoops to get a feel for how the soldering iron interacts with the flux, brass and solder. If you run out of brass, it's pretty easy to get. This will also help you understand the cleanliness required for soldering.
    One of the problems I had with the deadeyes is the heat from the soldering iron would scorch the deadeyes. I don't know of any way around it, but I do know too much heat too long on the joint will yield char-broiled deadeyes. Not very tasty, and not very appealing.
    Hope that helps.
    Thanks,
    Harvey
