DanielD
Posts posted by DanielD
  1. 52 minutes ago, jbcallender said:
    I am  just atarting the build of HMS  Terrror. I'm really enjoying your log.  I like the dirty weathered deck planking.  I am thinking of lightly brushing on charcoal powder to achieve that look.  Any thoughts on that?  Also did you darken the deck plank ends to simulate caulking?
    Welcome to the Terror club. The best part of this build for me was learning about the history of this wonderful ship and incorporating as much detail as I could. I wasn’t in a hurry to finish the build to just get it done, but more about the details I could add along the way, which took me two years. If this is up your alley, I strongly recommend the book HMS Terror: the design, fitting and voyages of the polar discovery ship, by Dr. Matthew Betts. I wish I had this when I started my build.
    As for your question…I used charcoal to darken the edges of each plank, all four edges. When in place you will see the dark lines that simulate caulking. I didn’t add any additional charcoal to the deck; however, after the deck was built I lightly sanded it before sealing with a satin finish. The act of sanding brings up some of the charcoal that was put on the edges of the planks, thus smearing small amounts across the deck which gives a slightly weathered gray look. If after all this you want to add more, it’s easy to dust additional on and rub it in…
    Be sure to check out clearway and keiths Terror version also. They were a lot of help!
  2. Good evening all, today was a day of tying up loose ends. My HMS Terror is nearly finished! My to-do list now consists of finishing the stand and building the last small boat, number 9 of 9 which I will be building on skis. The end of this build is in site and the start of my next adventure, the Amerigo Vespucci 1:100.
  3. Good afternoon mates. Today is problem solving day. The problem: my small ships hang from lines attached to the davits; however, my small ships are not heavy enough to weigh down the thread I’m using. This makes the display look, well…off or not believable. (1st picture)
    A solution was recently presented to me by KeithS, another Terror builder, to use some sort of weight to to straighten the lines (2nd and 3rd picture), then soak them with glue to make them stiff. Once the glue dries, maybe the lines will stay straight making the hanging ships more realistic. (4th picture) I used a 180g stone coaster as my weight.
    The 5th image is a before and after. I think KeithS solution works. Your thoughts?
  4. 1 hour ago, Keith S said:
    I was going to recommend that you try something with your boats on their davits. The little wooden ones are not heavy enough to hang from the falls properly, and I did spend some time thinking about it on my own model. I was going to either load some heavy items into the boats so that they stretch out the lines, or I was going to temporarily weigh them down and wick some thin CA or varnish or something into the lines so they stay straight. Either way, they would look much better if it appeared as though the boats were heavy.
    Keith, great to hear from you!
    I have been thinking about this very thing for some time. I think you might be on to something. I’ll give your idea a try!
  5. Good evening, today I had some time to finish the hardware (steel davits and hull protection bar and brackets) on the port side and get them installed on the ship.
    Next project, clean up the shipyard and build another small ship…which seems to take days to build 😊.
  6. And…a bit more work completed. Hung a small boat from the steel davits and tested the theory of the bracket and bar crafted in my previous post. Once the small boat swung freely from its davits, I pushed it up against the ship and sure enough, the rail protected the main ship from being damaged (second image).
  7. Good evening mates, todays project is a bit of a mystery; however, another modeler (KeithS) came up with a theory that makes a lot of logical sense. In the image below is this steel bracket that KeithS suggests mounts to a rod that protects the ship from a swaying small boat hanging on the davits in this area. The Terror is protected from swaying ships mounted to the wood davits at the stern by the main and mizzen mast shrouds. The steel davits I have added as described in historical literature are positioned away from the foremast shrouds putting the ship at risk. I have run with KeithS theory and crafted something similar…the second image below. And finally attached to the ship positioned to protect it from damage when I mount a small ship.
  8. Welcome everyone, it’s been a few days since my last post.
    As many of you know, when the Terror left England on her last voyage, she departed with two sets of steel or metal removable davits closer to the bow. Eventually, when the Terror took on supplies not long before she was last seen, the captain chose to send these steel davits back to England on the supply ships. Not sure exactly why…to save weight? To alter the ships performance?
    I have chosen to add this feature on my version of the Terror. Below is how this part of the project is going.
    I plan to hang a small boat on each side of the Terror from these metal davits, which counts for just two of the nine small boats that the Terror carried.
  9. 13 hours ago, clearway said:
    Coming along nicely Daniel- i am still debating as to have all the davits rigged with boats ready to be lowered or the whaleboats stored on the portside deck near the stern and the boats stowed with slings on the rear moat davits?
    Keith
    I hear you, I’m still trying to figure out what to do with the next four…but my goal is to have a representation of all nine small boats when finished.
  10. 11 hours ago, richardhd said:
    Sails and lines are looking great! Are they silkspan? I recall earlier in the log someone mentioning that silkspan can be difficult to obtain. Not sure if I’m remembering correctly.
    RichardHD, I thought about doing the sails in silkspan, but ultimately I hand sewed them from model ship sail cloth. Spent many hours designing the sails with the appropriate doublers and panel width, learning how to sew and use a sewing machine. In the end, while they look great, not sure it was worth all the time 😬.
  11. Good evening everyone. While I know I have at least a month of work remaining on the HMS Terror, I have been keeping an eye out for my next project. I more or less had decided on a couple of possibilities and the Admiral surprised me with one of my choices for our anniversary…the Amerigo Vespucci by OcCre 1:100. I will finish the Terror before starting the Vespucci, but I’m already ordering and thinking about all the upgrades 😬.
