shipman
Everything posted by shipman
  1. I can't remember the exact dimension, but the kit deck is around 4mm too high in the hull as is. The deck houses stand proud of the bulwarks, when their roofs should be level with them. By implication. it would seem the internal detail of the bulwarks isn't quite correct. See how the freeing ports molded outside, the bottom edge should be level with the deck, but they aren't. Getting the 'oval' panels proportionally correct would (to my eye) only emphasize the above disparity.
  2. For many years this Honda was only second to Guzzi's fabled 500 V-8 as the most exotic motorcycle in the world. Thanks for letting us peek over your shoulder.
  3. Yup ... oil coolers. Mr. Honda didn't believe in water-cooling. Even their first 1.5lit F1 car had an air cooled across the chassis V-12, which in principle was two of these engine's on a common crank case! Made good use of your time on this one.
  4. Yup, love the HD Flathead, all the classic Bobber proportions are there. The Beemer started life mid '70's, but as you compare the two bikes, the HD just crawls with class. The Beemer doesn't!
  5. Hi Craig. What is your idea of a 'grunge' bike? Bobbers have a high degree of respectability in the Custom community. Perhaps you mean a 'Rat' bike?.... deliberate designed-in 'rot'.
  6. Coming along nicely, though the rear wheel spoke pattern looks strange to me. See this as comparison....
  7. Your frustration is very understandable, you have my respect. With a bit of luck the extra links will do the trick and you can stop swearing at it!
  8. May I suggest you trial fit the rear suspension units. The combined geometry between sprockets and swing arm pivot varies in operation. Looking at your photo, the wheel appears to be at its upper limit of travel. With suspension attached, the wheel should be relatively lower and due to the geometry should remove some of the slack.
  9. Just had a thought..... If I were to tackle that chain assembly, I'd have a go at making a tool to press the links together. I'd find a brass pin from a household electrical plug, file one end to an appropriate shape and micro drill two holes spaced for the chain pins. As long as the holes are slightly bigger than the pins, it doesn't have to be 'rocket science' accurate. And there you have your own press to push the links together without bending them. The tweezers I highlighted are hardened, needle sharp and strong.
  10. Try these ... ebay 6PCS Professional Coated Precision Tweezers Set Kit Stainless Steel Non-Magnetic
  11. I believe the test rider is Hiraku Miyagi. Glad you enjoyed the video's. Honda weren't entirely dominant during those years. Both Yamaha and Suzuki fielded their own exotic two strokes. Suzuki built a 3 cylinder 50cc. At the end of 1967 the governing race organization (FIM) decided things were getting far too much and introduced severe restrictions in all classes in the hope of encouraging closer competition. Much like post war supercharging was banned for the same reasons. At the moment I'm not at liberty to divulge what was sitting on my table last night. When I can, it will be a real exclusive treat for late 1940's British GP enthusiasts. I'm fortunate to know some fascinating characters who have even more fascinating motorcycles.
  12. Yep, those were the 'GLORY' days when race paddocks were basically a field. No motor homes, teams living in tents and utility vans. Most riders survived on 'start money' and a private sponsor. The envy was palpable, only the 'works' riders had contracts. And there were only 10-12 of them at best. Remember, they were all air cooled, double overhead camshaft, four valves per cylinder. Tool room specials, creative engineering and no computers by modern standards. Notice none had any flywheel effect and were a nightmare to ride. Only the lucky few got the chance and earned every penny. Track safety was straw bales and a bashed up ambulance. Finally the 500 4. That's Honda playing with its museum GP racers from 1966 in a glorified car park. Hope you don't mind the overload but it may put 1960's bike technology in front of a new audience. Finally, finally, serious nostalgia.
  13. I remember building a 1:8 Honda race bike back in 1974. The chain for that was all individual plastic links and rollers which had to be glued together. My results were sadly predictable! As with all race bikes, each track needed different gearing, requiring a range of sprockets at the gearbox and rear wheel. Individual riders preferred their own set-up too. Then there were multi jets in each of the 6 carbs, requiring setting up for varying atmospheric conditions, which these engines were ultra sensitive to; as were spark plugs. Often the quickest way was a complete engine swap. The real jewel from that period was half the capacity.... a 125cc 5 cylinder!
  14. Splendid detail improvement..... go for it!
  15. CDW, that 'ferule' idea is brilliant and new to me. Alternately, the junctions could be micro-drilled to take the replacement wires; a little more labor there, but ultimately more secure and authentic. Looking forward to more results of your work.
  16. Coming along nicely. One observation ... the various cables and wiring. The tube Tamiya provide is way over scale in most areas. My suggestion would be to find some fine electrical insulated wire from a phone line/computer wotsits in suitable colours. Or use wire or solder (painted).
  17. The covers were magnesium and had to be protected from atmospheric moisture. I think originally a form of gold paint was used. I believe the black is a chemical derived coating. Here's an article featuring photo's of this engine in Honda's own museum. I recon they know what they're doing. https://caferacergarage.eu/honda-rc166-6-cylinder-racing-legend/ More.... http://www.deejay51.com/honda_hall_racebikes.htm I do also think it worth pointing out, though Hailwood is always associated with these bikes, Honda's first world champion was Jim Redman who did most of the early 6's development riding. Redman had a fall and broke his arm; that's how Hailwood got the job. Irelands Ralph Bryans also rode them regularly, normally, due to his sleight stature he was normally riding 50 and 125's.
  18. More goodies .... useful and interesting info to be gleaned here. https://www.motorcyclistonline.com/honda-rc174-rc-reborn/ https://www.philaphoto.com/imageLibrary/thumbnails.php?album=1696 It's worth noting, the rc166 and rc174 were externally identical. The George Beale replicas were built with Honda's co-operation, and I think Honda themselves took one to play with. They were faithful in all details and finishes.
  19. Here's a Japanese TV program where you get to see nearly every nut, bolt and washer of the engine being stripped in front of a live audience. I don't know of an English dubbed version, but this is a MUST SEE for anyone interested.
  20. No, the crank was a pressed up affair. In fact if you picked it up off the bench without support, it actually sagged! The crank cases and main bearings are what gave it rigidity. A mechanic was asked to lift one of these engines onto a work bench. It was so light he assumed there were no internals...until it was opened up! The engine had no flywheel effect and had to be run at no less than 2,000rpm, or it just died. As this project develops, I'll find some references (if you're interested), to illustrate I'm not exaggerating.
  21. The real thing was virtually a model it's self. Imagine 6 these things thrashing around at 20,000 rpm!
  22. Sitting upright in excited anticipation. The Tamiya m/c kits are lovely little things. To do these faired bikes justice you really need to build two, faired and without.
  23. Thunder City Wiki page... https://en.wikipedia.org/wiki/Thunder_City
