Lieste
Members-
Everything posted by Lieste
Windage ratios are not universally geometric progressions as used by the British with Bogard/Armstrong/Armstrong-Frederick. The French Manson pattern (extended by the 1820 30 livres) had quantised windage for 36/30/24/18/12/8/6/4 livre guns as 30/27/27/24/21/21/18/18 pts with 1 livre seeming to be defined a little higher. (these windages for the boulet, appear to be for the middle of the forges gauge (+/-3 pts) with the places gauge between (+3/-6) pts (same high/smaller low gauge). This is a windage proportion a little tighter than the 20/21 definition for the AF low gauge (with 1/3rd allowed for the high gauge within this interval) (roughly 24.5/25.5 mean) for the larger calibres, but significantly looser than the British stated standard for the smaller natures. It would be unusual for 'same service' windage allowances to substantially increase for smaller calibres, but I would note that the French land service pattern for shot is a tighter windage definition than the corrosion tolerant naval allowances - the same shot manufacturing techniques (and perhaps (aside from 16livre/18livre calibre differences) the same moulds) but are gauged according to use with a differing degree of hammer finishing and the same 6pt tolerance between gauges with different gauges for the two services. It would be possible to see a larger shot defined for the land service guns than in naval stores - and by inappropriate data combination see an anomalously tight windage for 'say' the 12livre gun (Land patterns are given to the high gauge, apparently, with 15pts allowance - equivalent to the naval 18pts - for 12, 8, 6, 4, 3 livre gun patterns. - the 16 livre and 24 livre patterns of siege/garrison artillery have looser gauges)
Mixing of bore and shot calibre/diameter is quite common, even in quite respected sources, such as the many works of Dr Summerfield. He has at least a few tables where the smaller guns are misreported. Even where 'a diameter' of shot is correctly stated it must also be remembered that there are national and period differences in what this 'boulet diametre' represents - It can be a mean gauge from the forges, a low gauge (with a mean and high gauge larger than the nominal), the high gauge (with the mean and low gauge smaller than the nominal) or a mean gauges of the places - the average of the high gauge and the unserviceable gauge. This can materially change the weight of the shot and the comparison of the windage proportions between different pieces - especially if you prefer to converge disparate data sets to a common standard (e.g the mean gauge of reception at places)
A 32pdr ball from the Blomefield pattern gun at the (late) middle gauge and with the turn of the century Waltham Abbey cylinder milled powder should still be sonic at about 500m. Smaller bore guns tended to be longer, relatively and could have significantly higher muzzle velocity, but lose velocity slightly more rapidly. 24pdr 9.5ft also around 500m, and the 18pdr 9ft a bit less ~475m, while the 12pdr 9ft is sonic at about 425m. The later 58cwt gun is slightly 'more' by virtue of its lower windage, but not by enough to render the very popular 55cwt guns obsolescent. Carronades are high subsonic (and with a few of the lighter rebore patterns of guns being roughly sonic at the muzzle). Muzzle velocity is expected to be above 500m/s for all of these guns rising as the calibre falls to about 540m/s for the 12pdr. (Sonic ~340m/s) (explicit muzzle velocity measured by Navez on an electro-chronograph for the 24pdr is 1720 ft/s, using the later shot and the standard military powder made up from high quality new powder mixed with small proportions of recovered powder to moderate the velocity to provide a maximised consistency of power) French powders are weaker, especially early on, though they recover most of the deficit in power between 1827 (where they are testing with Pont de Buis hammer milled powder) and 1843 (where they have a cylinder milled powder from Ripault in their testing programmes). There is still a small deficit recorded between French powder of 1860 (noted by the French as being the same as Ripault/1843) and 70 year old Waltham Abbey powder, when tested by Lt Mordecai of the USN. French guns have a narrow spread between their high and low gauges and use a higher line of metal to get a slightly longer but-en-blanc along the metal and marginally more consistency. Even with the much weaker powders indicated from their 1808 and 1811 gunnery manual their artillery is supersonic at the muzzle and for a few hundred metres downrange. The velocity deficit by the 1840s is on the order of a few percent, and not a critical difference - pointing is also detached from the line of metal with the universal provision of tangent sights.
The energy delivered to a target by the shock/wake system is of the same order as the energy loss due to drag over a short distance... which is fairly trivial for most practical cases especially when taken over an 'edge' rather than the total loss integrated around the entire surface. OTOH the blunt trauma from a 'spent' projectile incapable of perforating a blanket or cloak was sufficient to pulverise the rib cage and internal organs of a sleeping soldier in the lines of contravallation. He was found dead with no external wound, beyond a contusion where the rolling shot had hit him, and the shot lodged neatly in the hood of his cloak. Others lost feet 'stopping' spent shot rolling slowly over the ground. There is also of course a significant concentration of momentum in the muzzle field gasses - amounting to about 35-50% of the shot momentum, so blast injuries in the immediate vicinity of the gun is probable (combination of the bulk motion of the restrained propellant gasses to muzzle exit and the 'nozzle' expansion of the gasses after the shot clears plus an amount of blow-by ~ around 10% of the additional momentum is from the losses between shot and bore, but this does reduce the 'additional' work from *after* muzzle exit... (Similar claims made about the 50 BMG can be demonstrated false by firing (from outside the muzzle field) between the triangles formed by a House of Cards - the wake/shock doesn't disturb the cards, and a hit (even a very glancing one) is required to knock them down).
