modeller_masa
NRG Member-
Everything posted by modeller_masa
The bowsprit is a tricky part. These build logs are different models, but they may help your project.
- 63 replies
- card
- Revenue Cutter
Thank you for kind comment, Jsk. I'll finish this kit this month. Whether I complete my kit or not, I'll keep enjoying watching your build log. I constantly suffered from the tiny parts of this kit. I had doubts that this kit's scale was misprinted. I thought the proper scale number was 1/100. Was Seahorse wrong? No. I have checked Doughty's plans and concluded that the original plan is a bit weird. The 31 ton plan seems likely to be an undersized 51 ton plan. They are almost identical. The 31 ton US revenue cutter was a miniature 51 ton RC. I understood that why they didn't want to build 31 ton cutters.
- 16 replies
- Revenue Cutter
- Seahorse
If the strips spring out like a spring, bend the wooden piece before attaching. With a little water and mini iron, you can bend wooden strips permanently. The instruciton video also shows the iron. Unfortunately, the CA coated wood strips are wasted. Use new strips. I recommend buying iron and a fast-drying Titebond III PVA bond for woodworking.
I'm rebooting the USRC after I digged into the ropewalk for a month. I finished one of the main mast now. I'll go to the HMS Wolf ZL029 when I'm ready. Mixing paint and running ropewalk is one of my preparations. I think I'll start it after spring vacation. Thanks for your interest, and I'll check your build log soon.
Long term CA vapors
modeller_masa replied to ricky86's topic in Building, Framing, Planking and plating a ships hull and deck
I've experienced that excessive CA glue "pond" lasted for a month. It is good to use a limited amount, and the CA applicator helps to control it. I remove CA glue with Q-tips. Also, thin and fast running CA glue tends to produce more vapor and an eye-hurting smell. It is one of reasons I prefer middle thick CA glue for woodworking. In addition, CA primer or accelerator harden CA glue in a second. -
I think the second planks are sapelle strips. (1) The best : Remove any unsuccessful planks and place a new strip tightly. It needs huge time and labour, but the best way to revive the ship. (2) Hiding : Fill the gaps with wood fillers and stain the entire hull. Find the most similar colored wood filler. My choice was mahogani colored wood filler from Timbermate. The colour should be matched with sapelle strips. And apply an oil based gel-stain. I used the Varathane oil based gel stain, cedar color. Warning - test before apply it. I bought 7 different colored wood fillers and 6 gel stains and tested various combinations to find the best result.
Jo Sonja is a sub brand of Chroma inc in Australia. Norwegian brand since 1974. It is one of the most famous acrylic paint brands in Korea. Almost all of Jo Sonja's acrylic paints have a soft body, so it is very easy to convert to airbrush ink. I didn't expect that the Renesans is a brand name before I posted. I've never heard of it. Most of the Jo Sonja paints are not transparent. It won't be a big issue because I'll airbrush them. I can control the amount of spray, and the result was pretty good in my previous experience. Thanks everyone for advices on paints.
I made some color conversion charts for Shipyard kits. Some colors were dried when I opened the kit, and some colors are not enough to paint the hull based on my previous experience. I mixed my Josonja acrylic paints to make the same color. The 100% color matching means nearly 100%, or 99% in reality. I don't need to be picky when I paint wooden grain patterns. By the way, some pre-printed patterns have different colors from the kit's acrylic paint. For example, the red strips above the picture are different colors. This chart will help if you want to paint bulwark in the same red color. Also, you can find more simple sail colors, such as the Josonja Background color series - Linen.
Thin or run-down CA glue is really hard to control. I prefer medium thick CA for wood working. https://next.henkel-adhesives.com/us/en/products/industrial-adhesives/central-pdp.html/loctite-sf-7452/BP000000153559.html Any CA accelerator or primer makes surface ready for 10 hours. Also, it works instantly and permanently. In my opinion, it is so strong that I don't have any chance to fix it.
