Posts posted by Matthew Kassebaum
Update for all following. Began cutting gun ports. After getting tired of cutting I did start to frame some in and as I did actually double plank the whole ship and it only calls for one I am backfilling each port with balsa that will bring it back to 1 plank depth. I have not started cutting on the other side. Each port is framed and back filled and then sanded flush with the hull.
- GrandpaPhil, WalrusGuy, clearway and 2 others
- 5
So as this is a learning process as well...in all my glory and pride of working soooooo hard on my planking....I forgot one....small...tiny....detail..............😤🤦♂️🤦♂️
So I have spent the last hour or two measuring..planning...drawing..and this is where I am. I did get this half lined up correctly which I am proud of considering. On to the front...and of course the other side. Then to clean up above the deck and make some sanding corrections and do some detail work with the wood file. Onward we go!
I had the same issue on my Billings Victory but mine was due to running 8 on one side and pulling it to that side. I pulled 6 and would only do 2 on a side then do 2 on the other and so forth.
- BLACK VIKING and mtaylor
- 2
- GrandpaPhil, mtaylor, gieb8688 and 2 others
- 5
Starting on the second layer of plank...😒..the row of pins along the side is how far down the second layer is now. This is a SERIOUS chore...but relaxing as well..IF you have the patience to do one plank..let it dry....and fit it. Anyone keeping track....this far....I have roughly just over 110 hours to this point. Slower than some..faster than others..but a Victory of this size...that is where I am.
Yes Gary that does explain alot. I struggled with the planking as this is my first. Fitting sanding..etc. As I said there are mistakes but I knew starting that I wanted to double it and It has given me a good learning base and the second layer is quite thin. When finished you probably wont even notice that its double planked by looking at it but it allows me learning...and fixing. Thanks for the follow Kevin. As Ive mentioned before you hopped on board feel free to chime in! This is my first so all are welcome!
Yes that all made sense and thank you for the input as it is always appreciated. I have made headway in this stormy sea. I am going to do a double plank. My first layer is on.....a little rough..but Im pleased for this being my first. My second layer is about half as thin....more like deck planks but twice as wide so about the same width as the hull planks provided by Billings so very workable. Ive discovered a love/ hate relationship with the old girl......learning as I go. I discovered mistakes as I went with the first planking..but its a strong base for the second layer. I do understand the advice of not making this a first build but I am patient and meticulous and trudging headlong into this stormy sea!!!🚣♂️
- GrandpaPhil, clearway, gieb8688 and 3 others
- 6
HMS Victory by Matthew Kassebaum - Billing Boats - First ship build
So this is where she sits as of now. Slow but steady. Have not started any on the top yet.
