Redshadowrider
Posts posted by Redshadowrider
Fairing Underway
I have come to the point where I need to fair the hull and have done one side already and am started on the other. I read on a thread (I think someone following this build.) that they used a pain stirring stick with sandpaper glued on. I can say, from my view, this is a perfect tool for it. Just enough pressure to sand where needed, and the ability to have a little bend in it. This makes the bow to stern fairing task much easier than a solid sanding bar. (Newbie Opinion)
You can see in the picture the sanding bar, and the supports that I built for the building board. The arms that are being used have a long base that can be clamped into the board vises allowing for adjustment to fit the position of the bulkheads on different models. I have added a close up in case you are interested in how I built them. Add to that the lazy susan hardware, it makes for a convenient way to get to both sides without moving the whole model.
Newbie Error: (minor) Make sure to sand both sides of the bow fillers as the inside and the outside are needed. I forgot to sand the deck side and had to come back when the forms were glued in place. It's not difficult if you have a dremel and a small chisel, but you won't need either if you remember.
Still some sanding to do and it's on to Chapter 3......
Thanks for the answer and warning on the char problem. I will make sure to remove it before gluing. The Tung oil is delayed until tomorrow, so there is no rush. I can take time to make sanding is correct since all gluing is done and the hull is pretty solid.
Newbie Question: I have noticed that the adjustments to outside edge of the bulkheads appears to be mostly in the first 4 bulkheads and the last 3 or 4 at the stern. The plank then lies flat on the next several bulkheads until close to the stern where some adjustments begin again.
Am I seeing this correctly?
First plank being formed and dried in place for bow pattern. So far, it looks very good, with only a small amount of adjustments on the outside. Since I haven't done the inside yet, that will the the side with more work needed. Time for a break as I have a board meeting of the RC flying club that I belong to and I am waiting for the tung oil to arrive. In the picture, you can see the lower deck awaiting application of the tung oil.
- ccoyle, WalrusGuy and Overworked724
- 3
Bow filler blocks now in.. sanded, clamped and glued.
After they dry, I will undertake "fairing" of the hull. I should have the tung oil later today and will add first coat to the lower deck piece. For fairing, I think I like the idea of gluing a strip of sandpaper to a paint stirring stick, but am open to other ideas. As soon as the glue dries on the bow filler blocks, I will be adding bulkhead glue (CA) from the bottom. This will allow capillary action to solidify the bulkheads to the bulkhead former.
Obligatory pic:
Status Update
I tried to think of something to call this. I am retired, but Project Management still creeps back in. 😁
Last thing before a short break. .... well maybe, maybe not.
I have finished, except for the bow fillers, which come tomorrow. The instructions recommend that you shape them before gluing in, so that's doable. I have completed the lower deck, except for finish, and placement. I have decided on Tung Oil, as it just looks good on a wooden ship. Any way onto something I noticed in the instructions, and can easily lead to a little confusion.
Hull Fairing (Minor Point?)
...Page 7 - Line 5 / /Right hand column
Once all of the bulkheads are temporarily in position, you will fair the hull
..Page 8 - Caption underneath of the Bow Filler pictures
"It can not be emphasized enough how important it is to fair the hull properly. Check that a planking strip will lay flat across all bulkheads....."
As a newbie, and this build log, I consider this minor, but if this is your first time, you need to know. It seems you can choose to fair after putting in the bulkheads temporarily on page 7. Or wait until after all spacing blocks area glued in as on Page 8. I chose the second option on page 8. I am more comfortable fairing the hull with not a lot of movement in the bulkheads. So far I am glad that I waited.... In the picture, I have finished the spacer blocks, and the build of the lower deck. With things glued in place, I am personally more confident that things won't move during the fairing process. I have also taken an aircraft control rod and laid it along the center deck. I know it isn't a perfect use of it, but
it was narrow enough to fit between the bulwarks on the bow. Looks good to me. Next is using tung oil on the lower deck then gluing it in place. Until I get the tung oil (ordered today) I will shape and try fairing.
Thanks, I will give it a look.
