Everything posted by Waldemar
Well, it is hard to oppose the true archaeological find, even if it seems a little unorthodox today. Please take a look at the drawings of the upper decks of the real ship (quarterdeck, poop, topgallant poop). In contrast to the lower decks, most beams here are inserted between the loosely spaced frames, and in this case it must have been done on purpose, as – exceptionally(?) – even the vertical branches of the hanging knees are hidden beneath internal planking, being placed between frames too, most probably to save available space. However, I do not know the actual dimensions and spacing of the "Endeavour" frames and beams at the quarterdeck level. Just pointing at such possibility (again – only at the highest, i.e. quarterdeck level). Good luck with your choices.
Certainly, and all the deck beams on all decks of the “Vasa” rested on longitudinal deck clamps, which were directly fastened to the frames. Internal planking was added later and – as the last – the hanging knees. My point is that the issue "deck beams between or against the frames" is rather a mix of 1) minimising the work, 2) possibilities and 3) discretion of the individual builder. IMO.
Maybe of help, maybe not: On the “Vasa” of 1628, the deck beams of the lower decks were against the frames, as the frames were too closely spaced to insert the beams between them. It was the other way on the level of the upper decks with much loser frames – there the deck beams were inserted between the frames.
Le Soleil Royal by Nek0 - 1/72 - Marc Yeu
Waldemar replied to Nek0's topic in - Build logs for subjects built 1501 - 1750
Concerning the 17th century sailing navy (as opposed to the galleys) shipbuilding practices, may I propose some other French primary written sources? – G. Fournier, Hydrographie […], Paris 1643 – F. Dassié, L'architecture navale […], Paris 1677 – F. Coulomb, Livre de construction des vaisseaux […], Toulon 1683 – Anon., Construction des vaisseaux du Roy […], Havre de Grace 1691 – Anon., Construction et proportions de plusieurs vaisseaux, manuscript, ca. 1690–1701 These are as much useful works for early modern era ship’s reconstructions as any other, partially even for non-French constructions, provided they are correctly put in a wider context.- 208 replies
- le soleil royal
- 104 guns
Thank you. That’s right, Kevin. Upon completing the 3-D model, it could later provide all the necessary 2-D projections of each single part, assemblies or intersections. I have put a few quickly made samples below. Please note some strange lines may still appear, as many parts are not already cut to their final shape, masts are still a simple dowels, gunports are not yet pierced etc.
The vessel “Święty Jerzy” (eng. “Saint George”) was an admiral ship of the Polish fleet in the 3rd decade of the 17th century, so it can be said she was an indirect opponent of the Swedish “Vasa” of 1628 in the struggle between the two then belligerent nations. She took a major part in the battle of Oliwa in 1627, capturing by boarding the opponent admiral ship “Tigern” (eng. “Tiger”). The following year, in a retaliatory land-borne attack on the fleet base, led personally by the Swedish king, she was smashed, set on fire and eventually sunk by heavy artillery – large calibre demi-cannons (24-pdrs). Perhaps rather short operational story, nevertheless quite intensive (detailed descriptions of both epic fights have survived). Ultimately, the intention is to build wooden scale model, and a 3-D reconstruction in Rhinoceros is currently underway. The starting point is the two extant fleet’s inventories and contemporary iconography of the battle, mainly a painting made only a few years after the battle. While many details are sourced – of necessity – from various depictions and written works, I have also tried to retain the general layout of the ship as depicted in the painting of the battle, such as the large counter with a bas-relief (or painting) associated with the ship’s name and the low-lying gunroom (entirely below the gun deck). Given the rather low sternpost, this implies that the rudder must have been operated from the level of the gun deck, and not (as usual?) in the steerage located one level higher. Swedish, Polish and Dutch ships at the Battle of Oliwa 1627; painting by Adolf Boy, contemporary resident of the fleet base Local documents of