marsalv
NRG Member-
Everything posted by marsalv
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To scrubbyj427: It is not possible to make all cuts in one pass. At first I tried to mill the figure gradually from all 4 sides - without much success. In the end, I decided to mill on only two sides and finish the details on the back and front by hand. I am satisfied with the result. Lower and upper cheeks.
- 589 replies
- le gros ventre
- cargo
Now it's time to finish the head, so I had to start producing a long-delayed component - a figurehead. Making a figure using a CNC milling machine was quite a challenge for me. You can now judge the result.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Forecastle guardrail is installed with iron stanchions. The stanchions for the gangway are double stanchions with a revolving branch.
- 589 replies
- le gros ventre
- cargo
To bruce d: Yes, I did - see the picture on the page nr. 10. The last items on the quaterdeck - the stationary blocks and fixation of the tiller.
- 589 replies
- le gros ventre
- cargo
Thank you guys for all the likes and nice comments. I continue with the installation of swivel guns.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you giampieroricci. I had the opportunity to see your L´Amarante model in Rijeka last year. Great model. L´Amarante will probably be my next model, so I will study your L´Amarante log afterwards. A few components on the quarterdeck have been added.
- 589 replies
- le gros ventre
- cargo
To druxey: I'm almost ashamed to say this, but the elliptical frame is made with a CNC milling machine. To Dowmer: Hinges are made of a brass tube 1.0 / 0.2 (ie. the inner diameter is 0.6 mm). A groove with a length of approx. 0.6 mm is milled into this tube with a 0.5 mm milling cutter, the tube is then cut to a length of approx. 1.2 mm. The 0.5 mm brass nail (0.5 mm brass wire can also be used) is bent at a right angle and the nail is inserted into the tube so that it fits into the notch. This assembly is soldered with silver solder.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
I needed cleats to complete the forecastle deck. I have now decided to make all the necessary types.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys. To Taner Yagci: This is line nr. 8 form the Plate 3 - Hull horizontal section - the widest part of the hull. I finished the belfry.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To Hsae: The square holes are made with small diameter milling bit (0,5 mm) and the rest with file. To popash42: I am using VCarve Desktop software for CNC milling. As regards Laser Engraver, I´m not sure, but the VCarve Desktop is propably not primarily intended for laser. You can find information on the optional laser add-on module on the Vectric website (https://www.vectric.com/products/laser-module). Pinrails.
- 589 replies
- le gros ventre
- cargo
