Everything posted by Rock_From_Korea
I also started on balcony. I laminated several thin layers of wood sheets to get the desired shape and thickness of the base of balcony and then applied the deck strips both above and below. I am still deliberating on what type of design I am going to apply for the balcony, but for this prototype I am thinking to make it an open balcony - i.e. not applying side panels but with podium like poles.
Hi All, I finished the planking on lower part of the forecastle and after castle, with additional layer of planking done inside. I am still not very satisfied with this part of the planking and redrew the whole planking plan of GH2. I will apply quite different planking scheme for GH2 and have been working on the first planking of GH2. Anyway, below are some pictures of the finishing work on the weather deck planking.
Before starting the planking of the upper area (starting with the weather-deck), I deliberated a lot on what type of wood I should be using. Couple of tests later, I decided to use a thinner, more flexible wood strip for these areas. After installing 2 rows, I began to regret this decision as the overall look did not correspond to the tests I performed before. Anyway, I will contemplate on what to do with this section but will definitely not use this strip of wood for GH2 and beyond.
Doors blackened and finally attached. There will be small additional work later on (e.g. the door stopper inside the frame). A Lego sailor (Rocky) has been hired to gauge the appropriateness of scale. A 175cm tall (same height as myself) in 1:48 scale Lego sailor stands slightly taller than the top of the door. I suppose with the average height of the English sailors in the 16th century (I believe slightly above 160 cm), the proportion seems OK. Rocky looks kind of angry, but he is just being serious~!
Main deck planking begins. I applied a simple planking method this time and after finishing it I regretted a bit. A 3 butt or 4 butt shift method would have looked better. I will apply at least 3 butt shift in GH2 and GH3. For the deck material, I used 4 variations of the same wood - 1.plain, 2. dyed with tea, 3&4, dyed with slightly different colors.
Hi All, As I started on the beakhead platform, I realized that the Aeropicola plans are quite unreasonable. Therefore, I relied on contemporary paintings as well as fellow MSW modelers' previous works and came up with something that makes more sense (hopefully!). I also finished on bow section deck but I decided not to put treenails there as I realized that I can not put the tree nails in a clean and neat manner (too small space to work on for me). The other decks will get their tree nails. First, I had to put in a second wale in place before moving to next steps.
