modeller_masa
Everything posted by modeller_masa
  1. https://www.youtube.com/watch?v=IRvvVYMhZ2c Metallic paints have several different types. The differences among pigment, dye, mica, and metal powder determine the characteristic of metallic paints. This knowledge will help to adjust your metallic paint properly. --- I see. So the question is, what is a proper primer for 3D printed parts. I apologize for misunderstanding.
  2. https://www.scalemates.com/kits/heller-58899-le-soleil-royal--1365069 Is this the resolution you wanted?
  3. Thank you for your concern. The doctor said that it was not a big injury. I'm reading some unread books. I'm hoping to get back to work soon.
  4. I received the modeller's handbook. It was surprising that the book has a guide for Swift 1805. By the way, I got hit by a car last week. I was literally flown. Flying is always amazing. 🤪 I'll go rest a bit.
  5. It is a famous issue. You can read or buy the general planking technique instructions. Then you'll find that you can't apply the instructions to most kits because they have different hull-frame structures. The last step is manipulating the original planking technique to fit the weird structure of the kit. Many build logs and various modification methods will help the progress.
  6. Thank you for watching my project, Ronald. The oil pastel didn't penetrate the thin wood strips. The bulwark installation was tough work. I forgot to add wooden blocks under the edge of the deck plates. (Red arrows) I precisely pinned the bulwark panel to the deck. I drew guide lines using a marking gauge. This is the reason I didn't make holes on the deck planks. The transom part was easy work. I summarized the issues related to the bulwark component. I made some 3D printed guide parts for a bulwark installation. I'll use them in future projects. It is the first time I use the alcohol based ink. Masts and bowsprit. The alcohol inks penetrate wood very well, like the oil based stains. It is essential to apply wood sealer before I use the alcohol inks.
  7. Deck caulking. I used an wax oil crayon. It's really dirty, but it can't penetrate the wood layer. After massive sanding... Not clean, but weathering effect. I added protective masking tape before I did hull sanding. I made a sanding ball to sand concave deadwood area. But it didn't work well.... The sanding detailer is the only valid option in the progress. The brass rods reinforce slim keel parts. I roughly sanded the hull. I'm checking the hull line carefully to attach the wide bulwark part. 🔎 I watched all the Tally Ho videos before I started this project. I found that the garboard rabbet in this kit is different from the Tally Ho project. Tally Ho has a very smooth rabbet line, but this kit is not designed in that way. I don't know much more...
  8. Deck installation Upgraded display stand. Preparing deck planks. Building masts. I found my DIY ropes from last year's stashes. Better than original. Polishing and dyeing blocks. I used an alcohol ink and shellac. Cleats Blackening the brass parts. Tomorrow's work will be deck planking, bulwark, and sanding the hull. 😎
  9. My understanding of modeling and painting is growing as I build more models. I said that the weathering is covering a mistake a year ago. Now I make a flawed surface to build intended weathering effects. Control every mil and 0.01 millimeter.
  10. Thank you for watching my project. As much as I learn, I know more that I don't know.
  11. I filled all the large gaps before I applied a wood filler. After I finished planking, I removed all the plank battens. The next step is a deck installation. I warped the deck using a mini iron. The mini iron is really useful! It's over 300 W! Also, I'm studying about varnish. I want to make a clean and smooth surface, like a plastic model project. Is it time to abandon my favorite shellac?
  12. I can't believe it! Based on your previous build logs and the expert skills you have demonstrated, you should have gained experience with many kits and met good friends. I'm checking every corner when I turn and polishing my tech one by one. I wish I'll be at the level someday.
  13. Well... my rabbet and mortise doesn't work with this kit. 😪 I changed my plan and followed the AL manual. 4 belts x 4 planks Looking good. I used $9 mini iron only. Garboard First strake Wale Stealer Half my work has been done!
  14. I'm building a famous ship that has already been modeled many times. The 22110-N Swift kit is the cheapest intro line-up of the Artesania Latina. It is a two-masted schooner with simplified details, and has been renewed several times for 50 years. There are tons of American schooner kits with better details in the market. This post won't be a tutorial-like build log. I'm studying my building technique. I hope you skim my post quickly, and I'll be much obliged if you find any interesting point. 3-Dimentional error checking Fixing errors Plank battens This is a small ship. Temporary planks are done. The end of hull framing.
  15. Thank you for the kind words, schooner. I saw your 1/350 resin models. I'm not an American, but thank you for your service, captain!
  16. Before I started the final rigging work, I printed a rigging practice. The lines are lycra or spandex elastic threads from Infini models. All right. It seems good! A placing the railings was not easy work... See you tomorrow!
  17. It's finished now. I'll take pictures and videos tomorrow... 😪 USS Aries (PHM-5) is a museum ship in Missouri. These are my reference pages. NAVsource https://www.navsource.net/archives/12/1605.htm Tour videos https://www.youtube.com/watch?v=RIhwvKUIHco https://www.youtube.com/watch?v=w2ClX9Llzm8 https://www.youtube.com/watch?v=nNAqXiB5LN8 I started from printing a custom display stand for the boat. A new drill machine. I drilled all the windows and polished them one by one. Not the best windows... They are OHP films. I found that the Trumpeter's PE parts are not better than Flyhawk's. It is really difficult to fit the PE parts of the antenna tower. Designed and printed more parts. AND added handrail parts. They are 50% thicker than the real railings. The real railings are 3 inches thick. Better than the poor assembly of PE parts.
  18. There are some confusing points in the manual. It is better to check real photos everytime. The deluxe kit has two different sets of helipad net fences. Their shapes are a little bit different. Add this railing. It isn't in the kit. The two antenna masts are the most delicate and complex part in the kit. The 3D printed resin parts are flexible and vulnerable, so I had to be very careful. Don't forget the masts are straight when you attach ladders. This is my 2,094th mistaek... Not all the supports are removable. Always check real photos. The second mast is more complex. I forgot to add the C15. Ok... the last part is the radar assembly. 😬
  19. I've tested several acrylic (Plexiglass) cases. My final choice was an order-made case with 3mm thickness. I'll add 3D printed corner supports. Unfortunately, I measured the height wrong, so I ordered a new case. The price is $20.
  20. In my opinion, 1/700, 1/350, and 1/200 big scale models are different classes, like the boxing weight classes. I'm making many mistakes on 1/700 scale models, but they are not visible thanks to their small size. 1/200 scales have only a small tolerance to fold PE parts. I think 1/700 scale ship models are good for fast and easy introduction kits.
  21. Walkthrough #1 This is a really difficult kit. Most parts are interconnected with other vertical floors, including PE railings and stairs. I need to check every pages of the manual again and again to avoid a critical mistake.
  22. The next project is 1/700 Ticonderoga class cruiser USS Bunker Hill CG-52 1991 Gulf-war version from Flyhawk. Before I started the modern US Navy ship kit, I inspected a new acrylic paint set. AMMO ATOM is a brand-new 2024 water-based acrylic paint to compete with stronger environmental regulations. It appears to be the most recent and advanced high-quality paint set. However, the color selection of the ship color set is not suitable for ship models. (From 1950 to present US NAVY ships and submarines, Lifecolor CS-52) This is the closest color set to Snyder and shorts' paint chips I've ever seen. In this project, I used Lifecolor UA-655 and UA-656 colors. This kit has several tricky waterslide decals. I used a laser cutter to cut half-inch sized circles. Not bad... The burned edge of masking tape was very rough. Should I use my Silhouette CNC paper cutter? Deck and decals are done. Temporary assembly. I also made a custom handling grip. I can't build any Flyhawk kits without the handling grip.😎