After looking, there is no question, Tung Oil is the answer.
Thanks for the comment on the glue. I had forgotten that glue can present a problem. We don’t stain any part of our planes. 😀
Tung oil it is.
Question: I have been considering wood finish for planking and decks. There is Golden Oak Minwax as the instructions indicate, and another, Tung oil, that I have seen in other builds. I am going to have to order it anyway, so I have time and for input from y’all. Suggestions are welcome.... 😄
. Ready to start planking.
Whoa... 😄 just getting your attention. Ready to plank the lower deck at bulkhead 20.
I have all the bulkheads in place and all block spacers in, squared, and glued. You can see the last ones at the bow still under clamps. Now, I am going to wait 24 hours to let the glue dry. Then it's onward....
Process Note: During this step, I did a couple of things differently than instructions indicate (No, not that I am an expert, far from it.) However, I have read more than enough threads here to know that squaring the bulkheads is extremely important, so I took my time. However, I put in the bulkheads first (no glue) then began to square up with other sections as I added them. By not gluing the bulkheads to the bulkhead former, I was able to square ones that were off without twisting glued wood at the center. Each block has been squared, shaped and glued in even with no glue on the bulkheads. As you glue in each bulkhead, there is glue on the block on 3 sides. Bow and Stern sides are glued to 2 bulkheads as well as the former. I doubt they will move, but one more step I will add. Once all blocs are in, and the glue dried, I am going to come back on the underneath side and use the CA Applicator with extra thin CA and put some glue on each intersection of the bulkhead former and bulkhead. This should make it solid as a rock.... or good enough.
Newbie Error: Not quite a mistake, but a slight error. I couple of the spacing blocks are extended just above the bulkheads on the deck floor. I have a chisel that I can use to remove just a little without hitting the bulkhead. Try not to do this.. Luckily I have only 2 to clean up and it is not too difficult.
Just remembered something else. If you build your own building board, try to incorporate a base and lazy susan rotation hardware. I was really glad I had it when jumping from side to side on this part. Just remember to make it so you can lock it down at any angle.
Now the pics.
- Overworked724, Elijah and Ryland Craze
- 3
Thanks for the tip on sanding the high spots. With planking being so thin, It is probably a lot like the lite ply or balsa surface we need perfect before adding the covering on the planes I fly. I will do the once over before moving on.
As indicated, I had no 1X2 stock around, so I masked up and went to Lowes. (My second home, or maybe my first...just not sure.) Picked up some tite bond glue that dries clear and a 1"X2"x6' poplar strip and started. In the picture you can see the first 3 spacer blocks in place and clamped. I think sanding after they are in should take care for the fairing of the hull. Well time for lunch and drying the glue, will pick back up this afternoon.
- Ryland Craze, Overworked724, JpR62 and 2 others
- 5
Chapter 2 (continued):
Reading the instructions, it covers the process of “fairing” the bulkheads. It is to be done before gluing the spacer blocks and bulkheads in place. However, I am thinking that I am going to reverse the steps. Since I am going to square up each bulkhead as I glue it in place, there will be less of a chance that the bulkhead will move during the fairing process. Only 1 or 2 bulkheads were not square, and then, a very small amount, so I think the risk of an issue will be very small.
Well, I got the carving done on both the fore and aft bulkheads just now. Still a little to do to firm them up, as I still need to sand the inside of the bulwark. I may elect to go ahead and put in the spacing blocks, after "firming" up the hull. Doing the outside with the Dremel Sanding Disk is somewhat tedious, but that's part of the deal. We have those in RC flying, so I am ok with that. I now need some 1"X2" stock for the bulkhead spacers and I know that I have wood, but 1X2's is a size I haven't used much.