Sometimes the ship is commissioned into the cruising fleet 'as is' after repair if needed - HMS surprise (ex L'Unite corvette) was still armed with her French 8 Livre and 4 Livre guns when she sailed to Jamaica in 1796. On arrival at Plymouth in 1798 she was remasted, her spardeck bulwarks were built up, French guns removed and the plan was for British equivalents to replace them (9 pdr, 4 pdr guns 12 pdr carronades... but the Admiralty was persuaded to replace them with a carronade heavy armament of 32pdr and 18pdr carronades (and either a 4pdr or 6pdr chase gun pair). Things could be similar for the French too.. 2 of the French fleet at Trafalgar were previously British ships and still carried their British guns. For rigging, even if the sticks are the original foreign materials, the rigging might be adapted towards normal national practice, during repairs or while otherwise idle.
Are you sure they aren't removable, rather than hinged lids? This type could be rigged when the guns were stowed alongside the bulkhead (or have muzzle cutouts and a split cover design if the guns were stowed run-out) and usefully increase freeboard, but were stored below when cleared for action. This is also a common variant for 'open' waist ports on frigates or ships of the line where they aren't fitted with hinged ports.
Scout was a 1915 predecessor to the 1916 Pup. They aren't the same airframes, and the most closely related was the 1 1/2 Strutter (of which the Pup was the diminutive offspring - to the annoyance of the Admiralty) Pup is 8.3m span, Scout was 7.49m, length Pup 5.89m, Scout 6.3m. Scout uses the 80 Hp Gnome monosoupape, while the Pup often uses the Le Rhone 9C 80Hp as one of it's engine options.
The contemporary definition for these things is instructive. Thickstuff comes from the full depth of the tree, and is sawn to thicknesses of 4.5-12" Width is cut to suit when used. Plank is over 11" wide, and over 1.5" thick (but less than 4") Deal is around 9" wide and 1.5-4" thick Batten is 6-7" wide, 2.5" or under. Board is under 1.5" Deal lengths are typically 12ft, but these dimensions can all vary with the source of the material. (Ends are short lengths under 8', rather than the full length of a standard load.) A load is 50cu ft of finished timber, 40cu ft of rough timber. When worked the finished weight of a hull is about half of the timber used in her construction. Roughly. Finished loaded displacements hover near the rough weight of the timber expended in their construction (depending on hull form being comparable to a full bodied frigate or ship of the line.) - a mix of masting, rigging, anchors, guns and ordnance stores, crew and stores, and whatever cargo/passengers are substituted for some of that.
3D Naval Guns 1850s ~ 1870s
Lieste replied to JerryTodd's topic in CAD and 3D Modelling/Drafting Plans with Software
The 'taller' block trail carriage is dimensioned as 989mm to the top of cheeks (526+323+140), while the 'longer, sleeker' one is a little over 940mm (890 +50 for the rise of the lower edge ahead of the truck - it is 450mm above the breast). Both are for 22cm no1 guns of 1842, 1841 and for different vessels. I believe the taller carriage may be the standard 'tween decks' (lower battery) carriage, while the (very slightly) longer and lower one is intended for the spar deck of paddle steamers. As the model is a paddle steamer, this is likely to be the proper design, if not on a double pivot. -
In particular - the anspect (levers) for this carriage type have a little roller allowing them to form a 'rear wheel' for when running the guns in or out. Those for truck carriages for earlier patterns of guns just bear the rounded end on the deck to shift the carriage about. -
The PDF is a lower res than the online 'zoom-view' where you can easily read dimensioning etc. I have offline copies, but will go onto BNF to get a better view of plates (and some tables). They have a variety of other texts as well, but Lafay is one of the more and better illustrated. The online browsing can sometimes be a bit glitchy though. Being able to zoom at higher resolution is useful for an inset part of a larger plate, which can otherwise be obscure. There is a plethora of French pattern instruments and gunner's materials in the plates too. Not sure how early these patterns would extend, as Lafay is c. 1848 with some last minute additions. Most should go back to the 1837 regulations (unless specifically dated after that) -
That one is in Lafay too - a few plates after the 'taller' 1840 no1 carriage. Plt 17 lower -
Douglas 1855 has some drawings of a pivot and a (very flat) block trail carriage for the 1842 no1. In line at art 221 Also, try Lafay at BNF https://gallica.bnf.fr/ark:/12148/bpt6k9737980n/f789.item.r=lafay artillerie Several different block trail carriages and also pivots for the obusiers. (Also the later mod of the truck carriages, braque fixee for the caronade, embarkations etc) In the end plates. -
They are parallel to the sheer of the deck to allow the gun to train without restricting depression or elevation at the extremes. The sides are parallel to the frames, which may not be perpendicular to the waterline. This results in each port having a different (non-rectangular) shape in practice, this is fairly minor except right forward and aft, but there is a reason each gun, carriage and port-cover was specific to a particular port.
