Capella
About Capella
  • Birthday 09/07/1967
  • Gender
  • Location
    Villard, Minnesota
  • Interests
    Amateur Astronomy, camping, canoeing, and wood model ships, of course!
849 profile views
  1. Hey, guys. I know - it's been ages since my last update, but lots of life events have occurred that have taken priority over working on my project. I'm currently in the beginning stages of getting a new workspace set up and hope to be back up and working in a couple/few weeks. In the meantime, I bought a shelf set to display this ship and my first one (in my sig) and wanted to check to make sure the shelves that I bought were wide enough (yeah, I know, maybe I should've checked that first before buying the shelves, but I really wanted to get my first ship on display ¯\_(ツ)_/¯ ). Anyway, if someone could provide me the measurements of the widest point of the Occre Beagle, I'd greatly appreciate it!
  2. Looks great, Patrick. You put the alignment of the deadeyes on my chainplates to shame! 😉 (I too have made a decent amount of progress, but have been too lazy to post it here recently)
  3. Hi, All No update to post yet. I've made more progress so far this weekend, but I'll post a progress update tomorrow. One thing I wanted to point out to anyone who hasn't done this build yet: the spacing for the vertical posts (chafing boards, I believe??). I wanted to ensure that the spacing was even along the length of the hull, so I ended up plotting it out on graph paper. Sorry for my crappy writing, but as you can see both forward and aft of the gap in the hull, the two end spaces are 1mm each wider than the spacing for the middle spaces - except for the port, forward section, which turned out to be 2mm longer than the corresponding section on the starboard side. Don't know how that happened, but I just compensated for that by adding 1mm to the two spacings towards the middle from the fore and aft ends on that side. Hope that helps someone. _________________________________________________________________________________________________________________________ Also, a question to those who have done page "G" in the plans. Specifically, the two pre-formed metal pieces that go on the aft of the ship and have windows on them. Looking very closely at the pics in the guide, the windows themselves look slightly "bluer" than the black surrounding them. I went through a lot of the Beagle build logs here, trying to find others' pics of those - or even any comments about doing those, but I wasn't too successful. I got the Occre paint set for the Beagle and don't seem to have any color that might make the windows slightly lighter, other than just painting them black. Suggestions on that, anyone? I mean, I wouldn't be terribly disappointed if I just ended up painting the windows black and moving on, but I thought I'd check first. Thanks! Capella
  4. Well, as I knew, once I got past the hull, progress would pick up. I finished the hull and started on the strakes and inside "pretties": I gotta tell you, cutting those diamond-shaped pieces to all match was a challenge - for me, at least. But, I know they'll be covered up and hidden by a lot of other stuff going on as things get added to the deck and rails. Currently, I'm painting the hull and rails. I'll probably post updates on that this weekend. Until then... Capella
  5. It's been a while since I last posted an update, but as you'll see, I have not been idle on my ship! In my last post I had finished laying the first layer planks and smeared the hull with wood filler. Well, I've made quite a bit of progress since then: These pictures were taken after I had finished final sanding of the 2nd layer. You may have noticed in the 1st and 4th pictures the "blemish" near the forward keel of the port1` hull. The light part is planking from the 1st layer showing. I don't remember how exactly that happened, but it was exposed during my 2nd pass on sanding. Unfortunately, I don't recall in which thread I saw it, but I remembered coming across a post here at the MSW forums in which someone explained having a similar situation and he mostly fixed it by mixing sawdust with a bit of glue. Thinking about that, while sanding the hull I kept all of the sawdust. I then mixed a few of drops of PVA glue with a good amount of sawdust. It got pretty pasty, but I thought (hoped, really) it was workable. The mix was kinda gunky while spreading it on the spot, but I made sure to have enough on there to cover it and then some. I gave it a good few hours to dry. After re-sanding that area, here's what it looks like now: Not great, but better. If anyone asks, I'll just tell them the ship hit some rocks and they had to repair the hull! 😉 Anywho. That's it for now. Next step is to put a satin finish on the hull and move on. 'Till next time...
  6. Thanks, Chimp. Ewww. Extending the planking - however I choose to do it - might be a bit of a challenge Was that how you did the planks along the entire length of the keel, bow to stern (The keel pieces recessed into the 1st layer planks)?
  7. Okay - wood filler is done (I think). I included the wood filler I used in the picture, as I know I'm always curious what materials and tools people use. Next, obviously, is sanding. I just finished the filler, so I'm going to let that sit for a few hours. One thing I'm not clear on is how the planks are supposed to meet the keel at the bow. In the below picture you can see that I placed the bow piece temporarily to illustrate how I planked the hull, such that the planks meet up with the sides of the piece. Hopefully the circled area in my picture clearly illustrates what I did and what I mean. That is how it seems to me to be in the instructions pictures, but looking at a few pictures of that area in various build logs, how people did that area seems to vary slightly from one build to another. My question is, should I sand down the 1st layer planks at the bow to meet with the keel itself - thereby exposing the "base" of that bow piece, then plank the second layer to meet with the sides of that bow piece, or should I leave it as is? Or is that even not really a critical detail? Till next time! Capella
  8. Thanks so much for the encouragement and advice, Chimp (and @Patrick Btoo!). I'll take a close look at your posts before I start the 2nd layer.
  9. Okay - I'm back! In my last post (#80), I had torn off the mess that I made of the bow hull. Here's what the hull looked like yesterday after redoing that and planking the rest of the hull: I spent yesterday and this morning filling in all of the gaps in prep for filling (wood filler) and sanding. Here's where I'm at now: So, my next step is to properly shape the planks to meet with the keel on the bottom, the transom, and each other on the bow. As you can see, I'm not adverse to using copious amounts of wood filler to get a nice smooth surface for the second planking! As always, any tips and/or suggestions will be greatly appreciated! That's all for now. Till my next update... Capella
  10. Looking great, @The Gimps Chimp! I took a few liberties with the small boats, myself. Seems to be common practice. The weather is starting to turn towards Fall here in Minnesota, so I'll be getting back to my Beagle soon, myself. Keep up the great work!
  11. Hey, @Patrick Bt (I'm posting this on my phone, so, sorry if the "@patrick b" looks weird. It came out weird for me.) Thanks so much for checking in! That's very kind of you. We Minnesotans have a short summer, so we tackle the time with gusto. As such, the "shipyard" gets shut down for the season, and I'm out going to the cabin, going on canoe outings, doing yard work, etc. I'll probably be picking up the project again in another month or so. I did make some progress from my last post back in March, so when I sit down again to work on it, I'll give a full update on my progress and how I plan to tackle my re-do of the mess on the bow. Until then, thanks again!
  12. Looks GREAT, @Patrick B Mine will definitely need plenty of filling and sanding when I'm done with the first layer. I saw the benefits of a pin/nail pusher early on, so I ordered one from Micro-Mark, but it's been on backorder for nearly two months now 😕 Your first layer experience is definitely what I (and many others) strive for!
  13. I made note of the tape method in my plans. Glad you found a solution to that!
