marsalv
Everything posted by marsalv
  1. Thank you scrubyj427, the black wood is blackhornbeam, not ebony. Black hornbeam is a bit easier to work with than ebony . Installation of wales completed.
  2. I proceed by installing wales. I decided to glue the upper wale first - using a "guide" strip. Wale is connected using a scraph joint and the one in the front part is directly in the bend, which significantly complicated the accuracy of connection and gluing.
  3. I finally finished the internal planking to the deck clamp level.
  4. My posts have gotten me to the stage where the actual model building phase is, so now my posts won't be as frequent . The first part of the inner planking (the ceiling) is finished, including the limber boards.
  5. Thank you guys for all likes and nice comments. It's time for inside planking. The spirketting, which is made of two thicker planks, was installed first. These planks are slightly recessed below the level of the frames.
  6. Thanky you Applying the deck clamp strengthened the hull so I could complete the limber-passage.
  7. Gluing deck clamp, making temporary deck beams to check the location.
  8. Added keelson. This completes the basic hull skeleton.
  9. All the frames are in place, it's time to make the mounts for the stand screws. After gluing the keelson will not be visible.
  10. To contrecerf: In fact, these are square holes - limber-passage - see picture.
  11. To Hubac´s Historian: Thank you for nice comment, but be careful, we're just at the beginning (that was a joke ). The most beveled frames are done, the frames in the middle part don't have as much beveling anymore so it went a little faster.
  12. I decided to finish and fit the frames in the front and back of the model first - these frames require more beveling and I want to get this done as soon as possible.
  13. Making the hawse holes at this stage was a mistake, so I blinded them with a wooden plug and will drill them again after the planking.
  14. Thank you guys for nice comments and likes. I continue with the construction of hawse timbers.
