Posts posted by rfolsom
Nenad; you've seem to really master the porthole/mooring hole scratch build... I took the easy way out with my "non-elliptical" mooring pipes.
Now I am doing the "hmmm" thing again...
Very well done, my Friend!!
~Bob
Coppering is looking excellent. Good to see your new posts...
Well done!
~Bob
Very nice, Nenad. I may follow your lead on this...
Your boats look great; Not cluttered at all... The kit's "bread and butter" method is very tedious, and inaccurate, if you are a stickler for scale. A POF approach, while very, very, time consuming is more rewarding, but I think you've captured the effect quite nicely.
Don't sweat the small stuff...
If you stick with the scale, these boats' hulls can be about as thin as an eggshell...
Ok. I started initial installment of hinges (semi-painted) to the rudder, using CA at the hinge points, but letting the ends free. Once dried, I will drill into the rudder through the pre-drilled gudgeon holes and affix the loose ends with small nails (hopfully NO CA). The sternpost gudgeons remain unfinished, as I decided to make the whole rudder/hinge assembly first, then fine tune how it meets with the ship. These will be evened up and trimmed to approx. 7mm, and drilled with 3 or 4 holes, for accepting the nails.
Thanks, Nenad; I'm doing paint testing...
Marc, thanks for checking in, and it's great to hear from you again! Hope the new job is going well, and I hope to see some new posts in the near future...
BTW, the Pig is well trained, and will be paying a visit to you in Virginia to inspect your progress...
All the best,
~Bob
Nenad; this is why I have not installed the whisker booms on the catheads yet. The cats as they stand, are pretty strong. I also will not install the boomkins until rigging is well under way... Bulwarks were bad enough to deal with when I was planking: ( 1. Plank a bit. 2. fix cracked bulwarks. 3. repeat...)
A little bit of work was done on the Vic. Rough cut a couple more bulkheads, and stared at the plans for awhile.
Although I base this build loosely on Caldercraft, I've noticed many errors cropping up. The bulkheads are not lining up properly, so I'll be going completely to the AOTS.
I've rough-cut many of the bulkheads, with AOTS templates affixed, but I'll have to re-draw the alignments on the keel; Caldercraft/Jotika is inaccurate.
Hello, Dale; thanks for looking in. I've been busy with the Cutty Sark, and there's so many Victory builds it's hard to keep track of...
On the unfortunate side, I decided to completely scratch build the Victory's hull. I thought about tearing into your build, and taking the bulkheads, etc.(Decided not...).
Anyhow, she's safely in my shipyard, as a model reference..
Great way to organize your research, my friend. I initially cut some detail in "A, yellow" but filled it in. This is the area I'll be focusing on after the rudder.
Very nice work.
And fiddly = detail!
Looking forward to more light-speed progress..
Cheers,
Bob
A little bit more work.. I have trimmed, drilled, and filed the rudder side of the hinges.. The ship-side gudgeons have yet to be finished. They are shown taped to the scrap piece of wood that I used for a drilling back. It also keeps them together and somewhat protected. I will simulate bolts with small lengths of 24 gauge wire. (0.51 mm). The holes are drilled with a 0.55 mm bit, which broke, so I'll be stalled until I pick up some more bits.
Keith; I was originally planning on epoxy for these, but since I didn't have any on hand, and these hinges do not actually support the rudder in my build, I tried CA and found it to be adequate.
Lawrence, thanks for the kind words. I plan on using brass to fabricate all the yard and mast hardware, but that's a ways down the road, and my brass inventory is very limited. Also, my soldering equipment is not up to structural soldering; new toys must be purchased in the future...
Looking good, Keith. I see hatch remakes for me in the future...
Very nice work, my friend! I really enjoyed the work on the detail for the rudder ring. Your ad hoc macro lens is very cool, too; It reminds me of the views from stereoscopic microscopes in college...
Nenad is silent.......
Perhaps just sitting back with a snifter of brandy or Scotch, looking at Her lines, and going ; Hmmmmmmmm......
Keith; I'm not sure if they're the same, but I have a bunch of pins that came with my Billings kit. I'll have to do some testing soon, I believe...
Thanks for the kind words, gentlemen. Nenad; I am in the process of determining the rivet/bolts for the gudgeons, but they will be present.
I would like them to serve a structural purpose, (i.e. actually holding the gudgeons on) so I don't have to use any CA.
Keith; The topgallant rail is here to stay, for better or worse, and I'm ok with how it looks.
Cutty Sark by Keith B
Very nice work!
I'm looking forward to your coppering methods...