Process Note: If you have used a Dremel for work like this, I recommend it. I think it came out more accurate and was easier than using these "newbie" carving hands. I used, just a sanding disk for 95% of the work and it was a great set up, just by coincidence. The dremel sanding disk that has the replacement sandpaper disks makes it a good for the coincidences. 1. The sanding disk radius is the same radius as the thickness of the lite ply. It's almost like a router sander. However, since it is sandpaper you are replacing blades quite a bit. I used the cylinder type on only 1 bulkhead and it was the very first one at the bow. Most have small amounts wood removed that can be handled with the disk. The first one has the most wood to be removed. I started with a sanding cylinder and finished with the sanding disk. YMMV 😄
Here is a pic of the bow... still a little hard to see due to the wood coloring, but here it is.
- Overworked724, WalrusGuy and JpR62
- 3
Thanks Overworked. I don’t know how I would survive without my dremel when working on my planes. I am considering using a sanding disk rather than the wheel. You are correct about the wheel taking a large amount.
Will update with results.
Next step has been completed. All bulkheads have been placed in their proper positions. I am happy to report that only 1 or 2 did not sit at a 90 degree angle to the bulkhead former, but they are so close, the strengthening blocks that go in next will certainly take care of that.
Next step is to begin "carving" the bulwarks and bulkheads that need to be shaped. I have looked over them, I can see that once this is done, the bulkheads will line up correctly with the bearding line. I am sure some small adjustments will be required, but it doesn't appear to be a huge job ahead.
Process Question: The instructions indicate that I should "carve" the bulwark and bulkheads to shape them to the curve of the hull for planking. I am wondering if anyone has tried using a Dremel to sand the angles into each? It seems to me that I am just asking for a bulwark to break even with just a small amount of pressure.
Question on Bulkheads: In the Chapter 2 instructions, I have started going through the bulkhead fitting. At the same time, I am checking the alignment for bulkhead former to see how close to 90 degrees they are. Have completed sanding and fitting from the stern to the bulkhead that has a O ..with an X through it. The instructions say to face the numbered bulkheads to the stern and the lettered ones facing the bow. Does it matter with the O with an X in it? Stern or Bow? LOL
Thanks for reminding me about cutting off the keel overhang. I was going to ask and forgot to. All the pictures I have seen, show it is only about 1.5 to 2 inches past the stern. I will cut it back to avoid the inevitable accident I would have.
Keel and Knee Stem are in place, and glued. Just clamped up and now watching glue dry 😄
Cut the bulkheads from the light ply board and cleaned them up.
And thanks, Overworked, you are absolutely right about the next model. I did that a lot in the RC plane hobby, so It's something this house is familiar with. I have, I think, a total of 15 planes of flyable condition from 40" wingspan all the way up to 83" .. I had to start building smaller. 😁
NEX STEP: On to CHAPTER 2!
Thanks for adding your comment. Unfortunately, the rabbet was already glued in place, so I was unable to do it the way you suggested. Maybe next time. 😁
Progress Made
Although it is hard to see because of the color of the light ply, I have completed the bearding line on both starboard and port sides. It is now ready for the knee stem and keel.
Newbie tips: You can see in the pictures the tools that I used. Although the instructions show an x-acto knife being used, I found it a lot easier using a good chisel (pictured). I also used the emory board, and sanding stick in the hard to get places and I was pleased with the outcome. As far as the rubber bands and CA applicator, I recommend that you keep them handy along with extra thin CA in the applicator. You will and I mean will, at some point slice into the rabbet and you will need to pause to fix it. The CA applicator, and rubber bands make for a quick fix. (I know you don't have to ask how I know that.. ) 😉
- Ryland Craze, Charley54, JpR62 and 1 other
- 4
Finally I have started carving the bearding line. The pictures are of the stern portion on the port side. I did order and received the chisels that I noted in a previous post. I gotta say that a good chisel is worth it. I know those that I ordered are not top of the line, bu they came recommended. I have included two pictures, but details are hard to see. OHHH, for a macro-lense ....LOL
I will post again after completing the bearding line. both port and starboard sides.
First bearding line pics.
US Brig Syren by Redshadowrider - Model Shipways - Scale 1:64 - First wooden ship build
Thanks, Overworked, I am still waiting for the Tung oil. It’s supposed to come today, but if not I may have to reorder. Will have to see.
