desalgu
Posts posted by desalgu
Here's the stern framing after much sanding. I remember this part was tricky and I had trouble getting the stern frames aligned. It wasn't perfect, and required quite a bit of sanding. I used dremel for sanding to remove larger amounts of wood, and sanding blocks or sticks when I got close to what I wanted. I'll also attach a photo of the bow when ready to start planking.
- BenD, Overworked724 and Ryland Craze
- 3
Learning to do this build log. Looks as if I "reply" to add more. Here's the gunport sills and lintils. The last photo will show the oar ports. Up to this point, I remember everything being straightforward. My experience with with model airplanes, kits and scratch built, and I've built one model ship about 20 years ago.
I'm going to do a build log even though my model is nearing completion. If nothing else, it will remind me of what I've done, both good and bad. There are certainly a lot of areas I can improve on in the next build, which is yet to be determined. So here's the beginning with the frame, bulkheads, and spacing blocks. Spacing blocks were cut on table saw from scrap wood and make alignment super easy.
Hi Everyone, especially Chuck Passaro,
I've been retired a while and building model airplanes (electric rc park flyers - stick and tissue type). About 20 years ago I built a model ship, the Prince de Neufchatel, a ModelExpo kit. Back then, I went to local hobby shop to buy the kit, and just picked one I thought I could build. After building model airplane kits, I was disappointed with the kit, but proceeded to build it. I was working, so it took about 2 years to build the hull. Then it sat in the garage for about 10 years as work and other things interfered. Finally finished it, and at the time, said I'd never do another.
But now I'm retired and got tired of airplanes. Plus the FAA is imposing some regulations making it not quite as much fun. So after looking at some reviews online, I selected the US Syren kit. I didn't know about this web site and all the information on it, so proceeded along like I've always done. Now, 2 years later, I'm getting close to finishing it. Building the Syren has been a completely different experience from the first kit. Excellent instruction and plans, so well done Chuck Passaro!! Only slight disappointment was the usual rather poor metal fittings, blocks, etc. from ModelExpo, and I know that's to keep costs down. But I knew what to expect, so it was no big deal.
Several months back I discovered ModelShipWorld and it's amazing. I'm starting to take the time to participate now, and I'm a bit overwhelmed. Many thanks to everyone that posts build logs, articles, photos, etc. I wish I had found this before I started the Syren, but now I know about it. I'll create a build log for my Syren, so I can learn how to do it, and someone might be a little interested. However I've been humbled by what I've seen, and mine is hardly up to the quality of others. I'm sure I'll build another ship, and when I do, I'll start another build log. I'll also raise my standards and try to do better!
I will attempt to attach a snapshot of Syren as of today.
Thank you everyone!
- mbp521, Edwardkenway, Keithbrad80 and 6 others
- 9
Thanks so much for the links on how to get started on model ship world. There's so much information here, I'm a bit overwhelmed. I built mine based mostly on experience from the first boat many years ago and from model airplanes. I'm retired, so have no excuse for lack of time! But my eyes have gotten worse over the years from staring at computer screens, and it seems my thumbs are bigger than I remember.
I should have upgraded rigging and blocks like you did. I didn't discover Chuck's web site until I was too far along to change. I'm very impressed you tried carving the badges. I think they look great. I stuck with the metal ones and wasn't too happy with them. But they are small, and after you get everything else done, they don't show all that much. I also noticed you did the ships wheel. Those were real good decisions! I tried to find a wood color to paint the metal parts, but it's only so-so. Looking back, it's kind of funny I never thought of making my own replacements for some of the metal parts. The additional boat on the aft end is another wonderful addition. I did think about that and chickened out after doing the long boat.
One advantage I found is that the more details I add, the less you can see all the little mistakes I made. The rigging really distracts your eye away from hull and deck details. Of course, I know where I messed up, and there's a few things I couldn't hide. We can only try to do better next time!
Your comment about the ship getting taller and larger with masts is so true. I had the same feeling. And the display case being large is true. My first model was Prince de Neuchatel and the case ended up quite a bit larger than I expected. Syren is about the same size, a little less in width. I plan to put in LED strip lights in the top of the case which will let you see it a lot better. No lights in the first one, and the ship is too dark.
I'm sure you'll do better, but I had trouble with rigging bending the masts a little. It's hard to get enough tension, but not too much, and to balance it fore/aft and port/starboard. Both of my masts ended up with a lot more rake than they should have, and one is bent a little to the side at the top. I swear they were straight when I rigged them, so am wondering if humidity changed the tension or if I just overlooked it (most likely). The stays are real tricky. They are all interconnected, so pulling one loosens another. Drove me nuts! I finally get impatient, say it's good enough, and proceed onward. Otherwise, it would never get finished.
You've got a wonderful model! Can't say that enough. I felt rather humbled after looking at all your photos. And BTW, your photos are excellent also. I better get back to it. I'm working on the triple blocks for the lower yard sheets/tack/clew lines. I'll look into doing a build log of my version of Syren.
I'm new to model ship world forum. I'm getting toward the end of building US Syren, and it is also my 2nd model ship. I'm extremely impressed with yours!! Having been thru this myself, your workmanship is much better than mine. We did things a little different in places. I planked the bottom of the hull with walnut rather than copper. I just like the wood look. Most areas I painted like Chuck suggested, but I tweaked it a little. Love your hammocks in the netting. This has the side benefit of making those stronger.
I've been very impressed with instruction manual Chuck put together. Much better than first ship I built. I found a few belay numbers on plans or in manual that didn't seem right. Could be I couldn't find the ones he was talking about. I had to order extra rigging thread and extra 3/32 blocks. I gather this is common on ModelExpo kits. But there were extras for the laser cut parts and some of the metal parts. I like that you painted belay pins black. I left mine brass but yours look better. Awesome rope coils!! I'll have to look more closely to see how you did those.
You've also been making faster progress than I did. I just passed the 2 year point in Dec, and I'm close to starting the last chapter. I can only work on it so much before needing a break. My eyes get tired and I start going too fast and make mistakes. I also take several months off in the summer. I'm so impressed with how much you've done in less than a year, and the quality, amazing! I can only hope to get this good after a couple more models.
I have a bunch of pictures and thought about making a build log. Don't know how to start this or if anyone is interested in another US Syren log. Mine would mostly be pictures of what I've already done. Keep up the fantastic work!!
US Brig Syren by Desalgu - FINISHED - Model Shipways - 1:64
Here's pictures showing the start of planking. The first is the first wale plank. This is followed by the bulwards planking on the outside of the hull. I used Chuck's trick of using pencil along edge of planks so they show up later on. It worked great. I should have been more careful planking around the gun ports and oar ports, making sure everything was square and clean. This was the time to do it. I was not able to improve it later on. I had a hard time clamping around the bow. These clamps left marks in the planks that had to be sanded out or filled a little. Perhaps steaming them to get a little curvature beforehand would help, so you wouldn't need as much clamping force.
