Everything posted by shipman
I'm always in two minds about emphasising panel lines. I've stood right up close to many aircraft from all era's, yet such details are the last thing to catch the eye. Nearly always such detail is either absent or very subtle, unless the aircraft has been left to rot outside. I do agree, this technique makes a model look busy, but I also think it highlights features not seen on real aircraft. As you imply; each to his own. Your lovely model shows what a great job Airfix have done.
Siggi, your model is a splendid rendition; I'll just sit back and follow your progress. One day I may have reason to tell someone I've seen it somewhere 😎
When a ship was not in use it was called being 'in ordinary', where all fixtures and fittings, including masts and rigging were removed and stored at a shore establishment to avoid deterioration. I was referring to a ship being in use but in peace time.
Plastic or Wood models? Your Favorite?
shipman replied to Bill97's topic in Modeling tools and Workshop Equipment
To my mind it all depends on what resources a modeller has available, including time. Building a decent plastic kit to high level of detail is just as much an accomplishment as a wooden one. The tools required for a plastic build would comfortably fit into a small shoe box. The model could be built on the proverbial 'kitchen table'. Time and again we see fine examples on this forum. Vision, experience and determination are prerequisites of any endeavour , whatever the subject. -
When still in commission but not at war, depending on the size of the ship, a substantial compliment of ordinance was frequently disassembled and stored in the hold. Thereby helping stability and providing less cramped accommodation. When not at war a full crew wasn't required; stores were less, so it makes sense to 'open the deck'. Once hostilities began it became a mad scramble to put the ship in a state to actually fight. Notoriously, captains struggled to adequately man the ship. No idea where I read that, but did.
As promised, here's the arm rest I made. It can be clipped to table top etc. Each side rotates and can be angle adjusted using different wooden wedges. The 'pads' could indeed be lined or padded. I thought about recessing the two fasteners, but in practice I felt none of the above were required. Very useful.
Last year I was invited to see a wealthy man's extensive collection of classic GP motorcycles, the highlight for me was his brace of MV Agusta 500 triples, a favourite of mine. He asked me to guess what the small oil tank hidden under the seat was. Graciously I said ''you tell me''. He told me that was a reserve oil tank feeding the engine. As the reservoir was so small (the machine has a VAST heavily finned wet sump), I said that was improbable. Well, he said, the great Giacomo Agostini (a personal friend of his) the man these machines were primarily designed for, had told him that. Mmmm, I came home and consulted my extensive digital period photo files; the tank is in fact an oil reservoir for dripping oil onto the drive chain. The moral of that story is, don't believe anything anyone tells you (no matter if it's someone with Agostini's cudos), before you find out yourself. This forum constantly urges the importance of primary source information. This was a fine example. I believe the correct term for the Bianchi is Freccia Celeste.
See this, though not exactly the same machine, the practice is clear. https://www.fondazionepirelli.org/archivio-storico/fotografie/detail/IT-PIRELLI-FT0001-0000000482/il-pilota-miro-maffeis-nel-1925.html?jsonVal={"jsonVal":{"query":"Miro Maffeis","startDate":"","endDate":"","fieldDate":"dataNormal","_perPage":20}}&attachmentMisc=undefined&lang=en#n
I don't believe one of these machines survives. However an excellent picture of this model, previously shown here, makes the function of this small tank obvious, at least to the that builder, and makes sense to me. It is a separate oil tank, feeding the valve gear in the head, by gravity. In those days lubrication was primitive, being total loss systems. The head is above the main oil tank outlet, hence the higher supplementary tank. That model......the oil line is clearly evident.....the 'valve' on the little tank is actually a hand operated injection pump, again a common period feature.
Bob, to quote VB: ''Yep I'm aware, shipman - but compromises must be made. I'm not planning on a true scale implementation for this build. The next may be different, but I'll concentrate on this one and do the best I can as I develop my skills''. With that in mind, it is my humble opinion, getting the micrometer out for such details is verging on the autism spectrum. An old phrase seems appropriate....'if it looks right it is right'.
- 248 replies
- Cutty Sark
- Revell
Be aware much of the standing rigging is WIRE, which is thinner than 'rope'. All of it was served and tarred.
- 248 replies
- Cutty Sark
- Revell
Aren't they. Like others here, I too built several Protar kits back in the seventies, when they were much cheaper. Unfortunately their kits are a bit clunky compared with, say, Tamiya's offerings of today, yet many of those date back 40 years now. I have seen some splendid renditions of the Bianchi, but unless you are kidding yourself, the kit out of the box, compared to photo's of the real thing, isn't very accurate at all and don't justify the cost. Sad but true. However, I'm sure you'll have hours of pleasure building it and I look forward to the rest of your build.
As previously mentioned in other build logs......the kit deck is set substantially too high in the hull.
- 248 replies
- Cutty Sark
- Revell
