acaron41120
Everything posted by acaron41120
  1. When do you install the mast deadeyes? Rig it on each mast section then install the sections together or assemble the masts sections and then rig the deadeyes? Seems to me that installing the deadeye rigging before assembling the masts sections would be the better way as the fighting platforms (aka crows nests) wouldn't been the way. Thanks for your replies.
  2. Getting ready to stain the decks of the skipjack. What method do most use in applying stain? Stain , sand, 2nd coat of stain, steel woo; etc. And when finished should I use clear lacquer or should I use glaze? What's the difference?
  3. That's for the info. I'll have to check out some history and photos/paintings of the Skipjack. The scale of this kit is 7/16 inch =0.438 inches 1 ft which equates to roughly 1:190 or close to it. I think it'll be a fun build while I wait for the hull planks on the Golden Hind to dry.
  4. Received a Model Shipways Skipjack ship as a Christmas present. I will build it but I know nothing about quality of Model Shipways. Bad, good, in the middle of the road?
  5. Paul Ron. Yes. It's the reefers you show on your square rigged illustration (Item H). I thought they were tell-tales. Thank you. Again I'm learning which isn't bad for an old guy like me! Now the second half of the question is do any of you include these "reefs" on your sails? On many of my ship models, the plans show where these reefs would be attached but the instructions show how to sew these reefs onto the sail but never actually say to install them. It was these instructions that lead me to the question. Thank you all.
  6. On a sail, one side has some strips/ropes hanging downward on the forward side of the sail. It was supposedly used to tell the helmsman which direction the wind was blowing so they could adjust the sails to the optimum angle. I think they are called tells nowadays. So what were they called back in the age of sail and how many of you add these strips/ropes to the sails on your ships? Thanks for teaching me!
  7. Made it through Helene and Milton and now getting back to the Half Hull Tutorial. A friend asked me what was the biggest thing I learned so far and I told him that I was always under the impression that all the planks were straight/level the entire length of the hull which I now know is incorrect. So if I understand it correctly, a person building a plank on bulkhead kit will have to cut the straight planks into a more curved shape. For example a 7mm wide plank may be 7mm at the stern and be 4mm at the stem. Correct?
  8. I have started the NGR Half Hull Planking Tutorial and I now know where I was going wrong and misunderstood a lot from reading the books. If one waned to learn to plank a hull like they originally did I highly recommend this tutorial. It's money well spent. And even an old geezer like myself can understand it.
  9. Thanks Gregory for the education. Not quite ready to scratch build yet but slowly moving in that direction.
  10. When reading the instructions in the planking tutorial the components are the stem, stemson, keel, keelson, deadwood and stern post. But the Keel is one peace which makes me wonder if the actual shipwrights keel was one piece. I don't think so but that's how most kits are manufactured. (I don't know about scratch builders keels.) So were the actual ships built with a multi piece/section Keel or a single piece keel. Just wanting to learn more about this great hobby.
  11. Kit was made by Billing Boats. and has been discontinued years ago.
  12. Mark. I have read all the tutorials and one other that have all helped but none actually tell someone where to start the first plank. So I started searching through my other books and in one I actually found the answer. And I am happy to post here in the off chance someone else is having the same problem. From the book Ship Modeling Simplified, by Frank Mastini, page 36 “you must start the planking about one-half plank width below the deckline.”
  13. I am building a 1:50 scale Golden Hind kit. I want to plank the hull using the method shipbuilders of that time used. But I am confused as to where to start the upper plank. I have found that if I start the plank level with the deck, the plank will have to be forced into place (as in bent) to keep it level with the deck. However, all literature on the subject of planking states do not force the plank into position, rather let it take its natural flow. I thought a bit and realized no matter where I start, some planks will be full size at the forward end and have to be shaved to a point (which is wrong) at the rear end. Will starting the first plank along the frames where the plank stays level the entire length, bow to stern be best? Or am I overthinking it? I appreciate any suggestions.
  14. On the subject of the ship’s bell, was it normally located just aft of the main mast on the upper deck?
  15. Thanks for the replies. I now have several sources from you members to purchase silkspan. I’ll more than likely go with Brodak. Also I’m lookin forward to the Zoom session with NRG this Saturday morning.
  16. I also want to make sails for my ships but cannot find a source for silkspan. Who do you folks use to purchase silkspan?
  17. Great videos Chuck and planking techniques is great as well. As many modelers have a dislike for the garboard strake, a short video would greatly enhance the steps in the planking techniques. I know in y case I'd rather rig hundreds of masts than take an 8mm x 1.5mm x 550mm plank nd make it a garboard.
  18. Thanks everyone. I will continue on using the method I have been using as it turns out it was the correct method. I usually sand and fill using the sawdust from sanding with a mixture of the sawdust and glue which works much better than sanding down the commercial fillers that just don't seam to sand down enough. Before painting, I use a tack cloth and then add one light coat of sealer and follow up with the color of choice for my particular ship. For Mayflower, and the Golden Hind I will stain the hull with a quality stain and then paint from the waterline down flat white. Again thanks everyone for your help.
  19. Quick question on using sanding sealer. I have used it many times on ships whose hulls are painted with great success. But I'm unsure if I should use sanding sealer if I am staining the wood. I'm afraid that if I used sanding sealer then stained the wood, the stain would NOT soak into the wood s it should. Am I correct in my thinking?
  20. My neighbor lost part of his pecan tree. The only thing left was a 4 ft piece of the trunk which was in good condition. He cut that down and ground the stump. He knew I build wood model boats and asked if I wanted it. I said sure and have it in the back by my fence drying out. Now for my question. Is pecan a good wood to use in making a model boat? I have the plans of the Bluenose and I would like to try my first scratch build of the ship using pecan. What say ye master builders?
  21. Did the ships cannons on the starboard side line up directly across from the cannons on the port side? Also were the cannons set the same on a frigate/man-o-war located the same as say the Mayflower or Santa Maria etc.? Were they located that way from country to country or did it depend on which country built the ship? I've checked several model plans and Google and come up with everything lined up across from each other. Wanting to add some authenticity to my kit. Thanks for your help.
  22. druxey. Thank you sir. I never even thought of a rebate in the port frames but that does make sense. I see now how that would keep the port lids from swinging into the ship during inclement weather allowing the sea into the ship.
  23. Question on the hatches for the gun ports on a 16th century ship. Well all ships I guess. Did the hatches that covered the gun ports fit flush inside the port opening or did they overlap the opening a bit? Couldn’t find anything specific in any material I have. Thanks in advance for our assistance.
  24. I can't locate his grating kits in the syren website. Even tried searching for grating kits.
