drjeckl
2 Followers
About drjeckl
  • Birthday 06/30/1951
  • Gender
  • Location
    Long Island, NY
2,193 profile views
  1. Hi guys. Had to take a physical health break for a while. Getting a little better but probably won't begin to resume still for a couple of months. Thanks for the kind words...John
  2. He put the LN on hold and started building the Sphinx.
  3. I think the breeching line should have a connection to each of the side of the carriage, thru a ring-connected-to an-eyelet in the side of the carriage.
  4. Sorry, I was referring to Amati's FB location where I found around 20. Yeah, my point was only use that site to see things being accomplished, not necessarily how to do it. Have you gone through the https://modelshipworld.com/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ forum? Very good place to start. Plus YouTube. I did not taper my 1st plank. Just bookmark it. Not sure this was a good idea since all builds I've seen have this coming after the first planking. Not that your taking an alternate path may still work; it's only the 1st planking. But being a rookie, such as I am, taking alternate paths may lead to alternate destinations. Best to take the worn path. Here's something I cooked and posted in Kirby's LN log that may give you some idea, after you have a tapering plan, Post 19: Listen, I appreciate where you may have been a bit stand-offish after installing the bulkheads from taking the more difficult path, the 1st planking, and installed the frames. But at this point, you have no choice but to start it, so jump in. What's the worst thing that can happen? You eventually have to rip it and others off and have to start over? Happened to me and I'm sure others. But I got through it and I'm finished painting (2 coats primer, 3 coats of paint; photos not yet posted) my double-planked hull. Check some of my posts in the Framing,... forum. The best I like is: Yeah, I got around that. Again, all I'm saying is have a plan and then execute it. And don't stray to far from the worn path. You can do it.
  5. Jonathon, Welcome aboard MSW and to the LN builders. One caution on those Amati videos (there are about 20 of them). The guy doing the build, was Leon Griffiths from Model Shipyard, a master builder. I followed most of his techniques rather than those found here, to my detriment. After getting myself in a hole (needed to rip off the first 5 planks, port and starboard, of the first planking) the advice I got here straightened me out. What I'm saying is Leon didn't explain to the detail I needed and probably you will need also. I thoroughly read several times some of the experienced builder's LN logs, including Glenn's. Take your time and really understand what they writing about before you try it yourself. It will save you a lot of aggravation, which you have already experienced. I've been on medical leave since September but may get back into the big show in a month or so. But take a read on Freezing Parrott's LN Build log, post #2, where I gave him some places to go to get the information that I found extremely helpful. And poke about some of the other forums that deal with specific topics in the Shop Notes, Ship Modeling Tips, Techniques and Research section. And the best advice passed down to me here and I'll pass it to you is: Treat every single item you do (bulkhead, plank, etc.) as a separate project, and do your best on each of those projects, and you'll be fine. Good luck.
  6. Glenn, Here's a little tip I use when the construction manual is available on-line, preferably as a PDF. Pull it down into Acrobat and search (Ctl-F) for the text string you want to find. If it's there, it gets highlighted. It doesn't help if the only spot for that text is on the rigging plans, but if it's in the on-line manual, it at least may give you a start. The ship is looking pretty good. Keep up the good work.
  7. I'm building the LN, my first build, and I followed Vossie's log as my bible. I was also extremely disappointed that he dropped off this site; too bad.
  8. Did not specify; it was generic. And again, Allan, thanks for the background.
  9. Thank you gents, especially Mark, for the enlightenment; very interesting. Mastini shows two train tackles in addition to the side tackles and the breeching rope.
  10. Allan, Thanks for the update. Yes, still working on the LN. Maybe I'll just eliminate the training tackle. Could be why I don't see many of the modelers here show it. I just see those empty rings in the middle of the deck.
  11. Allan, Thanks for that. I must remember to be more specific phrasing my question. I've seen the frapping for the side tackles. I specifically was curious how the lines for the train tackles were stowed, since they cross a portion of the deck. Would they be frapped in the same manner as you show above? Thanks.
  12. What does this look like? I've mostly seen the Flemish coils.
  13. I finally got to prime the hull below the waterline on my Lady Nelson. I thought I had a pretty tight second planking but the grey primer shows that there were some gaps between planks, but it shows that the walnut planks provided with the kit are very porous. See below: Two questions: Is a second coat of primer needed? Should I fill in the gaps in the planks with filler? And then prime again or will the final coats of white be enough? I'm interested in seeing the wood through the waterline painting but not sure how it will look. Any appropriate photos out there? Thanks...jce
  14. Nice work on the waterway! And nice use of the outline of the false deck to work your margin plank. Coming along good.