The double thimble sounds like a modification to the seized breeching at the breeching rings paased through the side. Each end of the breeching, seized to a 'thimble and hook' in the bight, can then be detached at will, rather than being reeved through the breeching loop after the seizing is unpicked. The gun and carriage can then be shifted without removing the breeching from it. (looking at the definition of a 'Gripe' and extending it to a 'double thimble', rather than dead-eye and thimble) The earlier Contsplice could of course be pulled from the gun when needed, allowit it to be shifted, but the breeching, seized to the side would need to be shifted also, or substituted in the new place. A slightly later modification to the breeching loop allows it to be interrupted with a shackle to close the gap to restrain the breeching. If this is correct, then the contsplice is still needed for non-looped ordnance, with the double thimble being a convenience for looped guns which don't have a shackle opening, and more generally for ease of shifting or striking/removal of guns.
While all* new guns (from the 1790s) were cast to Blomefield pattern with the breeching loop, the ordnance wharves had a mix of these new cast guns and older Armstrong Frederick Pattern natures, which had a simple cascable and button requiring a C*** splice on the breeching. (*Except for the Gover 24 pdr, the Congreve guns and such ordnance proofed guns for the HEIC, HWIC and Hudson Bay vessels as were approved - which were often contract guns, only tested for proof, marked and supplied onward). The carriage suitable to the gun and it's intended port and the tackle suited to the gun and carriages were supplied with each gun. **By the 1830s the new patterns of guns started to be issued, with Victorian guns including patterns over the next few decades including those from Dundas, Dickson, Millar and Monk, as well as repurposed and bored up Blomefield patterns as a rapid expedient.
HMS Victory wales (position)
Lieste replied to Seren's topic in Building, Framing, Planking and plating a ships hull and deck
Recall that the wale is thickstuff, and as such increases the maximum beam. Even if the wale is very slightly above the widest part of the frame. It is also possible the frame has the balance slightly off. -
As with the Boynes and the Oceans there can be several distinct classes separated by a decade or two. The Edgar is ordered to a modified Arrogant design after the older 64 Edgar was scuttled - elsewhere there are examples of ships merely being renamed to free up the name for a new vessel. As the Edgar group of the modified Arrogant class has revised lines and is temporarily distinct from the two 7YW Arrogant ships it is not unreasonable to refer to it as either an Edgar class, the Edgar group or follow ons in the modified Arrogant class... I see no issue with the use of Group or Class for the Edgar and her sisters as they are established differently to the first pair.
It is how Rif Winfield lists the classes... BELLONA Class. Thomas Slade design approved 31.1.1758. Five ships were built to this draught. ARROGANT (or Modified BELLONA) Class. Thomas Slade design approved 26.1.1759. Two ships were built to this draught during the Seven Years War, but Cornwall was scuttled in 1780. A further ten ships were built from 1773 onwards. EDGAR (or Modified ARROGANT) Class. Revived design of 1774, slightly modified from Slade’s (Seven Years War) original Arrogant design and approved 25.8.1774 It is not a direct follow-on, but modifies the lines. This is commonly enough to generate a new class - as with the Boyne class of 1801, which would otherwise rate alongside Victory in 1807 as 98 gun ships of the second rate. (Originally started as 100 gun first rates, again, alongside Victory at that earlier date/rate). There is a degree of arbitrariness in the naming of classes - as with the Armada class (or forty thieves), while the lead ship 'Vindictive' had been on order for almost 9 months when the design was approved, and Armada was only in the third group of orders.
Some of the large ex-French 74s get more - the highest I know of is Spartiate with 24 Ordnance mounted to FC and QtrD. This was a moderately large (1949 tun) vessel, much larger than a common 74 such as Vanguard (1609 tuns) While there was a period in which supernumerary guns were common, these become less common after the rearmament of 1798, with the exchange of small guns for larger carronades and chase and retreat guns. RH carronades seem to be allowed, but not all designers or captains like them, so 'fitted for, but not with' is quite common. If fully armed a spar deck should be capable of fielding 30-32 ordnance, but this would strongly impair the functioning of the rigging and increase loaded weight if they are of a size to be useful. 32 pdr carronades are a roughly 1:1 exchange for 18 pdr guns for firepower and 12 pdr for total installed weight, so there is a weight penalty moving from 9 pdr to 32pdr carronades* ~ which should drive a moderation in the ordnance numbers. *The 32 pdr Carronade and slide are lighter than a 6 pdr gun and carriage, but 32 pdr ammunition is much heavier - the lower on-deck weight is useful for stability, but ultimately the whole installed weight eats into capacity. Crew requirements are reduced for the Carronade compared to a gun of equivalent tonnage - which can be used for more resilience to manoeuvre and musketry while at quarters, or to reduce the manning requirements of the fleet, and without any loss in longer range potential - 9 pdr and 12pdr guns lack penetration and meaningful advantages in accuracy compared to the heavier carronades.