This is a second attempt to make a thread unraveling machine. I added a thread tension unit (Red) that is used in sewing machines. The opposite side also has tension units. It will be a continuous thread unraveling machine. I printed the parts. It seems promising, but... The vibration exceeded my estimation. I added some counterbalance, but I found that the weight balancing should be very accurate to avoid the deadly vibration. Designing the automatic counterbalancer is beyond my ability. I understood why Domanoff didn't add the tension units to his rotating wheel. I completed the machine and tested it. It works, and I got Tex 3.5 Thread (equivalent to MARA or Serafil Ticket No. 840). It runs very slowly. The bobbin runs at 60 rpm. I'm out of ideas, so I'll take some rest. 😢
My long term mission is to build 1/200 HMS Victory with full details, like Lloyd McCaffery did. ( https://www.amazon.com/dp/0851774857/ ) It'll be a distant future 20 years later. My current goal is to build 1/48~1/72 common kits, such as galleons and ship of the line. Also, some 1/96~1/150 plastic kits are awaiting. To complete my current project, US Revenue Cutter 1/72, I use self-made ropes for every rigging, including 3/4" circumference rope for ensign staff and seizing. The smallest rope I can build is a 3-stranded rope with Amann Serafil Ticket No. 420 (or Tex 7). The three stranded rope has tex 21 (or ticket no.150), and real nominal diameter is 0.15mm or 0.006". I think it is fine because most ropes are 3" to 12" circumference, which are 0.50mm or 0.021" to 2.00mm or 0.083" nominal diameter at 1/72 scale. -------------- I studied about real rope and concluded that commercial model ropes are over-twisted. These are some samples of real ropes. 3 Stranded Z lay - Single yarn per strand S lay - Jute fiber 4 Stranded Z lay - 2 yarns per strand S lay 3 Stranded Z lay - 10 yarns per strand S lay 4 Stranded Z lay - 120 yarns with core per strand S lay - fiber Z lay 3 Stranded Z lay - 6 yarns per strand S lay 4 Stranded Z lay - 4 yarns per strands S lay - hemp fiber Z lay https://www.alamy.com/stock-photo-hemp-rope-rigging-hms-victory-portsmouth-historic-dockyard-england-31648539.html HMS Victory - White hemp rope 3 Stranded Z lay - Many yarns per strand S lay Here are model ropes. Amati 2.50mm rope Art.4125/25 3 Stranded Z lay - 10 Yarns per strand S lay - 3 yarns per yarn Z lay - Linen fiber S lay I can't find my Syren rope that I purchased with Rope Rocket. (Source : https://modelshipworld.com/topic/32140-rope-and-rigging-blocks-various-sizes-syren-model-ship-company/ 3 stranded Z lay - 3 yarns per strand S lay ( source : https://ropesofscale.com/products/polyester-tan-cable-laid-rope ) Rope of Scale - Polyester Tan - Cable-laid rope 3 Roped S lay - 3 Stranded Z lay - ? ------------------ I think the key difference between model and real ropes is the yarn on each strand. For example, Rope of Scale uses only 3 yarns on each strand. As a result, the texture of yarn is exaggerated. Also, the maker probably overtwisted the yarns so that the green lines aren't parallel to rope. On the contrary, HMS Victory's huge hemp rope uses 100 yarns on each strand. Also, the angle of the green lines is parallel to the rope. It means that yarns and strands are made 45' angle. The RoS rope wasn't because it was twisted strongly. You can find more examples with the search term "HMS Victory hammock netting." It looks like the hammock netting is made of 3 stranded rope with 6 yarns on each strand. Syren's rope shows an adequate angle that the green lines are almost parallel to the rope's direction. But, the yarns are so thick that they have an aggressive texture. I would say that Amati did pretty well. Although my first impression wasn't good because of its "flat texture," I think it is more realistic rope than RoS's sample picture. I don't know which rope is correct or wrong. I like the style of RoS, and Syren Rope Rocket's instruction also guided me to do that. I'm curious why commercial model ropes are different from the original ropes on real ships.
Yeah. It makes non-sense that the "continuous" machine can only work with larger size thread only, and offers only tiny bobbins to load. Thicker thread → The PL4 loads only limited amount, such as 10 meters or 30 feet. → Works well, but Rope rocket is also able to handle same amount of thicker thread at once. Thinner thread → The PL4 loads more than 100 meters or 400 feet. → Doesn't work. Rope rocket also works well with the thinner threads, but the capacity is limited. I can't help a topic about cored threads. I didn't try it because my biggest issue was making thinner rope. By the way, I don't know why I didn't see Bob Cleek's post a few hours ago.... ---- I'm sorry that I misunderstood the word take up bobbin. I modified or extended the PL4 machine to overcome my issue. I replaced the take up bobbin and related drive systems. There is a red LED digit in the center of the machine. The digit shows speed of the take up spool. Unfortunately, the modified machine is in my rooftop attic because I couldn't get a satisfying result from the machine.
