JKC27
Everything posted by JKC27
  1. Glad I found this build log - I have this kit, just no idea when I will get to it. Hope I can make mine look even close to what you have going on. Great job! Our local museum is working on restoring an old Mossie, along with our Lancaster bomber.
  2. I tried tinkering with TinkerCad - seems OK. I'll have to look at Blender. Back in my mold design days (my area is a leading automotive, auto parts, mold making city) we used CadKey I believe, then were sent for training on (at the time) a high end 3D modelling software called Unigraphics. This is 25 years ago now, so my skills are non-existant (I left the industry in 2000), so I'd be starting from ground zero. I'd love to get into the CAD programs again, as I know you can import .pdf and maybe other type of files and use these to create 3D printable files, and also design fittings to be 3D printed for my models. I believe some of the .pdf blueprints I have may be able to be imported to certain programs, and then you can isolate a certain area and maybe create a 3D part/deck/etc..........I could be wrong on this.
  3. I will ask about yellow cedar as well, when I hit my local wood shop. This shop's old owners stocked basswood blocks, but the new owners only carried really rough cut 1x6, which is fine to stack together anyway. Basswood cuts with such fine dust it is quite messy, but easy to work with. It seems like I will stick with the wood hulls going forward, especially considering the size of my models (1/192 scale of a 740 ft ship is a large model). Plus, my woodworking skills will improve along with my shipbuilding.
  4. That was another concern I thought about. I thought of maybe adding some stabilizing framing (which would not be seen in the model). I like to toss new ideas around, and push myself to the next level. Unfortunately I do not have cross sections or lines drawings with the drawings that I am using for this build. Looks like it will be a hollow wood hull with mostly solid bow and stern shaped to the correct shapes. Going hollow will allow for the addition of deck lighting and running the wiring for the lights fore and aft. Hopefully my local wood shop that I got my basswood from before, still carries it (new owners), otherwise will have to find another option. As you said Roger, modern lake freighters are basically just a hollow rectangle for most of their length.
  5. I actually picked up a couple bricks of hard styrofoam (XPS expanded polystyrene) from a local Michael's - called CraftFOM https://www.floracraft.com/products/floracraft-foam-xps/ really light weight, looks easy to carve/shape - not sure how you'd adhere styrene or cardstock to it without it melting though. I haven't played around with these yet. The only reason I haven't is the concept of trying to make it a smooth surface to look like a steel hull......adhering styrene sheets to it with the proper glue would melt it (I am pretty sure at least).
  6. It's a single prop, 2 rudders. here are couple other pics I grabbed from the 'net.... Hard to see, but this is what she looks like. I really can't see a way of making the rudder/prop area with styrene.
  7. Sorry that I didn't post my last completed build and it's progress, or my latest that I am working on, but they are also great lakes freighters. My 2 builds (Algoma Strongfield - which has a build log on here) and it's fleetmate (Tim S Dool - no build log as mentioned above) were built from scratch at 1:200 and 1:192 scale respectively using basswood for their hulls. I like working with it as it's easy to shape and readily available, but a little pricey in my area. These are large ships, thus large models. As I evolve as a modeller, I am always thinking of different ways to make my builds easier, etc. A model with a solid basswood hull that is almost 48" long is heavy. For my next/current build I have been working on building the pilot house, accomodations, etc..... actually building an unloading boom too which is turning out good (I will post pics for this build and make a log - I promise!). I plan to add led lights on the masts, cabins, and maybe deck if all works out. This has led me to consider doing a hollow hull. Doing so with basswood or balsa (even if for just the sides) is simple enough, and would the stern as a solid block. Leaving the solid block would allow for me to shape area where the propeller would attach, and rudders. However......I thought it be rather simple to do the hull out of styrene sheets, easy to weld together, but......how would I go about that back end area (pic included in this post) with styrene? I am thinking that wouldn't be possible......maybe somehow attach a carved wood back end to hollow styrene hull????? Thoughts/suggestions???
