cabrapente
Everything posted by cabrapente
  1. watching large amount of times that I am wrong, I think you do not have to worry. oh by the way ... a failure very well built. hehe. greeting one cabrapente
  2. WackoWolfare right. I forgot to use a translator. Sorry. cabrapente
  3. Today I made mini pulleys. I really enjoyed making them
  4. I am putting pulleys pulley blocks larger than 8 mm
  5. I am using wire instead of brass bars -. polished. I'm doing tests with ropes of weapons ...
  6. I start to put pulleys pulley blocks 10 millimeters
  7. really fantastic. I like his work, I learn a lot by watching. Thank you. greeting one cabrapente
  8. I have made ​​a rule to change the size of the planes, at 1/72, 1/48. I'm making scores of various measures
  9. I have removed the potentiometer. I put another 3 engines. I have removed the counterweight and the car I set the table. Fixed bench (I move with arms) is that I use to give tension to the yarns. for the moment leave all tests well.
  10. finally, we're going again. I have made ​​the machine colchar ends. testing it, burned the potentiometer, and I can not control the speed. but still can be used. the threads are old, to practice.
  11. in my case, when I mounted the frames, also had serious problems. I made the wrong decision to continue. I regret it every day. I think starting over is better than continuing something that was manufactured wrong at first. greeting one cabrapente
  12. today is the first time I hear about tools Donna and Jim. after reading the comments from happy customers, I hope to acquire Thickness Sander. I think the price of transport to Seville (Spain) will be worth it. greetings and happy birthday. cabrapente
  13. Thanks for your feedback. this time, until we got something really good, I have not made​​. Now if I'm satisfied with the result
  14. I managed to clean with a degreaser, and I can pavonar brass
  15. in photo # 1, are all parts that did not go well. after many attempts, I managed to go all the same carriages.
  16. I keep practicing. the axes of the wheels, do with a tube placed in the lathe.
  17. I'm starting to make small parts. when I think I've reached the limit,,, I see your work. uff, as I have to learn. a greeting cabrapente
  18. a little trick. to catch small parts, I use a small box that attaches with a magnet.
  19. another question: I believe that the measures in millimeters, the scale I have. Should we reduce them to 1/48? thanks
  20. I have a question. the map, I have drawn red. left rig is it like the right one? thanks
  21. I fabricated a jimelga. I only needed two attempts
  22. thank you very much but if you look closely, you'll also see a lot of mistakes. heh heh