It is interesting that animal oriented thread has relatively short life time. It may mean Vegan is the best. Hemp and Asian linen - I researched them long ago because they are common here. Unfortunately, they are too thick for model ship. Probably the linen is a good start to research natural fiber. Hello, Gregory. It is a good subject for thought. - Is realistic thread better for a scaled model? The first rope is not realistic and looks bulky. However, its sharper edge and high detailed texture appeal to the public who don't have deep knowledge. The third rope is more realistic. However, many people won't notice a significant difference between the second and third ropes. I sometimes paint scaled models in different colors. For example, I paint 1/700 ships a little brighter. I think I should use difference-size ropes when the color is darker - Scaled black rope looks smaller than white rope, although they have same thickness. Sometimes cheating eyes may result in a better scaled effect. And thank you for sharing the great lecture document. I already found some new ideas to improve my machine in the text.
Hello, Snug Harbor Johnny. I'm glad someone else uses the Syren's awesome machine. It is a really good choice to learn rope making. I moved to Domanoff's VR ropewalk because of the noise and handling. Here is my modification of the VR ropewalk. The Domanoff's VR ropewalk has a very weak stand, so I replaced it with 3D printed stand. I added the other things on my needs. I'm really satisfied with my modification. If you want zero-fuzzy polyester thread, I recommend Amann's serafil or leather work threads made in German. Their applications are leather wallet or shoes. I tried the heat method yesterday and found that my oven is broken! 😂 I use liquid shellac and dip thread in a dish.
Thanks for your advice, Dziadeczek. The one who claimed some issues regarding Domanoff's continuous ropewalk should be me. While thin linen thread has 40 lea = 70 tex = 40 Ticket No., according to the Amann Serafil's polyester thread series, I'm practicing with 420 ticket no. (=7 tex) Serafil thread for building the thinnest rope. The 7 tex poly thread is three times thinner than linen thread. Domanoff PL4 really works well with 10~40 ticket no. or 270~70 tex thread. When I go to thinner threads, such as 120~420 ticket no or 24~7 tex thread, too strong tension breaks the string. On the contrary, Syren' Rope Rocket structure machine can build every kind of rope. It is a reason I abandoned PL4 and use the Domanoff's VR ropewalk, which is a micro sized Rope Rocket. I've experienced that threads are really different by materials. It may be time to investigate various natural thread. Thanks for the recommandations. I'll try them as soon as possible.
Thanks for your kind advice, Jaager. I agree that the 2x3 method doesn't look good. Also, 1x3 isn't good with 3 stranded polyester thread, too. (The numbers are Ticket No.) I dulled the sharp edge by adding more yarn. (2x3 → 16x3) Lea or NeL is 300 yards per 1 lb of linen yarn. I converted it to tex size (40 lea = 66.14 tex) Also, linen can't produce infinite length fiber. It is a reason I stick to 7 tex polyester yarn. I didn't know how I should prepare specific ropes before I run 2x3, 4x3, and 4x4 progresses. I'll study them. 45' Angle - I got the hint from Youtube video. ( https://www.youtube.com/watch?v=toyOKOi0DsM ) I also want to try the natural fibers. Synthetic fiber has better physical specs, so I'm testing and learning about any kind of rope. The DMC cordonet special never could stand my experiment. There will be a time I try linen with a softer setting. By the way, I failed to adjust Domanoff PL4 - it's too delicate and can't use the 420 (Tex 7) polythread.
Before I ask a question, I would like to show my previous studies on rope making. This is a conventional ropewalk machine for model work. This setting uses 1 yarn to build 1 strand. Also, 1 rope has 3 strands. I'll say it is a 1x3 setting. This is a 2x3 setting. It uses 2 yarns to build 1 strand. In the same story, this is a 4x3 setting. This is a 4x4 setting. Ok, let's check real ropewalk machine. (Source : https://www.youtube.com/watch?v=Bquft1_ezIs ) I counted the holes. The machine uses 120 yarns to build 1 strands. The final rope is 4 stranded. In the same story, I'll say this is a 120 x 4 setting. To build the real rope, I unravelled a factory thread and re-ropewalked. The result is better than the others. However, I found that I couldn't compress the yarns anymore. I need the exact same machine that a real rope factory uses. In other words, I need to extract each yarn from a factory thread, and I also need a micro-sized ropewalk with 120 holes for the hair-thin yarns. It's a dead end of my study. I may need to change a mechanism. Is there a better ropewalk machine for model work? I'm using the Domanoff's VR ropewalk. Also, I'm looking for the synthetic polyester yarns (fiber). Extracting it from thread is time and labor consuming work.