legal nature suggest that the ship was built using a skeleton technique (as opposed to the shell method), and I have made efforts to shape the underwater body of the hull so that it could be achieved by most of the known skeleton methods (as can be derived from contemporary Iberian, French and English works on shipbuilding). At the same time the assumption was made no scale drawings on paper in the construction process were made, only true-scale tracing on the shipyard platform/ground. On the other hand, it is believed that ships built in the southern Baltic area had many features in common (structural, decorative, rigging) with other ships built in the north of the continent, as exemplified by the Dutch built Swedish “Vasa”, Dutch manuscript (mainly on rigging) of around 1650 or the Dutch monumental work on shipbuilding by Witsen, so masterfully interpreted by Ab Hoving. As a result, in contrast to the conceptual features of the ship (hull shape), these are the main sources used for the reconstruction of structural and rigging elements, besides the Scandinavian early 17th century contracts for building men-of-war and the French works containing data on timber scantlings (largely Atlantic-oriented “Construction des Vaisseaux du Roy” of 1691). Some visualisations of the 3-D model in the present (unfinished) state: Cheers, Waldemar
Actually, I did an attempt of 3D reconstruction of this very plan some time ago too (with deliberate, slight modifications to the ship’s lines). Ultimately possible in many cases, but it is usually a pain to work with distorted drawings. Besides, distorted plans take considerably more time to interpret them and the accuracy is jeopardized. I wish I could use your program before, in this project and in some other as well. Your ship plan adjuster just do what was desperately needed. But now it is ready for the next projects, which makes me very optimistic... Many thanks again for sharing it. Warmest greetings, Waldemar
Hello Kris, I have been looking for such plan adjuster for years (rather unsuccessfully), and have given yours a try. The source bitmap drawing I have used is distorted in so many ways, that it was originally almost impossible to redraw it credibly, even manually, into the vector graphic. Original plan: Only basic transformations were applied so far (i.e. squaring and flattening), giving already outstanding results, simply impossible to achieve in common bitmap editors. As it was just an exercise, the drawing with all its views was adjusted as a whole (which should be not of course) by your program, taking as a reference half-breadth rectangle. Here’s the outcome: What graphic formats does your program support except PNG and JPG? Great job. Many thanks for this. Waldemar
48pdr cannon
Waldemar replied to Thanasis's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
This is one of the finest models I have seen. The bow gun is lovely made too, but it is a classical long gun, and not a 48-pdr modern carronade you are probably striving for. Perhaps the best course of action would be to scale the below British carronade drawing so that its bore diameter would be 180 mm (this calibre would be a 48-pounder for Hastings). This is not a British system calibre, but Russians were known to order large quantities of carronades from Scottish factories, perfectly conforming in its shape and proportions to the British pattern. Later made Russian specimens were also perfect copies of British specimens. Some of them could be re-sold or given away to anyone, and also lost to the Ottomans. Good luck! -
48pdr cannon
... this is much better, surer method than calculations based on the crazy specific densities of substances like iron or stone used in the shot manufacture. -
48pdr cannon
As evoked by Bruce, a simple formula can be used to calculate any bore (or roundshot) diameter, just knowing only one from a given calibre system. There were naturally some small individual variations for different reasons, but it usually works within production tolerances, at least for identification purposes. Diameter1³ Poundage1 ------------------------ = ----------------------- Diameter2³ Poundage2 For example, if you know that the bore diameter of a French 48 pounder is 19.4 cm, and you are looking for a diameter of a (theoretical) French 68 pounder gun, then: 19.4³ 48 (pdr) -------------- = -------------- x³ 68 (pdr) x³ = (19.4³ * 68) / 48 = 10343,63 =====> x = 21.8 cm (bore diameter of a theoretical French 68-pounder) For better results, avoid – if possible – mixing calibres of different systems used in specific countries. -
