marsalv
NRG Member-
Everything posted by marsalv
L'Amarante by marsalv - 1:36 - POF
marsalv replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
To allanyed: Material used for this part is boxwood. The part is made using a cnc milling machine, which enables precise milling from both sides. The procedure can be seen in the photos in post 8. I continue with the construction of the wing transom. -
Thanks to all. Knee of the head. With Le Gros Ventre, I installed the knee of the head only on the already completely finished hull, which caused me a bit of a problem (the gap between the stem and the knee of the head). That's why I decided to make and attach the knee of the head already at this stage of the construction. In this case, the installation went without any problems. -
To tartane: - L´Amarante is sloop of war which was designed by J.L. Ollivier. There were three versions that differed only in decoration - La Palme, L´Anemone and L´Amarante. Some information about the ship's history is from the GD monograph - see photo. -
Hello everyone. Last year I successfully completed the construction of the Le Gros Ventre model according to Gerard Delacroix's monograph and I chose L'Amarante as the next model (also according to GD's monograph). I started the construction of the POF at the end of last year and will gradually publish photos from the construction process here. First, I made a jig for installing the individual frames on the keel and started assembling the keel.
Thank you guys for nice comments. To dvm27: some pictures from exhibitions you can find here: https://wchs-c-2023.eu/cz/zpravy/id:11385/mozaika-z-vystavy https://shipsofscale.com/sosforums/threads/naviga-c-from-czech-republic.12620/
- 589 replies
- le gros ventre
- cargo
Once again, thanks to everyone for the positive responses. The last two photos remain to be posted. This week I participated in the Class C World Championship (NAVIGA organization) where I received a gold medal for the Le Gros Venter model. I would like to take this opportunity to thank Mr. Gerard Delacrox for his technical support during the construction. My next model will again be according to Mr. Delacroix's plans - L'Amarante. marsalv
- 589 replies
- le gros ventre
- cargo
The construction came to an end after approx. 4600 hours. All that remains is to post a few last photos and thank all the followers for watching and commenting on the progress of the model construction. Thank you.
- 589 replies
- le gros ventre
- cargo
To botra288: the adjustable tabel is "homemade", but you can buy something similar here: https://www.renishaw.com/shop/Product.aspx?Product=R-PCA-135075-12-6 Finishing work continues on the larger boat.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys for compliments. To mtbediz - This is a normal slotting cutter, with only a reduced diameter of the shank to be used in the Proxxon milling machine. (https://www.uni-max.cz/produkty/drevoobrabeni/stopkove-nastroje/drazkovaci-frezy/dvoubrite-kratke/drazkovaci-freza-2br-6-19-8-mm) I continue with the second - bigger boat. Here I decided to make the frames from one piece only, because in the end the connection of the individual parts of the frames will be hidden under the floor and will not be visible.
- 589 replies
- le gros ventre
- cargo
HMS SUSSEX by KarenM - FINISHED - 1:48
marsalv replied to KarenM's topic in - Build logs for subjects built 1501 - 1750
Unbelievably beautiful work. Bravo. -
You're right, druxey. But after gluing a few planks on the ribs, the whole structure is strengthened and there are no problems with it. I finished the outer planking of the small boat. Now I will start on the frame of the larger boat.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To Kevin-the-lubber - The materials in the monograph are well prepared and provide all the important information for building the model. However, if any information is missing or there is any ambiguity, Gerard Delacroix (the author of the monograph) will be very willing and quick to answer the relevant questions. So the anchors are placed in their places, so to complete the model, all that remains is to make two boats.
- 589 replies
- le gros ventre
- cargo
Thank you guys for nice comments and all likes. To Strelok - my next project will be L´Amarante according to plan G. Delacroix. To dvm27 - The only advantage of my age (really the only one) is that I am now retired and therefore have plenty of time to build the model. But this does not mean that it is a full-time job - it is usually 3-4 hours a day. Preparation of anchors for hanging - buoy, fish strops.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
