Redshadowrider
Posts posted by Redshadowrider
I am thinking that I also have to keep the planking free from any obstruction between the bulwarks. That will avoid the occasional bulge if the plank hits it on the backside. I will see more when I test fit each bulwark. ...and, I have a wood carving chisel set on order. I think I will be ok. I just got nervous carving away wood. 😁
Now that the mistake was resolved, I have started the true next step, carving the bearding line. As you know, the bearding line along the bottom that it is difficult to carve without hitting the rabbet. It leaves me with a question in the intent. I know that the rabbet is a slot for the planking. Is the intent to remove enough material so that the planking is hitting the bulkheads only? If so, I can slide in bulkheads 2 at a time and sight between them to ensure clearance. I have done a search on it and still am confused a little.
As indicated, this is a newbie build reporting good and bad by the builder.. (me) I am hopeful to keep this to a minimum
NEWBIE Mistake #1 - Read a page ahead on next steps, and forgot to go back to the page I was on. Not a big deal as it has been resolved, but I need to be more careful.
I started gluing the stem knee on before I had carved the beard line. Probably not a big mistake, but it would have made carving much more difficult and possible damage to the stem knee. Caught it, cleaned both parts of the residual glue, and now moving on to the carving. (LOL...need some small chisels first though.)
Considering these: https://www.amazon.com/Power-Carving-Tools-Seven-Piece/dp/B0037MI3K2
ALSO - LOL on the jack stands... They are from Harbor Freight and have been recalled...due to the virus, just haven't taken them back in. 😁 Will sell cheap...
- WalrusGuy and Overworked724
- 2
Thanks guys, I am glad to be started. BTW, Overworked....we have lived in Glen Ellyn on two separate occasions.
That is some great work Walrus. We got back from seeing our new grandson, and I finally got started on mine. Your build log will be my go to for help, and pictures as it is a terrific resource. I started a build log from the view of a newbie. It will be more photos with some written content when required. After all, it is just my first. Keep up the great work.
- 2
I am going to attempt to create a build log that is somewhat different. It is intended to follow my first ship construction including both the good and bad that occurs. I have built and flown RC Aircraft for about 18 years now, and have some experience with wood construction. However, I know that what I am starting is quite different. I have to stop building planes since some are now so big, they barely fit in my pickup bed. That being said, I will gladly take advice and comments as I go along.
Since there are numerous build logs by experienced builders here, I will try to stay with a photo log and keep the writing to a minimum. It will be mostly from a newbie point of view any way, and I am not sure what tips and skills will convert from planes to ships. So here we go....
First, I needed to add some items to my tool box/bench. Not much need for a 9mm wrench, hex wrenches, or other larger tools. So I bought some diamond files, spring clamps in different sizes, and built my own building board that can be seen in the pictures. I used scrap wood I had laying around, added a lazy susan to be able to turn the model 360 degrees if needed. I built clamp devices that will allow me to turn over the build when I begin planking. To keep the table from spinning, I put in two blind nuts and a butterfly screw on each side. This will allow me to clamp it from either side so it will stay put.
Today, I was able to begin the first step.....
Hoist Anchor and get under way. 😃
- Matt D, Overworked724, Charley54 and 5 others
- 8
Can you point me to where I can find these pieces? I have found the site for obtaining the carronades. I am in the process of making a decision on buying them. After all it is my first build and while it may be the way to go, I have a lot to learn.
Maybe an easier way is to take a rolled piece of tape in each hand. Holding it between thumb and forefinger leaving a flattened part to push against the copper and backing. Then gently pull it apart leaving the copper on one side and the backing on the other. I would add pictures, but happen to be out of state seeing our new/first grand son. It might take some testing to see how it works. In the video, I just envision trying to separate the pieces by using the xacto knife as bending at least one corner on every copper plate.
Newbee here. Regarding the process of removing the adhesive backing from the copper Plates. We have a similar issue in the RC plane hobby with the covering materials. The covering has a thin layer of heat sensitive glue on the back, and then a layer of protective film on top. To separate the film from the covering we use tape like on the quarter round, but we also use tape on the colored film side. The tape attaches to the film backing on one side and the tape on the other side attaches to the colored film. This allows for an even pull to both protective backing, and the covering side.
I am thinking that placing the backing on a flat double taped surface With copper side up. Then using either a piece of 1/4 round to roll lightly over the copper, or a flat piece with tape to gently lift the copper plate off of the backing. It might help to protect the shape and detail of the copper intact. I am just thinking, and would try it, but I am miles away from even starting mine. -
Hi All, new builder here and am getting ready to build this beauty. I do not want to hijack this thread, but will be following along. I have been building rc airplanes for quite awhile now, but my garage is full of them hanging on the wall. I either needed to stop flying, or change what I build, so this was my choice. I hope to transfer my skills over to this hobby and am looking forward to following this build. If you want to point me elsewhere (since I am a new bee) I am open to that as well.
I am reading 3 different books: Planking techniques by Donald Dressel; Ship Modeling from Stem to Stern by Milton Roth; and How to Build First-Rate Ship Models from Kits by Ben Lankford. Also have almost completed my building board/keel clamp. Hope to be able to follow this thread and become more knowledgeable. Here is my building board... still a few things to complete, but it is mostly done.
oops....And the Chuck Passaro practicum.
US Brig Syren by Redshadowrider - Model Shipways - Scale 1:64 - First wooden ship build
This morning, I tried a different approach to carving along the bearding line. I think this will help me visualize what amount of wood I need to remove beyond what the different drawings show.
I removed 3 bulwarks from the laser cut template and used them to see where they fell along the bearding line. Since I started carving already, here is how I am using them. I took each bulwark and placed it on top of the hull at the spot where they will be glued into place. By doing this, I will be able to see where, and how much of the hull to remove along the bearding line. Time will tell if this works as I move forward and stern. (Tip...Just make sure you put the bulwark, in the right place for the visual.) 😉