48pdr cannon
Is it acceptable in this fine project to arm the ship („Terpsichore“) operating already in 1821 with the ordnance specifically designed in 1825 (and delivered in 1826) for „Karteria“? You decide, but if the current preferences are for a modern carronade (or carronade like gun) of exactly 48 pound caliber, you are perhaps left only with Russian or Ottoman ordnance, or maybe a British specimen aimed at the merchant market too. The inventory and weight marks cut on the baserings of bronze cannons in the two pictures above are not much helpful here. -
48pdr cannon
Well, factories can be taken over (captured) too, like cities or fortresses. Never mind... The text reads (ou, already translated by Bruce): "This gun is formed like a carronade except that it is longer and has trunnions resembling those of a long gun". One may also add here: just like in carronades intended for merchant service (in contrast to naval/military service), which had normally trunnions as well. This quasi-carronade concept/project by Hastings could not be modelled after Paixhans system, as this system was not yet fully invented, or at least accepted by the French Navy. See Gerard's posts. It seems, that it is just an invention by Hastings. Maybe actually cast, maybe not. Don't be afraid of the apparently obsolete stone (chambered) guns, as they could be deadly efficient even against large warships. You perhaps know a famous accident, from just a few years before, when a large stone roundshot from an Ottoman gun smashed at the large British ship-of-the-line, making terrible damage and killing some of the crew on the spot. Only range was lacking, just as in carronades. -
48pdr cannon
Just to be on the safe side: no armament factory (gunfoundry) in Greece then? Taking all this into account, and especially the available sources of artillery armament, I would turn into the Ottoman or Venetian ordnance. If Ottoman, it could be half-kantar gun, which may be regarded as an equivalent of the Western carronade of roughly the standard 48-pdr size. This half-kantar gun, in its shape, was not far from the obsolete, medieval stone guns (cannon-periers). And all of these chambered guns were still widely used on board Ottoman ships even in 19th century. Always cast in bronze. For example, in the Russo-Turkish war of 1787-1792, Ottoman 86-gun battleships had four half-kantar guns. Ottomans also cast copies of Venetian and Russian longer unicorns (cannon-howitzers), but these should be easily distinguished by a professional like Hastings from a carronade-like guns with shorter barrels. If not Ottoman, you can take into account Venetian ordnance, with hundreds, if not thousands of specimens lying all around. Many of them, in function and capabilities, were almost perfect equivalent of modern guns. Again, first take a look at what was used locally then... -
48pdr cannon
Well, if you insist on something more modern, quite detailed data is available for the Russian carronades and the so-called unicorns, both naval service, and both also in 48-pdr size, and both in regular service in 18th and 19th centuries. As an aside, Russian unicorns are in practice nothing more than copies of Venetian guns of the New Invention from 1684. You just need to establish such possibility in your sources. And keep in mind that even "Karteria", built abroad few years later than the "Terpsichore", had to wait several months for her modern, state-of-the-art armament. Meanwhile, she got temporary, more or less random guns taken from a fortress. -
48pdr cannon
May I ask you, what is the current state of this research except data you have already put in this thread? Thank you in advance. -
48pdr cannon