  8. Been a while since I've been on here, but wanted to chime in on this. When this happened, right away media outlets were talking about this happening in the great lakes/seaway. Here in Windsor we have the Ambassador Bridge that connects Windsor, Ontario to Detroit, Mi - and the way it is designed/constructed (80+ years old now), there is no way a ship strike could happen, and the new bridge downriver that is almost complete, is also strike safe. The entity that oversees the St. Lawrence Seaway (all the locks, canals, etc.) also reassured the public that measures are in place to make sure this cannot happen.
  9. Hello and welcome aboard from a fellow Ontarian (?)
  10. The other style hatch cover that @Roger Pellett is mentioning that are used on the new US build Mark W Barker, as well as a few here one some Canadian lakers namely Spruceglen and Kaministiqua, are called McGregor hatches I believe? See these commonly on the "salties". Large hatch openings for large size cargoes, as opposed to the hatch farms typically seen on the boats that carry grain or taconite.
  11. How I just found this, I don't know, but I will say that this is breathtakingly amazing.........and RC even! Love the fittings, and the windows......top notch! Your attention to the minute details is just fantastic. This ship almost reminds me of the smaller versions we have on the great lakes, that carry petroleum related products. This type of ship is very close to my main interest, as well as style of build. Great job!
  12. Woodland Scenics makes nice dry rub lettering/numbering in different sizes/fonts. I used it white lettering on a dark blue background on my 2 builds (one is posted on here, the other I didn't do a log but will post pics when done). https://woodlandscenics.woodlandscenics.com/show/category/DecalLetters
  13. Thought this may be of interest to many folks on here. Thanks to my daily perusing of the good ol' www.boatnerd.com https://boatnerd.com/boatnerd-news-december-7-2023/
  14. Welcome aboard Deyson! Great resources here, and even greater people! I too took up the hobby when the pandemic first raised it's ugly head.
  15. For my current build, which I didn't create a build log for......sorry folks...... I am almost done, but need to print the company logo for each side of the stack as well as at the bow of the ship. I need the interior part mirrored, so it's facing the other way. The bear always faces forward, so the image below would be on the starboard side of the bow and stack. I need to rotate the interior only. I tried it with my previous build, but was unhappy with how it turned out and honestly took more time than it should have. I can't figure how to do it in paint, and I'm not well versed on this type of software. Resizing isn't an issue. Suggestions on how to best do this?
  16. Also.....just curious how the ship is mounted to the base or acrylic?
  17. Wow...this looks fantastic! Great job on this. Sure makes me want to explore this as a possibility for my lake freighters.
  18. Thanks Andy......I'm doing a model of the Tim S Dool and they have an anchor windlass for their single stern anchor on the boat deck I think. Is it close to this or should i just use one of these....
  19. How do you assemble this.....No instructions provided....
  20. Call me crazy, and I can't find it anywhere, but I am pretty sure I remember someone on here posted a while ago about making deck lights using a certain type of nail or pin, and just bending the head? Trying to replicate modern deck lights, just won't be illuminated of course. Anyone remember this????
  21. Looking great! I sure wish I had the capability/knowhow to 3D design/prints parts. Great attention to detail and again a build I a following closely.
  22. I think I am coming along with this one now. Never started a build log this time though, supposed I could and get caught up on that! Waiting on my prop and other fittings to arrive to make sure I don't have to make any adjustments before I sealing things. I did end up grabbing a can of the sanding sealer posted above and some find grit paper too. Been working on other parts of the ship and a Spitfire plane kit. Hoping I can get this ship done for the model show coming up in September!
  23. Never used it before..... might just have to give it a try
  24. Been having some PC issues, and time (not enough of it) issues...... I am working on another great lakes freighter. I am again using basswood for the hull, and it is coming along nicely. I am getting to the filling in any gouges, gaps, etc on the hull stage. Sanding and filling with wood filler. This time around, when I paint, I want my hull to have a much smoother appearance so the grains of the wood are not visible, giving it a look of steel (smooth). My other laker build (Algoma Strongfield) turned out pretty good, but upon close inspection it still looks like painted wood - could be the clear coat I used??? Any suggestions, tips....?
