Posts posted by jct
Well finally some progress on the new nests...as I stated in a previous entry I wasn't happy with the symmetry on my original scratch build nests, so I tore them down. I decided to do something closer to what I'd seen in pics of the HM replica, so with that in mind I started rooting through the wood box and came up with some of the super bendy beech that the rails were made of this was split to a thinner profile, sanded and treated to some bending. I made 4 circles, two for each mast, fore and main. I bent some material for the stanchions and treated it to a ride through the band saw getting two for one. Next came some layout based on the diameters of the bases, still attached to the masts, and the new tops, once complete this showed where the stanchions had to be cut for everything to align. All the stanchions were then cut to size and ganged sanded to final size, from there it was just a matter of gluing everything up. The nest still need finish sanded and they will get painted red and mounted to the bases...pics follow.
THX for your interest
J
- maso, WackoWolf, popeye the sailor and 5 others
- 8
the good stuff just keeps coming...your deck furniture is superb sir, well done
J
Rudder looks good and your work on the companion way is over the top, looks really fine. Your craftsman's ship shines, I really like the mixture of woods your using.
J
Haven't posted any updates in a while...had the mast almost complete and really started taking a hard look at them...not happy with the crows nests. The octagon shape just wasn't symmetrical enough and looked really bad. I suspect it would have looked worse as the rigging began, just calling attention to it, so I've stripped off the nest and will scratch something once I've figure what I want to do.
I wouldn't call it a solution... I resorted to paint
Rudder looks fine in place, I've had the same issue with the blackening chemical, you may have hit on it though, perhaps it should be sealed prior to handling?
Amazing work...I too look forward to the new log, I may be tempted to follow along and build a little one of my own, very nice, thanks for sharing.
J
Nice gonna look good mounted to the hull, keep up the fine work
I hear that, I have used this technique after the feline attack on my Enterprise and it worked surprisingly well and has held up over the years so I'm thinking it should be ok...time will tell
May finish the fix this evening
- pete48, SGraham and popeye the sailor
- 3
THX Popeye,
I have got the wooldings applied to the fore and main but the masts are fighting back a bit...the main top has warped after being fixed to the mast cap never saw that one coming...figured the dowels would be fine after they were shaped...guess I should have sealed each individual piece prior to assembly?? I'll figure something out...when I do I'll post some pics of the solution...thinking maybe kerfing the mast and bending after some ca, or cutting and pining the half's...don't know but you'll know when I do :P may have some new pics tomorrow...been nuts at the salt mine.
THX
J
Steve...really sorry to hear of your spouses health problems, my best goes out to you all. Nice work on the saw
J
Thank you Pete and Danial for your kind comments, there are glitches here and there but overall I am fairly pleased with the results so far. Thx again
J
HALF MOON by jct - FINISHED - Corel
Thanks Steve and Pete for your kind comments, No heat was applied the beech was soaked in water, I'm still amazed at how easy that materiel is to bend, this build is my first experience at bending wood at this scale and with using beech, it's fast becoming one of my favorite woods