There is also another possibility, ie. that of Venetian guns of the so-called "New Invention" from around 1684, being in essence cannon-howitzers, just like the later French Paixhans guns (canon-obusiers). Two models were produced in modest quantities, with calibres of 265 mm and 212 mm (respectively of 200 and 120 „small“ Venetian pounds). The calibre of the smaller version is quite close to the supposed, later „48-pdr carronade“. Two prototypes were cast from iron in England (six calibres long, ~1670 kg). „Normal“ production specimens were cast in bronze at the Venice Arsenal (3500 „large“ Venetian pounds = ~1560 kg). More on these guns in G. Candiani, The race to big calibres during the first war of Morea and Sigismondo Alberghetti’s guns of new inwention, [in:] Ships and Guns. The Sea Ordnance in Venice and Europe between the 15th and 17th Centuries, 2011. Smaller, 120-pdr (212 mm) Gun of the New Invention (cannon-howitzer), with its shell beneath the muzzle: -
48pdr cannon
More details on a matching Venetian „48-pdr carronade“ (from the book by C. Beltrame and M. Morin, I Cannoni di Venezia. Artiglierie della Serenissima in Turchia, Grecia e Dalmazia, 2013). Tipologia: cannone petriero da 90 in bronzo Località di conservazione: Askeri muze ve Kultur Sitesi Komutani Istanbul N° di inventario: 261 Fonditore: Tommaso di Conti Anno di fusione: ante quem 1540 Proprietà: statale Calibro: 19.2 cm Peso pezzo marcato: 1360 (il peso in libbre grosse alla veneziana) = ~610 kg Dimensioni: 190 cm (lungh. tot.), 174 cm (lungh. conv.), 30.7 cm (diam. al foc.), 31.8 cm (diam. agli orecch.), 26 cm (diam. alla gioia), 32 cm (diam. della gioia). Descrizione: pezzo di tipo “camerato”, ossia con canna il cui diametro in corrispondenza della culatta è ridotto. L’arma è dotata di rinforzo centrale mentre la volata, e parte del posteriore, sono più strette. La gioia di bocca presenta una gola molto pronunciata. Sulla parte alta della volata una doppia cordonatura crea una fascia su cui è presente la X del Consiglio dei Dieci. Al di sotto è presente un leone accosciato verso destra soprastante le iniziali T e C tra triangolini, indicanti il fonditore. Al centro dell’anello di culatta è inciso il numero 1360 indicante il peso in libbre grosse alla veneziana. Sul pomo sono incise due linee parallele. Sample stone gun (cannon-perier) intersections: -
48pdr cannon
… and it would be rather a bronze gun, relatively lightweight, up to, say, 700–800 kg. -
48pdr cannon
Thanasis: An obsolete large Venetian stone gun (petriera, cannon-perier) would lovely match the available data on your gun. Such guns could be quite long, sometimes almost like true-bored cannons. Large bore in the range of 18–19 cm diameter would roughly match the closest standard 48-pdr shot. And perhaps best of all, it was a chambered gun, just like the carronade, and essentially it could be used as carronade, hence classed as such by the Philhellenes. -
48pdr cannon
Licentia poetica? My straightforward interpretation (hopefully in line with the intention of both author and translator) is: 48 pounder carronade = carronade of the calibre of 48 = carronade of the calibre of 7 inches Just different descriptions of a new proposed type (class) of ordnance with the French standard 48 pound (or 7 inches) calibre. Gerard, am I right or otherwise? -
48pdr cannon
… logistic issues may be of help too. What was the source of guns for the Greek navy in general (or this cannon in particular)? Russia, Turkey, France, GB, Greece itself, and so on… Without all of this, we can only create pure deus ex machina. Sorry. -
48pdr cannon
Try to establish if this bower shot through the gunport or over the bulwark (required gun barrel length depended on this, ie. longer barrel for a position with a gunport; horizontal angles!). Try to establish also the way in which calibre of chambered guns (like howitzers, carronades, mortars) were measured and referred to in Greece then (for example, according to iron roundshot or stone rounshot for a specific calibre). Try also to establish the actual weight of a pound used in Greek artillery then. You will have more data then to hopefully sort it out… -
48pdr cannon
In short, soldier words: make an educated guess and choose at the most „modest“ 24-pounder for your schooner‘s bow gun. Better don‘t count on general historians sporting national bias who have usually no idea on period or modern artillery (assuming a 48-pounder or a 68-pounder is just their guess, not derived from the sources). Generally speaking, Paixhan work is more on ideas, rather than on actual practice. That's my advice. Thank you. -
48pdr cannon
Sorry to say, but this is not contemporary document, just modern interpretation sporting many, many grave mistakes… Please don't waste your time on this drawing, unless you have some other goals. Sorry again. Waldemar
