marsalv
Everything posted by marsalv
  1. Thank you guys for very nice comments. Preparing to make these blocks was quite a challenge for me. But the result exceeded all my expectations. Uncritically, I have to admit that I myself am very satisfied with the result.. To Hsae - The blocks are made with a CNC milling machine, not from Proxxon, but a commonly available Chinese milling machine. The material for the blocks is pear. The construction of the model moved to the next stage - rigging. I start by attaching the bowsprit.
  2. A few more "special" blocks remain to be made before I start rigging.
  3. Thank you guys for nice comments. Now it's time to make the yards.
  4. To No Idea: As garyshipwrighter partially answered you, the small blocks are intended as a stop for gammoning and collars (fore stay, fore preventer stay, inner and outer bobstay) - see enclosed picture. I finished all the masts and tried installing them on the model.
  5. Hi Richard, I will be very happy to follow your construction. In the 1:24 scale, a truly impressive model will be created. Will you be building just the hull or the whole model?
  6. To Hubac´s Historian: Chain segments are soldered with silver solder paste. Using solder paste instead of solid solder has the advantage that it is possible to dispense a really minimal amount of solder onto the soldered joint. In places where a really minimal amount is needed, it helps to first heat the soldering parts with a flame and only then dose the solder paste. The solder spreads when it touches a heated area, which makes dosing easier. To Richard Dunn: I am going to rig my model, but only rigging without sails. To Daniel.b: I only have one stepper motor (x-axis) attached to the MF70, so it doesn't work like a real CNC machine. I only use it for x-axis scrolling (on/off switch). For these purposes, I have made a simple driver to control the stepper motor (i.e. without connecting to a PC). Topmast deadeyes and futtock-plates. Tops are completed.
  7. To robert952: This is not a pill container. These are plastic cups intended for paints, which can be advantageously used for storing small things - see link: https://www.sevt.cz/produkt/kelimek-plastovy-primo-7-6-ml-25040400820/ https://www.sevt.cz/produkt/kelimek-plastovy-primo-3-75-ml-25041501850/
  8. Fantastic and inspiring work. Have you tried using silver solder paste instead of solid solder for silver soldering? Dosing solder paste is much easier, even when adding a small amount.
  9. Small adjustments to the masts, preparation of parts for the masts and tops - fishes, crosstrees, trestletrees, cheeks, caps.
  10. I finally finished installing channels, deadeyes and chains after a long time.
  11. Thank your guys for all likes and comments. I continue with channels.
  12. Very nice and clean work. I have a question. How is the blackening of brass achieved? Just painting it with tung oil? marsalv
  13. Deadeyes. Most modelers make deadeyes using a lathe. I tried a new method (at least for me) of production using a CNC milling machine.
  14. Thank you No Idea. The last decoration is added at the end of the mainrail and the head is completely finished. Next parts will be channels, chains, deadeyes etc.
  15. Thank you guys. I continue with seats of easy, filling peace (in front of the gammoning) and boomkins.
  16. Thanks for all comments and likes. The front part of the model is practically done except for a few details.
  17. Thank you guys. I continue with making of gratings - to be continued...
